FBr on the X3 Series ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-21-2012, 03:28 PM - Thread Starter
sboychuck's Avatar
I just picked up two 42X3's and was wondering if they can experience the fluctuating brightness issue? My 65GT30 did and a Panny Tech did the SD Card fix. I am running the slides right now and do not have a source plugged in. They are both June 2011 builds and the serial number sequence is MB1171XXXX. Thanks in advance...
sboychuck is offline
post #2 of 2 Old 02-21-2012, 09:27 PM
mailiang's Avatar
Quoted: 849 Post(s)
Liked: 586
The FBR issue is more common with the higher end NEO PDP's.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
