Weak Signal from HDMI - General Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-24-2012, 01:05 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Not sure if this is the right forum to ask, but what the heck. I have a Samsung Plasma (A550), and a friend of mine has a more recent Samsung Plasma (can't recall the model).
Both of us have intermittent issues whereby while watching cable (can't recall if it happens any other time) we get "weak signal" indicators on the TV, where the screen goes blank but sound can still be heard clearly.
I was assuming it was likely the cable box, but wonder as well if it might be a handshake issue or the HDMI cable itself.
But then got to thinking, if it was a handshake issue or the HDMI cable, wouldn't I get no signal at all vs being able to hear sound but not see video? I.e., either a signal from the source box passes through or it doesn't, versus one aspect of the signal coming through (audio) while video doesn't?
I know, I could just try swapping cables but in my case it happens maybe a couple times a week and it would be a pain to change cables (TV is mounted and access to the rear panel is a pain), so figured what the heck, I'd ask first...
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #2 of 4 Old 02-24-2012, 01:07 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
poor service from cable company.
the message is from the box
Loving D65
CalWldLif is offline
post #3 of 4 Old 02-24-2012, 05:59 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
From the box? Looks like a Samsung message to me. Ie. same one as the "no signal" message when there is a handshake issue.
pbc is offline
post #4 of 4 Old 02-21-2013, 10:31 PM
Vegemeister's Avatar
It is your Samsung TV giving you the message as does mine.
I only have the problem when viewing from my PC. The DirecTV DVR never has the issue.
When the PC does cause the problem, the DVR won't revive the picture, I have to turn off the TV and back on again to get the picture back after I receive that message.
Hopefully we'll see a solution here. I'll keep working on it.
Vegemeister is offline
