Samsung D series FBr fix discussion - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #721 of 1660 Old 02-25-2012, 08:26 AM
brian6751's Avatar
Quoted: 1173 Post(s)
Liked: 1159
Originally Posted by mcv83 View Post
No accidental changes : I just scrolled down to USB Logic, pressed enter to select, and right arrow to start ( was too afraid doing bad things that I've been very precise on what I did).
And ok, I can't go back. But If I get the old firmware (through samsung) it is possible to overwrite the last logic firmware right?
No. You cannot overwrite it.
Seriously i think your experiencing the same thing i did. I was really upset. Everything looked awful. I kept messing with the settings and it finally went back to fantastic. I thought toggleing bd wise back and forth then going back to movie mode was what did it but maybe it was something else.
Bottom line is its not the update itself causing the issue so there's no need to wish you can go back.
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is online now
post #722 of 1660 Old 02-25-2012, 08:34 AM
hamiltonpl's Avatar
For what it's worth and it may have already been said - I don't believe that SAMSUNG is sending out the "fix" they promised via the two USBs for the 1019.5 upgrade.
I've already applied the ZOYD fix so I'm good. But, I expected to receive and then post the software on the two USBs for others who wanted to give it a shot.
If anyone else has received ANYTHING like this I would be interested to hear if it did the trick.
hamiltonpl is offline
post #723 of 1660 Old 02-25-2012, 08:51 AM
sherpa25's Avatar
Just to add to the update, it seems to have worked in my PS51D550C1N, simply followed step 2 of Zoyd's post. Pops don't appear w/ the 2 test files, and some SD material where I used to see them. Thanks Zoyd.
Just wish the blacks were better though.
sherpa25 is offline
post #724 of 1660 Old 02-25-2012, 09:40 AM
mcv83's Avatar
Ok. Thanks for your help...I'll try and try harder...hoping to find the new right setup..
Have a nice week end.
mcv83 is offline
post #725 of 1660 Old 02-25-2012, 11:54 AM
AvidHiker's Avatar
Quoted: 24 Post(s)
Liked: 45
Originally Posted by hamiltonpl View Post
For what it's worth and it may have already been said - I don't believe that SAMSUNG is sending out the "fix" they promised via the two USBs for the 1019.5 upgrade...
They are still sending out firmware updates for people who do not need the downgrade (firmware rollback). The rollbacks have never been sent AFAIK, and seems they never will (this has already been confirmed by a few people who complained directly to Samsung that they did not receive the 2 sticks).
That's why anyone who is buying a new TV should not upgrade their firmware direct from Samsung (if you're concerned about FBr). That way, you have a chance one of the firmwares zoyd links in the first post will work without having to use the "hack" method (as it did for my D7000).
AvidHiker is offline
post #726 of 1660 Old 02-25-2012, 04:33 PM
Kootenay Dog's Avatar
Just wanted to add my thanks to Zoyd and the rest of the folks that put together all this information and files.
I found the "FBr" to be very distracting from the day the set was delivered - I didn't have to load any special test videos it was very distracting on regular HD network shows like "Criminal Minds".
I did the manual logic board update to my PN59D8000 this morning following Zoyd's instructions. Perfect!
Spent the day watching a variety of sources and completely forgot about the issue.
It really made a positive difference.
Kootenay Dog is offline
post #727 of 1660 Old 02-25-2012, 09:11 PM
af21187's Avatar
Hi everyone,
Got a 64D8000 from EastCoastTv.com around Christmas time, and have had constant problems with the brightness pops. Thank Goodness for this thread.
Could someone please re-upload the T-GAP8AKUC-1024.8 FW for the US D8000 model? It is showing 0KB at the link provided. Thank you so much!
af21187 is offline
post #728 of 1660 Old 02-26-2012, 05:32 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
zoyd is offline
post #729 of 1660 Old 02-26-2012, 05:40 AM - Thread Starter
zoyd's Avatar
Liked: 1064
no, the old firmware will not overwrite your new logic firmware. However, I can tell you positively that the new logic firmware can not generate the problems you described. You describe "spots" and less sharpness, these things simply can not be generated on the logic board. The only effect the logic board update will have is a minor shifting in the brightness of the darkest levels. I don't know what the source of your problem is but it isn't the new firmware.
zoyd is offline
post #730 of 1660 Old 02-26-2012, 11:03 AM
af21187's Avatar
Originally Posted by zoyd View Post
ok, link is fixed.
