LG 50PA6500 and LG 60PA6500 Plasmas - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1261 of 1299 Old 10-01-2013, 10:06 AM
Moonwalker1982's Avatar
Quoted: 89 Post(s)
Liked: 29
Originally Posted by angelitto View Post
To see what model u have, u have to do this: Settings / Red button with single white dot / Product/Service Info
U can see there if your model is ZG, ZA or other models.
in your link above, if u press "Software Update" and then [Operating System(s)] LG Firm and "view more", u'll see that this update is for a lot of PA models:
[Applicable Model]
42PA4500-UM
50PA4500-UM
50PA4900-UD
50PA5500-UG
50PA550C-UG
50PA6500-UG
60PA5500-UG
60PA550C-UG
60PA6500-UG
60PA6550-UM
So if your 60'' set is UG or UM, u can install it. If not, u need to wait for another update suitable for your model.
Hey thanks for the reply man, cause i was really stuck here. I just checked..but seems like i'm out of luck. I have a ZA model. I doubt i'll be seeing a firmware update anytime soon.
But i found something interesting. On another forum I saw someone saying you can rename the input of lets say HDMI to PC. I was never aware of this option, but I tried it. I renamed HDMI 2 input to PC and all of a sudden the picture quality was more crisp than usual. If the input remains unnamed/unchanged it looks a lot less crisp. Remember I said that I thought VGA looked better? This now looks exactly like VGA, however..the sharpness, colour and many other advanced control settings are again unavailable. But the Vivid picture mode that is just overly vibrant and ugly on HDMI (without changing input to PC) looks a lot better when the input is changed to PC. Why is this?
Moonwalker1982 is offline
post #1262 of 1299 Old 10-02-2013, 01:46 PM
peter10111's Avatar
Hi Moonwalker, I am happy that you are still here in this thread and your informations are very helpful. I have vertical banding problem exactly like yours. on the grey or light background, the banding was especially visible when the energy saver was set on maximum. I bought this tv (60pa6500) from Costco Canada April 2013, it was clearance $799.99 CA. I did Google search and this banding are normal. but i can see the banding on the grey or light background all the time. should I call for the warranty? and how is your tv now? thank you.
peter10111 is offline
post #1263 of 1299 Old 10-03-2013, 04:45 AM
angelitto's Avatar
If your model is ZA, then i have an update for you. Check this romanian site (im from romania)
http://www.lg.com/ro/suport-produs/lg-50PA6500#
Software_File(Version_03.31.12).zip
[Applicable Model]
42PA4500-ZF
42PA4900-ZE
50PA4500-ZF
50PA4900-ZE
50PA5500-ZB
50PA6500-ZA
60PA5500-ZB
60PA6500-ZA
42PA4510-ZA
42PA4520-ZC
50PA4510-ZA
50PA4520-ZC
50PA6520-ZF
If u press there "Afla mai mult" (view more) u will see the models like i show u here. So, i think the correct version for u is 03.31.12.
But to make sure what version u have instaled on TV, press like i told u before:
Settings / Red button with single white dot / Product/Service Info and check there. If your firmware is older, you can download and install this. But let the TV do it automaticaly, dont try to install it yourself double clicking in from the stick. Cos if the TV dont pop up and tell you that a new version of firmware is found and ask u to press yes to install, then is not a suitable version for your TV.
angelitto is offline
post #1264 of 1299 Old 10-06-2013, 08:41 PM
fragezeichen's Avatar
I tried to download the "Software_File(Version_03.31.12).zip" with no success. The file is 0kb. Could anyone please give a working link or upload it somewhere? Thanks and best regards.
fragezeichen is offline
post #1265 of 1299 Old 10-07-2013, 11:19 AM
angelitto's Avatar
It seems that is not working now. It has 0kb. Maybe its an error or somthing. The other one works fine.
