Plasma Question - Refresh - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-24-2012, 01:15 PM - Thread Starter
asmealio's Avatar
Quoted: 17 Post(s)
My company bought a plasma a while back and had no use for it. Now they want to use it to display a single screen for 8 hours a day
I have a solution to prevent IR, how long do you guys think i should leave my plasma off before bringing it back on to display the image.
My thoughts where 5 minutes of off time for 15 minutes of display.
asmealio is offline
post #2 of 3 Old 02-24-2012, 04:02 PM
BillP's Avatar
Quoted: 258 Post(s)
Liked: 199
I don't think that will work. If it is always showing the same fixed screen when on, then periodically turning it off will not help. The best way to prevent it is to change the screen when on!
BillP is offline
post #3 of 3 Old 02-24-2012, 04:14 PM
JRoX85's Avatar
instead of turning it off have some slides running through it
It's all fun and games until my wife notices something new in the entertainment center
JRoX85 is offline
