Samsung D series FBr fix discussion - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #181 of 1660 Old 01-31-2012, 05:25 PM
brian6751's Avatar
Quoted: 1145 Post(s)
Liked: 1124
not sure what im doing worng. i keep getting FAILED like immidietly. ive tried both 59 versions.
i made a new folder on a usb called "PDP_LOGIC" renamed the file to "LOGIC.bin"
just not working. any ideas?
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is online now
post #182 of 1660 Old 01-31-2012, 05:28 PM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
zoyd is offline
post #183 of 1660 Old 01-31-2012, 05:29 PM - Thread Starter
zoyd's Avatar
Liked: 1064
looks like it's not reading the usb stick, make sure you are using usb 1 slot or try a different stick
zoyd is offline
post #184 of 1660 Old 01-31-2012, 05:37 PM
brian6751's Avatar
Liked: 1124
still not working. goes right to fail in a split second. i tried the other USB input as well
Rivers Edge Theater
post #185 of 1660 Old 01-31-2012, 05:42 PM - Thread Starter
zoyd's Avatar
Liked: 1064
zoyd is offline
post #186 of 1660 Old 01-31-2012, 05:48 PM
brian6751's Avatar
Liked: 1124
59D7000 using 59DS_ITOless_Deepblack.bin
Rivers Edge Theater
post #187 of 1660 Old 01-31-2012, 05:53 PM - Thread Starter
zoyd's Avatar
Liked: 1064
You can try using the other file 59DS_ITO_Deepblack.bin, if that doesn't work try both files again on another USB stick in USB 1 slot.
zoyd is offline
post #188 of 1660 Old 01-31-2012, 05:53 PM
brian6751's Avatar
Liked: 1124
fw version ends in ,BT-G
Rivers Edge Theater
post #189 of 1660 Old 01-31-2012, 05:58 PM - Thread Starter
zoyd's Avatar
Liked: 1064
zoyd is offline
post #190 of 1660 Old 01-31-2012, 06:00 PM
brian6751's Avatar
Liked: 1124
ive tried 2 sticks. when i bring up the first menu it says Logic Connect OFF at the top of the menu. is that ok?
Rivers Edge Theater
post #191 of 1660 Old 01-31-2012, 06:01 PM - Thread Starter
zoyd's Avatar
Liked: 1064
zoyd is offline
post #192 of 1660 Old 01-31-2012, 06:05 PM
FrancoisC's Avatar
Mine's off too on a d6900, but I upgraded using the d7000 method. I wonder what that setting actually does...
FrancoisC is offline
post #193 of 1660 Old 01-31-2012, 06:05 PM
Sam Menard's Avatar
Thanks to Larry and Zoyd for the instructions. Although I don't speak German, I managed to select the correct choices and activated the emulator.
I have a PN51D6500 and successfully upgraded (I hope).
SW version before: 11-02-21
Logic SW CheckSum: ?? sorry I didn't note it
SW version after: 11-10-31
Logic SW CheckSum after: oxB402
tv software version: 1015 (before and after)
Sam Menard is offline
post #194 of 1660 Old 01-31-2012, 06:06 PM
brian6751's Avatar
Liked: 1124
ive tried 3 different usb sticks now
Rivers Edge Theater
post #195 of 1660 Old 01-31-2012, 06:09 PM
brian6751's Avatar
Liked: 1124
USB 1 is right below the opticle in correct? its wall mounted and i cant see back there very well
Rivers Edge Theater
post #196 of 1660 Old 01-31-2012, 06:12 PM - Thread Starter
zoyd's Avatar
Liked: 1064
yes and it's marked (HDD) so it should be fine with larger sticks. The message you are getting (immediate fail) means either it is not reading the stick or the file is misnamed or it's in the wrong folder. Make sure it does not have a double extension, windows sometimes does this if you are not showing extensions.
\\PDP_LOGIC\\LOGIC.bin
zoyd is offline
post #197 of 1660 Old 01-31-2012, 06:14 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
That's a good question, mine was on.
My Logic Connect was showing OFF and the logic board updated with no trouble.
Larry
LarryInRI is offline
post #198 of 1660 Old 01-31-2012, 06:22 PM
brian6751's Avatar
Liked: 1124
i see the extension. i can read the usb through th tv. like as if i were going to view pictures on it. is the us supposed to be formatted a certain way? is the usb itself supposed to be call PDP_LOGIC or am i supposed to make a folder called PDP_LOGIC (thats what i did).
im felling pretty stupid since i seem to be the only one having these issues
Rivers Edge Theater
post #199 of 1660 Old 01-31-2012, 06:29 PM
brian6751's Avatar
Liked: 1124
i DID have a double extension!!!
progress!!
now getting a NO MATCH message
Rivers Edge Theater
post #200 of 1660 Old 01-31-2012, 06:31 PM - Thread Starter
zoyd's Avatar
Liked: 1064
zoyd is offline
post #201 of 1660 Old 01-31-2012, 06:31 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Brian,
The other bin file should work.