post #1266 of 1299 Old 10-09-2013, 04:44 PM
Quoted: 89 Post(s)
Liked: 29
Hey man. Well i accepted it. I still see it in games like Skyrim and GTA V when looking at the sky, i clearly see vertical banding and its distracting as hell. But i've come to realize (after having had several plasma's now) or just tv's in general, there is no perfect TV. I didn't have any problems with my Samsung plasma a lot time ago, but i did have the horrible green blob on the Panasonic VT30, then i went with a Toshiba 55 inch LED which was said to be perfect for gaming, but the blur destroyed my gaming experience completely. And now this LG plasma which so far its only true downer is the banding. But apparently it's a common thing for plasma.
[Applicable Model]
42PA4500-ZF
42PA4900-ZE
50PA4500-ZF
50PA4900-ZE
50PA5500-ZB
50PA6500-ZA
60PA5500-ZB
60PA6500-ZA
42PA4510-ZA
42PA4520-ZC
50PA4510-ZA
50PA4520-ZC
50PA6520-ZF
Hey thanks man. This is the update i needed...a window popped up and it was a newer version. Could you tell me what kind of things have been changed/improved with this update? I see it seems to have reset my saved picture settings, but that's ok, i made pictures of it.
post #1267 of 1299 Old 10-09-2013, 05:27 PM
angelitto's Avatar
For my ZG model i didnt noticed any improvements but must be some. Thats the point of updates, right?
Well on LG site, u cant find the information about this update, they are lazy about sharing infos.
The only thing i noticed is that, when i open the TV, the clock isnt there anymore.
Anyway, i dont have reasons to complain about this TV yet.
post #1268 of 1299 Old 10-09-2013, 05:46 PM
Quoted: 89 Post(s)
Liked: 29
Now that i have upgraded the firmware, it's probably not possible anymore to go back to the previous version, right? Just to check if there are any picture quality differences. But i assume there's no 'going back' anymore, right? smile.gif
post #1269 of 1299 Old 10-10-2013, 05:46 AM
angelitto's Avatar
post #1270 of 1299 Old 10-10-2013, 03:03 PM
Quoted: 89 Post(s)
Liked: 29
Because i;m probably not too happy with the changes it seems to have brought. I could be wrong and that it's just me, but after the firmware upgrade it seems that the picture quality isn't as crisp as it used to be. I use the GAME picture mode on the tv and I have changed all the settings back to how they were before the upgrade, but letters on the Xbox 360 dashboard seem less crisp and games in general too, while I do have selected those exact settings.
There isn't a way at all to downgrade or well...hard-reset the tv so that it goes back to the previous firmware?
post #1271 of 1299 Old 10-10-2013, 04:52 PM
angelitto's Avatar
I dont think so, But u can write an email to LG customer support. Maybe they can answer your question.
post #1272 of 1299 Old 10-13-2013, 04:46 PM
fredk444's Avatar
My 606550 just died! Was watching Walking Dead on Netflix through PS3, then all of a sudden no picture! The tv turns on and off, and there is audio, but the screen is completely black. I can't even bring up the controls or settings displays. Unplugged everything, still nothing. This was purchased in July 2012 from Costco. WTH. Now what?
fredk444 is offline
post #1273 of 1299 Old 10-14-2013, 03:18 PM
Quoted: 89 Post(s)
Liked: 29
Surely you can count on the warranty?
post #1274 of 1299 Old 10-14-2013, 03:34 PM
fredk444's Avatar
Luckily Costco offers an extra year warranty for free. I would be seriously upset if it was a few months out of warranty and this happened. Costco is having a repair company contact us to set up a time to come out, hopefully soon.
fredk444 is offline
post #1275 of 1299 Old 10-15-2013, 06:37 AM
fairwood's Avatar
Ah, the famous 12 to 15 month LG poop out. Been there, done that. And so have thousands of others if one is to believe what pops up on the google search. Usually it is a power supply board. Mine pooped out right on schedule 15 months after purchase. Cogeco extended warrenty came into play. Same symptoms as you. Turns on and then off within a second. I did not have sound however.
