LG 50PA6500 and LG 60PA6500 Plasmas - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #121 of 1299 Old 05-18-2012, 02:04 PM
brody76's Avatar
Since you mentioned It I can notice those too on my plasma.
I can't see them during a movie, but on dark image I can for example.
I'd like to ask again since no one answered, I'm not able to see the running time on my plasma in the "Costumer support" menu, can any of you ? Someone said earlier in this topic that he could, I wonder why I can't.
It would come in handy for the break-in period.
brody76 is offline
post #122 of 1299 Old 05-18-2012, 03:32 PM
goodoldman5's Avatar
^^^^ i will check out the customer support menu tonight when i go home.
goodoldman5 is offline
post #123 of 1299 Old 05-18-2012, 05:05 PM
Turrican4D's Avatar
Quoted: 742 Post(s)
Liked: 436
Two things I'd like to mention:
1. Dithering in the dark shades near black is not the same as on Panasonics. Panas have much finer noise in these areas and this year's models even made additional progress to that matter.
2. Brody76, 46 to 48 brightness seems too low. The brightnesssetting is basically there to reach for the optimum point of black. On my PK350 it's 54.
Prof. Dr. Turrican M.D.
Turrican4D is offline
post #124 of 1299 Old 05-18-2012, 05:37 PM
NorthernNerd's Avatar
My ancient 27" CRT died, finally. I was hoping it would hold on until OLEDs dropped into my price range. Alas.
So what I was thinking was that I'd get a good but not great set now to tide me over until OLEDs are reasonably priced. I was getting ready to buy a 60" Panasonic ST50 that is on sale at London Drugs here in Canada for $200 off (regular $2499) until May 23rd. The ST50 has awesome bang for the buck, but there are a number of people that comment on its buzz that I am very sensitive to (took back two Samsung 6500's last year because of it). That plus flashing during basketball / hockey and so-so 3D are giving me second thoughts.
Costco up here has the 60" LG PA6500 for $200 off its regular price of $1499. That $1000 difference widens if you consider that I'd have to buy a pair of 3D glasses to take full advantage of the ST50. My room's light is well controlled so I can live with the LG being more reflective than the Panny. The LG is looking like a heck of a deal. I don't care about SmartTV. 3D would be nice but no point paying a lot if it isn't really good 3D, and it sounds like the ST50 doesn't have really good 3D.
Anyhoo, I've read all the messages in this thread and haven't seen any comments on input lag for gaming. The ST50 is excellent here. Can anyone comment on how the LG fares?
NorthernNerd is offline
post #125 of 1299 Old 05-19-2012, 07:52 AM
KAB53's Avatar
I decided I was still unhappy with flesh tones, compared to my Sammy plasmas. So I started over and kept it simple:
Aspect Ratio: 16:9
Energy Saving: Off
Picture Mode: Standard (User)
Contrast: 83
Brightness:55
Sharpness:25
Color: 48
Tint: G8
Color Temp: W10
Advanced Control
Dynamic Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Color Gamut: Wide
Edge Enhancement: Off
Best yet. I'm probably done.
KAB53 is offline
post #126 of 1299 Old 05-19-2012, 12:09 PM
brody76's Avatar
Well after 50 it starts degrading my blacks, and making them clearer.
I'm at 52 now, or I will have that annoying bug if I go any lower (screen turning off). But I couldn't go any higher, or my blacks would look washed out.
I think it mostly depends on the room and position of the set.
brody76 is offline
post #127 of 1299 Old 05-19-2012, 09:29 PM
Tilk's Avatar
Settings/red button/product/service info... The fourth line down right under serial number is "used time"
Tilk is offline
post #128 of 1299 Old 05-19-2012, 10:34 PM
brody76's Avatar
Yep, that's what I've been doing.
Unfortunately I don't have a forth line (it's empty, like a skipped line).
