Samsung Plasma Panel tweaks for better blacks. - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #361 of 483 Old 03-19-2014, 07:45 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
So I should or shouldn't touch the vsc? I thought that one should be adjusted as well as yrr?
I'm mostly just squeamish about adjusting anything on the power board, both the vsc and yrr are apparently on the y sustain board right?
Mik James is offline
post #362 of 483 Old 03-19-2014, 08:01 PM - Thread Starter
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
zoyd is offline
post #363 of 483 Old 03-20-2014, 08:10 AM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
Well, it's been 2 years now since my initial adjustment based on info learned in this thread. And I'm now finally seeing enough misfires to motivate me to pull the back plate again and make another adjustment. I'm already dreading all those screws! And squeezing myself behind the display.
For anybody feeling hesitant, I have no regrets about making the adjustment. The small inconvenience of needing to go in and do it again is easily offset by the past 2 years of noticeably better contrast on my display. And when they do eventually start appearing, the pixel misfires aren't terribly distracting. Even now they only happen on very specific content, and I'm the only one that seems to notice them.
pitviper33 is offline
post #364 of 483 Old 03-24-2014, 12:13 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Are the f4500 and e450 panels also candidates for this tweak or just the d450?
post #365 of 483 Old 03-24-2014, 12:22 PM - Thread Starter
zoyd's Avatar
Liked: 1051
zoyd is offline
post #366 of 483 Old 03-24-2014, 12:28 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Alright thanks, the d450 had color uniformity issues so I had to return it.
post #367 of 483 Old 04-22-2014, 02:07 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Hey zoyd I'm a hesitant too do this adjustment,but on yours is the scrolling screen wash the exact same grayscale colortone as regular tv? I've read some adjustment patterns built into the tv can be a different colortone as regular tv.
Vic12345 is offline
post #368 of 483 Old 04-22-2014, 11:34 AM
whityfrd's Avatar
Quoted: 63 Post(s)
Liked: 52
i used the HD color bars as opposed to the white wash pattern. You can tell when your going too far clockwise as the as it looks like the whole picture is deteriorating. Believe me, you'll know when it happens.
whityfrd is offline
post #369 of 483 Old 04-28-2014, 11:05 PM
chucky2's Avatar
zoyd,
Quick questions for you. When you said this, "Firmware version will not matter. First try lowering Vs (ccw) as far as it will go which is around 195V and see I'd that gives more adjustment room for Yrr. You can also raise Ysc from -190 to -180 (approx). Do not adjust Va or Ve.", how did you arrive at those voltages? Were you looking at the screen looking for misfires or did you just max the pots as far as they would go? Or just something else?
Thanks for this great thread!
Chuck
chucky2 is offline
post #370 of 483 Old 04-29-2014, 02:34 PM - Thread Starter
zoyd's Avatar
Liked: 1051
zoyd is offline
post #371 of 483 Old 04-29-2014, 04:06 PM
chucky2's Avatar
Ok, so for Vs and Ysc, you didn't adjust to a voltage with your multimeter, you adjusted based on misfires on the screen, correct?
Or, when you say Vs as far as it will go, do you literally mean just turn down the pot on Vs as far as it will go?
chucky2 is offline
post #372 of 483 Old 04-29-2014, 06:25 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
In general from my experience I would increase Vs, drop -Vsc. High Vs has no effect on the panel black level but can increase overall contrast due to brighter whites.
tom669 is offline
post #373 of 483 Old 05-03-2014, 11:00 AM
pimpology26's Avatar
Quoted: 32 Post(s)
Liked: 39
I get misfires mostly on the left side of the screen and really its just red and green colors that you can notice them. Overall the lowered black level looks great! I dont have a gray tv anymore! Has anyone noticed misfires on one side of the screen like mine? I have an older samsung 50B560
pimpology26 is offline
post #374 of 483 Old 05-14-2014, 12:31 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Any way around the mll variance across the screen? I'm getting ready to do the tweak and I want to know if the variance is noticeable in very dark scenes or just when the sets don't detect a signal/full black screen?
post #375 of 483 Old 05-14-2014, 01:57 PM
chucky2's Avatar
I did this a couple of weeks ago on a PN50C8000 that has quite a lot of hours on it, and the Yrr was in the 3-4 o'clock position already (perhaps Samsung intentionally doesn't adjust the other plasmas helping the C8000 have better blacks?). I was able to turn it to the 5:50 position, with the maximum adjustment allowable being the 7 or 7:30 position.
I looked for misfires on the white and black screens, along with the green. On the white screen, the purple dots/bloom came up in the center bottom and grew from there. So I just dialed it back until I was barely getting any purple misfires. Then I used the AVS calibration disk here to set my black levels (we had been running brightness way too high for nighttime viewing).
Can't say it was really worth it for our situation as far as blacks vs hassle & risk go, but, it is now off my mind as something to try. Those with sets that have much lower hours and are willing should try it, it was really that hard at all. Just be OCD about what you're doing so you don't screw anything up.
Chuck
chucky2 is offline
post #376 of 483 Old 05-14-2014, 06:14 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
I see no yrr, only vscan on a long vertical board to the left as well as vs and va on the power board in the middle. It's a pn43d450a2d.
post #377 of 483 Old 05-14-2014, 07:22 PM - Thread Starter
zoyd's Avatar
Liked: 1051
I just looked up some pictures of the Y-sustain boards for the 43" and I don't see one either. Seems it's only available on the 51" 450s.
zoyd is offline
post #378 of 483 Old 05-14-2014, 07:25 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
I guess I'm tv shopping again then biggrin.gif.
post #379 of 483 Old 05-25-2014, 09:41 AM
Mob-Rules's Avatar
Do you know if the PN51F5500 would have the pots?
