Which cable should I use to connect my PC to my PN51D8000 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-12-2012, 12:40 PM - Thread Starter
raehza's Avatar
Hello!
I have a new PN51D8000 from Samsung and I'd like to connect it to my PC. As I understand there are different VGA cables (VGA, SVGA et.c) and they all represent different resolutions.
Which cable type would allow me to use the maximum resolution that my TV allows? Wouldn't it be HDMI instead of VGA? But can I connect my PC to my TV via and VGA to HDMI cable? Is that even going to work or am I over thinking this?
Ray
Projector: AE7000
Screen: 5x12 Wilson Art Laminate Designer White
Receiver: Denon 2112Ci
Fronts: DefTech 8020ST
Center: DefTech 8040HD
Side Surround: DefTech SR 8040 BPs
Rear Surround: DefTech PM 1000s
Subwoofers: 2x HSU VTF 15H's
raehza is offline
post #2 of 11 Old 02-12-2012, 12:56 PM
LanceX's Avatar
Quoted: 84 Post(s)
Liked: 30
vga to hdmi
LanceX is offline
post #3 of 11 Old 02-12-2012, 01:52 PM
petern's Avatar
There aren't different types of VGA cables. There are different VGA resolutions, but they all use the same 15-pin D-Sub cable.
Look in the manual for your TV to see what VGA resolutions it supports. It may accept a 1920x1080 signal; then again, it may not.
No cable alone will convert "VGA to HDMI". You may have a graphics card which has a VGA-style output which can be switched with software to output VGA or HDMI.
petern is offline
post #4 of 11 Old 02-12-2012, 01:55 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Check to see if the PND8000 will accept a 1920x1080 signal over VGA. If so, try any VGA cable and see how that works.
A VGA-to-HDMI cable may not work since VGA video cards tend to not be HDCP compliant so the TV may not display a video signal in this case (due to copyright limitations).
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 11 Old 02-12-2012, 01:59 PM - Thread Starter
raehza's Avatar
Thanks for the replies but Samsung doesn't show any info on the resolution.
http://www.samsung.com/us/video/tvs/...000FFXZA-specs
Or maybe I am overlooking it? It just says that my TV has a VGA input.
Ray
Projector: AE7000
raehza is offline
post #6 of 11 Old 02-12-2012, 02:14 PM - Thread Starter
raehza's Avatar
Called Samsung and the guy on the phone didn't sound like he knew much about it. He said he'd need to research it got back to me after a 2-3 min wait on hold. He says I can put a regular VGA (the obvious choice) and a DVI to HMDI adapter. My Graphics cars supports DVI so I guess I'll try that.
Thanks fellas!
Ray
Projector: AE7000
raehza is offline
post #7 of 11 Old 02-12-2012, 02:45 PM
malovich's Avatar
What outputs does your computer have?
HDMI to HDMI would be optimal
VGA to VGA should work as long as your tv accepts it at 1080p and you are not planning on watching blu-ray movies on it
DVI to HDMI will work without potential resolution limitations but again, no blu-ray movies.
XBL Krimzen Rage
malovich is offline
post #8 of 11 Old 02-12-2012, 02:56 PM - Thread Starter
raehza's Avatar
Only purpose for connecting my PC to my TV is mostly for youtube (my TV has youtube but I rather use a Keyboard ) and some Videos I have saved on my PCs HD. Also, I'd like to occasionally play some Games on my PC but use the TV.
Ordered a 25ft cable from Monoprice.
Ray
EDIT: My PC has 2 DVI connectors.
Projector: AE7000
raehza is offline
post #9 of 11 Old 02-12-2012, 07:39 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Originally Posted by raehza View Post
Thanks for the replies but Samsung doesn't show any info on the resolution.....Or maybe I am overlooking it? It just says that my TV has a VGA input.
The detailed PC resolution specs should be listed in the owner's manual, they won't be listed in the abbreviated online specs. There's probably a large chart in the manual that tells you exactly which resolutions the PC input will accept.
Randy
post #10 of 11 Old 02-19-2012, 03:36 PM - Thread Starter
raehza's Avatar
The Monoprice cable worked! Only issue I have is that the picture doesn't fill the entire TV Screen. I have big "edges" on each side of the screen. I tried different settings and "fit to screen" is the best. It still doesn't fit the entire screen though.... hmmm
Ray
Projector: AE7000
raehza is offline
post #11 of 11 Old 05-10-2012, 02:08 PM
mdbsat's Avatar
I am glad I found this thread. I am using a mini HDMI to HDMI adapter and the screen fills and graphics look amazing (I am running two Nvdia 570GTXs in SLI). The problem is, and I am embarrassed to say this, I don't know how to get the sound to play through my TV or receiver. Can anyone help me out with this?
mdbsat is offline
Samsung Pn51d8000 51 Inch 1080p 3d Ready Plasma Hdtv 2011 Model