Do you happen to have the 5500 by any chance ? Maybe that's one of the differences between the 6500 and 5500.
brody76 is offline
post #129 of 1299 Old 05-20-2012, 03:03 AM
rb1213's Avatar
Brody,
a bug in the tv? sh*t I just ordered a 50PA6500 !
byt the way on the Belgian website they removed the 50PA6500
and some shops also say ' not available any longer '
only the 50PM6700 is available now ? was it too cheap compared to PM6700?
cheers
rb1213 is offline
post #130 of 1299 Old 05-20-2012, 11:48 AM
brody76's Avatar
From what I read, the PM6700 was terrible compared to the PA6500.
Some users swapped it for the PA6500 because it had better PQ.
Anyway, here it is :
brody76 is offline
post #131 of 1299 Old 05-20-2012, 01:15 PM
skriefal's Avatar
Quoted: 97 Post(s)
Liked: 80
My 60PA6500 has the fourth line, labeled "Used Time". Firmware version is 03.09.00. Perhaps this is a difference between the US firmware and your (French?) firmware.
skriefal is offline
post #132 of 1299 Old 05-20-2012, 02:48 PM
cjsiv's Avatar
Liked: 40
I had the PM6700. The picture was about the same as the PA6500. I got two in a row with defects in the panel. There was what looked like plastic shaving or debris behind the glass about the size of 2-3 pixels. Not wanting to try my luck a third time, I switched to an led set. The 3d was amazing with the passive cinema 3d but the 2 D picture was garbage. After seeing the passive 3d, I decided it was a waste of money to get a plasma with active 3D because it would just be a letdown in comparison. Too much crosstalk and ghosting. So I went with the 60PA6500 and have been issue free since.
cjsiv is offline
post #133 of 1299 Old 05-20-2012, 04:39 PM
Tilk's Avatar
my model is 50pa6500-ua running firmware 03.09.00 and there is a fourth line saying
"-Used Time: XX"
Tilk is offline
post #134 of 1299 Old 05-21-2012, 03:14 AM
rb1213's Avatar
Hi guys,
there seems to be a problem with the PA6500
to display 1080p/24
can someone confirm this doesnt show correctly (jidder?)
cheers
rb1213 is offline
post #135 of 1299 Old 05-21-2012, 05:19 AM
cjsiv's Avatar
Liked: 40
Mine looks about like the other two sets I've displayed 24fps in. It just has a little judder because it is an entry model set IMO.
Did you read somewhere that it has a problem or is it your opinion that it has an issue ?
cjsiv is offline
post #136 of 1299 Old 05-21-2012, 05:24 AM
rb1213's Avatar
Someone on the HDTV shootout in the US said that yesterday
just wanted to check the judder level.
so It's fine Thanks
I'm still waiting for my Pa6500 to come in.
I've got a 50PK550 now but the shadow details I lose made me want a Pa6500.
(+ the cheap upgrade price)
rb1213 is offline
post #137 of 1299 Old 05-21-2012, 05:47 AM
cjsiv's Avatar
Liked: 40
Like I said. I'm not an expert and I picked mine up for $998. For a 60 inch plasma that costs less than a grand it looks acceptable to me. There is some judder but I have more tolerance due to the price. I can totally live with any deficiencies for what I paid. A competing Samsung where I live is $350 more and $500+ more for a Panasonic.
cjsiv is offline
post #138 of 1299 Old 05-21-2012, 01:29 PM
brody76
I checked this last night mine also shows just the "used time: XX "under the firmware version.
post #139 of 1299 Old 05-21-2012, 01:56 PM
stealthx's Avatar
Hello, does the LG 50PA6500 have HDMI 1.4 with Audio Return Channel (ARC) support?
stealthx is offline
post #140 of 1299 Old 05-21-2012, 06:07 PM
cjsiv's Avatar
Liked: 40
Deleted.
cjsiv is offline
post #141 of 1299 Old 05-21-2012, 08:36 PM
brody76's Avatar
I agree.
Last night turned the TV on to catch up with a few shows, and I was surprised by the PQ again, really good for the price.