Larry
post #202 of 1660 Old 01-31-2012, 06:33 PM
brian6751's Avatar
Liked: 1124
used the other .bin file and Logic sw is now 11-11-04 !!!!!
Rivers Edge Theater
post #203 of 1660 Old 01-31-2012, 06:36 PM - Thread Starter
zoyd's Avatar
Liked: 1064
zoyd is offline
post #204 of 1660 Old 01-31-2012, 06:49 PM
Yoeddy1's Avatar
So what is the process to update the logic board on a PN64D550? Which .bin file should be used? I have the emulator communicating with my TV via the wifi USB adapter (the 550 doesn't have built in wifi). I'll give it a go if I can get the specifics. I updated the tv FW already. Didn't get optimization and have 1019.5.
Jason
Yoeddy1 is offline
post #205 of 1660 Old 01-31-2012, 06:51 PM - Thread Starter
zoyd's Avatar
Liked: 1064
zoyd is offline
post #206 of 1660 Old 01-31-2012, 06:54 PM
datamage's Avatar
From my previous question, updating the firmware alone, did not update my logic board- I too had to follow the steps by Zoyd. (PN64D7000)
My logic board is now updated, so off to do some testing.
Thank you so much Zoyd.
datamage is offline
post #207 of 1660 Old 01-31-2012, 06:55 PM
brian6751's Avatar
Liked: 1124
congrats!
you guys rock!!
the only way i noticed is i had the pointer hovering over the folder and the little pop up windo had "LOGIC.bin.bin" in it. so when you rename the .bin file, just type"LOGIC" and hit enter not "LOGIC.bin" correct?
Rivers Edge Theater
post #208 of 1660 Old 01-31-2012, 06:58 PM - Thread Starter
zoyd's Avatar
Liked: 1064
You're welcome, maybe I should hit up Samsung for a consulting fee.
zoyd is offline
post #209 of 1660 Old 01-31-2012, 07:33 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Hmmm... You gonna give me 10% of that? Okay, then maybe 5%?
Larry
post #210 of 1660 Old 01-31-2012, 07:56 PM
mightymouseusf's Avatar
Quoted: 34 Post(s)
Liked: 34
Originally Posted by LarryInRI View Post
It is becoming clear that 59 or 64D7000 models with an alpha suffix software version like T-MST5AUSC-1015.0, BT-G, will have to use the 64DS_ITOless_Deepblack.bin file. This will yield a result of:
Logic SW Version: 11-11-04
Logic SW CheckSum: 0xE09B
59 or 64D7000 models without an alpha suffix software version like T-MST5AUSC-1015.0, will have to use the 64DS_ITO_Deepblack.bin file. This will yield a result of:
Logic SW CheckSum: 0x3796
EDIT: I'm waiting for more data to verify the above.
Larry
Hey Larry,
Thanks so much for all the help man. I've used your calibrations and your advice about our model. This is one instance however, that you seem to be incorrect. Well, at least with my tv (64D7000FFXZA from 11/11). I did the update today:
Initial version:
T-MST5AUSC-1015.0, BT-G, 11-06-07, 0x2E12
The ITOless bin file kept giving me the "no match" error message. I tried it on 2 different USB sticks and even re-downloaded the file. Once I tried the ITO version it upgraded fine. The tv indicated "upgrading", however it didn't show "optimizing" before the tv reset. I ended up with the following version:
11-11-04, 0x3796
I tried updating the spreadsheet, but for some reason it had me set to read only. I haven't had a chance to really look and see if it's cleared up the pops but I'll let you guys know as I evaluate.
P.S. I think I read some people concerned that the update would reset all your calibration settings. I don't think its the update that did it. In order to check the fw by entering the sm you have to hit "info" followed by "factory". I think if you hit "factory", too late after you hit "info", it doesn't recognize the pattern and just does a factory reset of the calibration settings. Can't say for sure though.
mightymouseusf is offline
Samsung , Samsung Bd D7000 3d Blu Ray Disc Player Silver , Samsung Bd D6500 Za D6500 Serivce Blue Ray Disc Player 3d Stereo