Thank you so much for the re-up, but every time I try to extract the folders, I get a "files corrupted" error. I have re-downloaded the file 2 more times and still the same issue. Could someone else please confirm that these files are/are not corrupt?
Thanks guys!
af21187 is offline
post #731 of 1660 Old 02-26-2012, 11:21 AM
Soopermario's Avatar
The file is not corrupt. Downloaded it and extracted with winrar, no problem. Try winrar or 7zip.
Soopermario is offline
post #732 of 1660 Old 02-26-2012, 11:42 AM
Carl Lee's Avatar
I don't know if this has been posted before but I just did the USB update via the DL link and I never seen anything saying "optimization" but after the update restart, the screen went black for about a minute and the Logic SW version is correct. I assume it did its thing.
Carl Lee is offline
post #733 of 1660 Old 02-26-2012, 11:55 AM
jroptop's Avatar
I know when I did mine,it said "updating" then the TV reset and turned back on.When I rechecked the S/W version,it had the appropriate update.
jroptop is offline
post #734 of 1660 Old 02-26-2012, 12:01 PM
Carl Lee's Avatar
Yeah, it did the update, just never seen the "optimization" screen. I was on 1024.4 and now on 1024.8 with the correct S/W version.
Carl Lee is offline
post #735 of 1660 Old 02-26-2012, 12:48 PM
af21187's Avatar
I have tried again and again. Still having corrupt files:
! C:\\Users\\Sam\\Desktop\\T-GAP8AKUC-1024_8.zip: CRC failed in T-GAP8AKUC-1024_8\\image\\appext.img.sec. The file is corrupt
! C:\\Users\\Sam\\Desktop\\T-GAP8AKUC-1024_8.zip: CRC failed in T-GAP8AKUC-1024_8\\image\\exe.img.sec. The file is corrupt
! C:\\Users\\Sam\\Desktop\\T-GAP8AKUC-1024_8.zip: CRC failed in T-GAP8AKUC-1024_8\\image\\Image.sec. The file is corrupt
ootfs.img.sec. The file is corrupt
Please note I am downloading the 1024.8fw for D8000 models.
af21187 is offline
post #736 of 1660 Old 02-26-2012, 01:02 PM - Thread Starter
zoyd's Avatar
Liked: 1064
Did you try another archive utility? I just verified the files are fine but it was zipped on a mac so the stock PC unzipper might choke.
zoyd is offline
post #737 of 1660 Old 02-26-2012, 01:19 PM
Carl Lee's Avatar
If you update the TV to any other current versions (via the update menu) , will it remove this fix?
Carl Lee is offline
post #738 of 1660 Old 02-26-2012, 02:00 PM
F.Ultra's Avatar
Only if Samsung decided to release a new Logic Board version (with a higher version number) that for some reason would reintroduce this problem.
F.Ultra is offline
post #739 of 1660 Old 02-26-2012, 02:24 PM
Carl Lee's Avatar
Something interesting.. I started with 1024.3. Updated with the provided file to 1024.8 and s/w 11-11-04. I just did an update via the TV itself and it "updated" me back to 1024.3 but kept 11-11-04. How come if 1024.8 is a more current version, why did it roll me back to 1024.3?
