Strip of staticy/moving pixels across the top of my ST30? - AVS Forum | Home Theater Discussions And Reviews
Old 02-25-2012, 04:29 PM - Thread Starter
MASKOAA's Avatar
I decided that I wanted to see if there was any signs of burn in since I've been play alot of Call of Duty lately lol, so I made this image to load on my 360 and at the top of the screen I noticed that theres a strip of pixels going horizontally across the whole screen that seem to be moving....you wouldn't notice it at normal viewing distance especially since you don't look at things that are a solid color but I just wanted to know if anyone knew what that was. My set is a 42 inch ST30 and it took up about an inch and a half of screen space going across the entire screen. I couldnt notice it as much on other colors. This is the picture I used.
http://img14.imageshack.us/img14/4835/63875833.jpg
MASKOAA is offline
Old 02-25-2012, 09:01 PM
vzphoneman's Avatar
Quoted: 83 Post(s)
Liked: 78
That's normal same thing happens on my 58" S1.
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is offline
Old 02-25-2012, 10:08 PM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
it is called dithering and it comes with any plasma package it souldn't be a problem if you aren't trying to fake an IMAX experience 12" from the tscreen.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
Old 02-25-2012, 10:15 PM - Thread Starter
MASKOAA's Avatar
I just thought it was weird that its only showing on a perfect strip across the top of the screen rather then the whole image since the image is a solid color.
MASKOAA is offline