Mob-Rules is offline
post #380 of 483 Old 05-25-2014, 03:04 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
After looking at some pn51f5300 replacement boards on ebay it doesn't seem to have the tweaks. Probably good to confirm that and post it to the original post/front page to deter any adventurous f5300 owners from voiding warranties wink.gif
Edit: Mob-Rules: It doesn't appear to have the tweaks:
http://www.ebay.ca/itm/Samsung-PN51F5500AFXZA-LJ41-10317A-LJ92-01943A-Y-Main-Board-/231235209271?pt=US_TV_Boards_Parts_Components&hash=item35d6b14837
The thread creator/op might have a better idea of that though.
post #381 of 483 Old 05-26-2014, 09:16 AM
Mob-Rules's Avatar
I might dig up the courage and open it up since the TV is about 6 months old. If it was going to break, it would have. Or I'll just buy the service manual.
post #382 of 483 Old 05-26-2014, 10:55 PM
Mob-Rules's Avatar
I opened my pn51F5500. It has the vscan pot, vs adj, and va adj. Although I found the sector for Yrr I saw no pot. I have ordered the Service Manual anyway to see if by lowering the voltage I can squeeze out some darker blacks or adjust the yrr electronically.
post #383 of 483 Old 07-10-2014, 02:03 PM
klajbas's Avatar
Liked: 0
Hi Mob-Rules
Did you try to tweak your TV? If you did what are the results?
I am thinking of tweaking my pn60f5570 which is the same model but for European market (and size 60" pentile).
I did the voltage tweak on my LG PG6000 a few years ago with good results for that time. Sold it and bought this Samsung...
klajbas is offline
post #384 of 483 Old 07-15-2014, 06:40 AM
Mob-Rules's Avatar
Hello Klajbas. I became very busy when I set out to do the voltage tweak. I haven't gotten around to it, so I don't know if the voltage adjustment will work. I will give it a shot in the next month or so.
post #385 of 483 Old 07-15-2014, 05:48 PM
Vegeta's Avatar
Quoted: 25 Post(s)
A shame if it doesn't work on the F series Plasma TVs i.e PN60F5500.
Vegeta is offline
post #386 of 483 Old 07-15-2014, 09:21 PM
cjpk248's Avatar
Quoted: 42 Post(s)
Liked: 24
Anyone have any good info on adjustments to be made on a 51" F8500?
cjpk248 is offline
post #387 of 483 Old 08-13-2014, 11:33 AM
orion2001's Avatar
Quoted: 462 Post(s)
Liked: 311
Hi Tom, from Zoyd's OP, it does seem though that lowering Vs can lower black level? As you may recall, on my PN60F5300, I lowered Vs all the way down to 197V from 208V as it seemed to help with the pink tint issue. I believe that this also lowered my black level with Black Optimizer on Dark Room. I consistently measure 0.002ftL black level, which is inline with what the F8500 panels achieve! Unfortunately I don't have measurements prior to the tweak, but the difference in the black "glow" when viewing in a pitch black room is very noticeable to me after the tweaks. ).002ftL looks simply amazing as the blacks blend in with the bezel on pretty much all scenes except the faintest/dimmest ones.
I haven't played with Yrr as suggested in the OP, but I'm not sure I care for trying to tweak this further.
Even with dropping Vs, I measure a contrast ratio of ~17,500 on my panel, with 12% size, 100% white windows measuring ~35ftL
RyanHomsey likes this.
orion2001 is offline
post #388 of 483 Old 08-28-2014, 08:22 AM
FrancoisC's Avatar
Originally Posted by buttonsw View Post
An update....
I tried the Yrr tweak last night but unfortunately my set was at it's limit already and only the tiniest of turns resulted in misfiring pixels, but the annoying thing is that the misfires were only on the top half of the screen and turning the Yrr pot a bit more resulted in the bottom half getting lovely and black and the top half misfiring with a clear horizontal line separating the two halfs!
Top half was dark grey and the bottom half was getting darker (Black). I had to put the pot back to where it was so my black level is still poor but I could see how low it could go but only on the bottom half
I didn't check the voltages against the sticker as I am waiting for a new multimeter to be delivered but the fact that the misfires happened immediately after turning the Yrr pot suggest that my voltages are out or too low?
A picture of what I see before and after tweak (In paint LOL)
Steve
I'm quoting this because my TV is starting to develop something like that (PN51D6900). At first I though it was just the panel aging/dying, but I read some article and watched some youtube videos that fixed it by changing the Y buffer board...
Worth a shot, or would it just be a waste of money?
FrancoisC is offline
post #389 of 483 Old 09-02-2014, 07:37 PM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Finally was going too do the yrr tweak on an e450 but there is no pot adjustment for it but thanks for the thread as there's other good info here.The black levels are fine on mine anyway.
Vic12345 is offline
post #390 of 483 Old 10-17-2014, 09:46 AM - Thread Starter
zoyd's Avatar
Liked: 1051
Here are the results of voltage tweaks on a 60F8500. Adjustments are available for Vs, Va, Vscan and Ve but only Vs and Vscan were found to have any effect on black levels.
Turning Vs down from the preset value of 209 to 190 volts reduced the black level for higher APL scenes and reducing Vscan from the preset value of -200 to -190 volts reduced the low APL scene blacks. The net reduction was 15%-20%
Other findings:
  • Reducing Vs also reduces peak white (about 10% in this case).
  • 24Hz playback with CS on has the best black level performance.
RyanHomsey and orion2001 like this.
zoyd is offline
Samsung Pn51d8000 51 Inch 1080p 3d Ready Plasma Hdtv 2011 Model