Warrenty people contacted their local service depot, set was picked up and returned a week later. "We changed the board" was all I was told. Quality of service will depend on skills etc of your local shop.
fairwood is offline
post #1276 of 1299 Old 10-15-2013, 07:09 PM
fredk444's Avatar
Hopefully this isn't a recurring problem once it's repaired.
Tech guy called and they are ordering parts, said should be here in about 3 days, then will schedule to come out.
fredk444 is offline
post #1277 of 1299 Old 10-15-2013, 07:38 PM
peter10111's Avatar
Thanks for reply, so here are my 60pa6500's photos. Do you guys think this is horrible banding?? and do you guys accept this? Because this is my first plasma TV and I also own a 47" LG LEDTV. I love plasma very much, but I can't believe this banding issue.
should I call for the warranty? Costco will repair or replace a new TV? or should I keep it like this?  Thanks
post #1278 of 1299 Old 10-16-2013, 02:57 PM
Quoted: 89 Post(s)
Liked: 29
Holy cow dude, i really don't have it that bad on my set. That ain't good what you got there.
post #1279 of 1299 Old 10-26-2013, 06:58 AM
fredk444's Avatar
Repairman came out, replaced three different boards, still did not fix the problem. Called Costco asking for a refund, manager said no problem, bring it in. How awesome is Costco! Thankfully there is at least one company in this world that stands by their products and does the right thing. I doubt if any company would take back a 15 month old tv for a full refund.
No more LG anything for me. Boycott LG! For goodness sake, this company is knowingly selling crap and getting away with it. When people across the country experience the same problem, failure just after warranty expires, it's time to send these companies a message. New electronics should last a minimum of 10 years, not 15 months.
fredk444 is offline
post #1280 of 1299 Old 10-26-2013, 08:44 PM
peter10111's Avatar
Also for my 60pa6500, (Costco refunded everything). I called Costco first, then she said I have to contact LG. Called LG and she said I need to e-mail two of my TV's photos to LG. After 5 Days, Costco called me to return the TV. I thought they will replace a new model 60pn6500 for me,but the CSR said I have to get refund first and then repurchase.Now I will wait and see what TV go next.
Costco is the BEST,best service and warranty. Thank you
post #1281 of 1299 Old 10-27-2013, 10:07 PM
Quoted: 89 Post(s)
Liked: 29
Sucks to hear that man and glad for you Peter.
I sold my tv, i've made the decision to go back to something i have been missing all this time. True big screen gaming and cinema. I am going for a full HD Optoma Projector and soon a 90 or 100 inch to use for it.
post #1282 of 1299 Old 11-04-2013, 06:38 AM
fairwood's Avatar
Quote from above: agree. I think LG is exiting the top market I am in total agreement with that. My 50" LG PA6500 packed in after 15 months (seems OK now after local Cogeco rep took it away for a week ... see my postings in these pages). I just bought a 24" LG computer monitor. The software is buggy, written by an uneducated 8 year old in some far off galaxy. I actually pushed at least 37 telephone buttons going thru "push 1 for EngRish push 2 for appliances .... " First real person was in Quebec, she pushed me over to computers in the Phillipines! She could not help me with trying to get proper software updates. Finally an email address that worked. They sent me updates inPDF form which was also buggy. Enough of 3rd tier products.
fairwood is offline
post #1283 of 1299 Old 12-18-2013, 10:21 PM
dashriprock107's Avatar
How does this tv do with USB file recognition? my samsung plays anything i throw at it... mpg, mp4, .mkv, .avi etc...
Also, how is it for sports? Debating between this and the samsung plasma, but apparently that tv sucks for hockey. Ugh.
dashriprock107 is offline
post #1284 of 1299 Old 12-19-2013, 08:03 AM
peter10111's Avatar
Not mkv for this TV.
sports are not bad, I know some Samsung plasm has flashing problems on ice hockey game!!