As for judder, have noticed some few times, but nothing bad.
I can live with it.
Does anyone know if it's still possible to activate THX via secret menu on the 2012 models ?
brody76 is offline
post #142 of 1299 Old 05-22-2012, 10:25 AM
Gimpy2k7's Avatar
I posted a thread in the plasma forum about an issue I'm having with our new 60PA6500. I was referred to the owner's thread and I hope I've found the right place.
Forgive my copy/paste but this is what I had written out in the other thread:
I've got a question specifically about the black, fading to black and seemingly power off for a brief second during that time.
We were watching a movie (blu-ray on PS3) the other night and quite often scenes were fading to black then fading in to the picture from black. Something I noticed is when it first faded to black it looked fine, but once it reached a certain "level of black/darkness" it was a sudden change from the...greyish color that I assume is the light because the TV is on...to a very deep black with no light, like the TV shuts off. It's almost like at the end of the fade it shuts off briefly and then starts up (ie. light/TV comes on) and then fades back in. It's a minor issue but hugely distracting when you notice it.
I hope I've described the issue well enough to be understood and wanted to ask if there's anything I can do about that. Is there a setting somewhere perhaps that prevents it from completely shutting off when fading to black? Or is it something that we just have to deal with.
Gimpy2k7 is offline
post #143 of 1299 Old 05-22-2012, 10:49 AM
rb1213's Avatar
I think Brody said not to put Brightness below 50 or 52 to stop this.
Brody?
rb1213 is offline
post #144 of 1299 Old 05-22-2012, 12:35 PM
brody76's Avatar
Brody?
Right, raise your brightness to 52 and It'll disappear.
brody76 is offline
post #145 of 1299 Old 05-22-2012, 12:38 PM
rb1213's Avatar
I still didn't get my 50Pa6500 (no stock) , the shop asks me if I want a 50PM6700 instead for only 50€ extra ?
what would you guys do ? DLNA, 3D extra for only 70$
rb1213 is offline
post #146 of 1299 Old 05-22-2012, 02:08 PM
KAB53's Avatar
Do you have energy saving off?
KAB53 is offline
post #147 of 1299 Old 05-23-2012, 08:05 PM
cjsiv's Avatar
Liked: 40
Mine is boxed up and going back tomorrow. Worst dithering I have ever seen. Looks like red and green noise. Only way to reduce it is to crush the blacks. Bad enough that it actually distorts the lines with letterbox content at normal viewing distance. I have had 3 defective LG plasmas this year. Ordered a new Samsung PN64e550. Hoping to have better luck. I think LG is cutting too many corners trying to compete with Samsung and Panasonic and it is severely affecting quality. I pretty much will never buy another LG product after this mess.
Installing and returning 3 60 inch plasmas totally sucks!!
cjsiv is offline
post #148 of 1299 Old 05-24-2012, 02:06 AM
brody76's Avatar
Sorry to hear that, fortunately I have nothing similar and my PQ is more than acceptable.
Good luck with your new plasma.
brody76 is offline
post #149 of 1299 Old 05-24-2012, 03:44 AM
Gimpy2k7's Avatar
Thanks for the tip, I'll put the brightness up a bit, I think it's at 50 right now. Also I think we turned energy saving on the other day. I take it that's not a good idea? (I'll say I wasn't the one who wanted it on)
Also I'm kind of worried after looking through this thread about how unhappy people are with the TV. Personally I think it looks great, but I haven't had 5 or 10 plasmas in the past to compare it to.
I'm sure I'll be able to do a few tweaks here and there to improve it even more but I'm happy with it for sure.
Gimpy2k7 is offline
post #150 of 1299 Old 05-24-2012, 08:18 AM
brody76's Avatar
I feel the same, for the price I can't complain.
If it was 1k I would definitively return it and get a Samsung or Pana, but for 700$ ....
brody76 is offline
Lg 60 Inch Pa6500 Plasma Hdtv , Lg 50pa6500 Plasma Hdtv