Carl Lee is offline
post #740 of 1660 Old 02-26-2012, 02:37 PM
af21187's Avatar
Thank for your reply, Zoyd. I have used WinRAR, 7zip, and now WinZIP, and to no avail. I have downloaded the file at least 10 times. I've even tried on a different PC.
af21187 is offline
post #741 of 1660 Old 02-26-2012, 06:23 PM - Thread Starter
zoyd's Avatar
Liked: 1064
zoyd is offline
post #742 of 1660 Old 02-27-2012, 06:34 AM
swurver's Avatar
Thank you for all of the help in this forum. Got my 59D7000 yesterday and the USB fix worked perfectly; didn't even have to use the emulator. Do I need to update the firmware now that the logic board is good, or just leave it? Using some of the posted settings from the other thread and they look great!!! What should I have "film mode" set to-Off, Auto 1, or Auto 2? Thanks again for all of the insight!!!
swurver is offline
post #743 of 1660 Old 02-27-2012, 12:25 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
swurver,
If you did not use the emulator then you had to use the full firmware/logic update -- the 1014.6 version. Check the Menu > Support > Contact Samsung page and tell us what the installed FW version is.
Auto2 is mostly used for non-1080p/24 sources.
Larry
LarryInRI is offline
post #744 of 1660 Old 02-27-2012, 03:57 PM
jroptop's Avatar
Heres a quick question,I did my S/W upgrade and have the current 11-11-04,but How do I know if I have the 1024.8 and not the 1024.3? I checked my current version in the support menu and upgrade and it says current version 001024.Its the same version I previously had before I did the logic board upgrade?Any ideas?
jroptop is offline
post #745 of 1660 Old 02-27-2012, 04:18 PM - Thread Starter
zoyd's Avatar
Liked: 1064
Your main board firmware version doesn't matter, as long as your logic board version is the new one you have the currently best firmware samsung has to offer.
zoyd is offline
post #746 of 1660 Old 02-27-2012, 04:24 PM
jroptop's Avatar
Ok gotcha! Thanks once again Zoyd!
jroptop is offline
post #747 of 1660 Old 02-27-2012, 06:22 PM
swurver's Avatar
Zoyd, you killed two birds with one stone by answering my question as well...thanks!!! Any suggestions for brighter or more vivid 3D? The freebies I got along with the TV seem to make the picture noticeably darker. You, Larry and the rest make this a great forum...thanks for taking the time.
swurver is offline
post #748 of 1660 Old 02-28-2012, 01:34 PM
ogrjmj's Avatar
ok heres my update,i exchanged my 51d550 because it had bad ir and was getting white pixels in the balckbars during movies and was also hoping to get a unit without the fbr,well i get the new unit delivered,turn it on and it has dead pixels.lol, i call best buy,they schedule a service call, i talk to the guy and ask if i should just exchange it since its gonna cost as much or more to change out the panel, he said that might be a good idea, so i call best buy twice in the last two days spend 2 hrs on the phone trying to convince them to just wait until the new models come out next month to send me one of those since they dont have anymore in stock,well i finally got it,as soon as the 2012 51d550 comes out theyre sending me one, and hopefully these have the fbr fixed as i saw in cnet the 8000 models do, so i assume they fixed it in all models,, sheesh what a fiasco.
ogrjmj is offline
post #749 of 1660 Old 02-28-2012, 01:52 PM
N3kKo's Avatar
So would I use FW 1014.6 on my D 6500?
On Samsungs site they have a download for FW ver.1013.1.
Which one would I need to use?
N3kKo is offline
post #750 of 1660 Old 02-28-2012, 02:42 PM
AvidHiker's Avatar
Quoted: 24 Post(s)
Liked: 45
Originally Posted by ogrjmj View Post
...as soon as the 2012 51d550 comes out theyre sending me one, and hopefully these have the fbr fixed as i saw in cnet the 8000 models do, so i assume they fixed it in all models,, sheesh what a fiasco.
If it's an E550, then presumably it will be fixed.
Yes, 1014.6 should work for the D6500, no need to bother with 1013. Just install 1014.6 and verify that the logic version is current per zoyd's first post:
NOTE: If you upgrade via Samsung FW you should see an optimization pop-up during the procedure. Check your logic board FW to see if the update occurred. (poweron mute 7 3 7 enter).
If you do not have the following versions your logic board did not update:
PN51D6500: 11-10-31
PN59D6500: 11-11-04
PN64D6500: 11-11-04
Samsung , Samsung Bd D7000 3d Blu Ray Disc Player Silver , Samsung Bd D6500 Za D6500 Serivce Blue Ray Disc Player 3d Stereo