(I remembered watching TOR vs BOS last year playoff game, and no problem for LG)
post #1285 of 1299 Old 12-21-2013, 11:08 AM
BaerGriggs's Avatar
Add me to the list of those who've had the circuit board go bad on their LG. (50PA5500 specifically) Luckily I was able to talk LG into a free out-of-warranty repair by calmly stating that this seems to be a widespread issue with last year's model, so not too much harm done. Definitely staying away from LG from now on though.
BaerGriggs is offline
post #1286 of 1299 Old 02-02-2014, 11:54 AM
Pigbait's Avatar
Anyone know why my whites look Grey on this TV?
Pigbait is offline
post #1287 of 1299 Old 02-02-2014, 11:57 AM
Pigbait's Avatar
I'm just switching over from LCD could I just need to get use to the true colors of plasma
thevaxcat likes this.
Pigbait is offline
post #1288 of 1299 Old 03-11-2014, 02:00 PM
thevaxcat's Avatar
I know this reply is really late. I have a small studio, with windows on one side, looking over the city. I am South East, with excellent sunlight. The TV is Perpendicular to the windows. It does not get much direct sun (no beams). My 50 inch model does glare, but not horribly. I am able to focus past it, like old B&W, or some color CRT's. If I am home during the morning, I watch my B-list shows That I listen to, more than watch. If I am home in the afternoon, I can see past the glare almost entirely. I don't know if everyone is able to filter the glare out, like I feel I can.
Evenings is when I like to watch favorite TV shows from the previous days. It pops.
Nights, my favorite time to watch TV is flawless. I could not ask for better.
I do have black-out curtains if I need, but I prefer the sunlight. I love the swivel, and built in divx/mkv player.
Thank you everyone for the great picture settings. only thing I notice is sometimes bright white backgrounds almost look a tiny bit blue. Tiny. A Doctor's jacket looks perfect, as is text. Conversely, the blacks are just stunning. Saturation of other colors just Pop! I watched the new Cosmos, twice. This is after almost two years.
This was a floor model. I don't have much money, so for $550, it is right for me. There were less than 100 hours on it!
It did break on my about 6 months out. I was simply lifting one side up (near middle, not edge), and the picture went. LG took care of everything, even a loaner for the 2 weeks it was out. It was serviced by the best TV people in town. Not a moment's trouble since. I never upped the firmware, as I have no problems (I have the 6500- 50 inch).
If you still can find one, I'd buy it if it were $550, or below. I only say that because LG backed the warranty, without any fight. Not all products are perfect, and they made good.
When people come over and see my TV, they wonder how a "cheap" TV can be better than their newer LCD's. I always known Plasma was the way to go, as I am a fan of many tech-casts, and blogs. The general consensus was that LG was the weaker than the other two manufacturers, but they always test the TV's I could never afford. I love it, and it works for me. I feel this TV will last me many years. I can wait for 4K to be obtainable, with abundant content.
thevaxcat is offline
post #1289 of 1299 Old 01-10-2016, 07:51 AM
Liked: 0
Question 50PA6500-UA Not Finding any channels doing auto tune.
I just bought a used PA6500-UA tv. I can get a good picture using my DVD player connected with component cables. However when i connect my antenna rf cable or Satellite rf cable i do not get any picture. When i do the auto scan it does not find any channels with my outside antenna connected. I get several channels from my antenna and Satellite when connected to another TV. Anyone have any idea whats going on? Thanks in advance.
poorfella is offline
post #1290 of 1299 Old 01-11-2016, 07:20 AM
angelitto's Avatar
Pa6500 doesnt have DVB-S, so you cant use it with satellite. But with room antena you can. You just need to select "antena", before "automatic scan" for programs.
Lg 60 Inch Pa6500 Plasma Hdtv , Lg 50pa6500 Plasma Hdtv
