Official Panasonic ST50 Series Discussion Thread [No Street Price Talk] - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #3331 of 10076 Old 06-03-2012, 09:17 AM
deathrattlehead's Avatar
Quoted: 16 Post(s)
Originally Posted by stuart81 View Post
Have definitely noticed this. Still, it's not a deal breaker for me.
Anyone else have difficulty getting the iOS app to discover the television on their network?
I'm just trying to not notice it again. My V10 had the same thing but it seemed to get better over time.
deathrattlehead is offline
post #3332 of 10076 Old 06-03-2012, 11:13 AM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Originally Posted by mikediamond View Post
Does the TV have to be at eye level? I know the horizontal viewing angle is great on this TV , but what about the vertical?
Not exactly at eye level, but if your tv is above a fireplace and not tilted down or if the tv sits low and someone is viewing it from above (bar stool?) the image quality will change.
sheshechic is offline
post #3333 of 10076 Old 06-03-2012, 12:00 PM
broadwayblue's Avatar
Quoted: 17 Post(s)
Originally Posted by QuiGonJosh View Post
I ordered some used ones on Amazon Marketplace for $30-$35. Worked just fine and came with all of the materials. That's probably about as cheap as you'll fine them. You can buy these Samsung's that are compatible with Panny's for $18, but they're very cheap looking to me. The Panny glasses are very durable, yet not heavy or overly bulky. They're quite comfortable.
www.amazon.com/gp/product/B007K9P7H0/
Thanks. I'll check out the used ones.
broadwayblue is offline
post #3334 of 10076 Old 06-03-2012, 12:24 PM
Quoted: 16 Post(s)
Mine is at eye level. It's definitely the application of the filter. It's been an issue on every plasma I've owned to some degree except the Samsung E8000.
post #3335 of 10076 Old 06-03-2012, 01:18 PM
Iron Condor's Avatar
Some people do have issues with the AR filter (actually AR filters in general) so there is always the option of going with the UT series.
Iron Condor is offline
post #3336 of 10076 Old 06-03-2012, 02:25 PM
theben07's Avatar
http://youtube.com/results?q=tcp60st...?v=Xv6NgF_MhcA
My set is suffering from this. Don't watch hockey but still wondering is this the source or a real issue with the set?
theben07 is offline
post #3337 of 10076 Old 06-03-2012, 03:01 PM
Gibson lp's Avatar
I watch hockey and don't have this issue at all.
Gibson lp is offline
post #3338 of 10076 Old 06-03-2012, 03:22 PM
slinkyd's Avatar
Originally Posted by deathrattlehead View Post
Unfortunately it looks like the louvre filter adds vertical lines during panning shots, like the Kuro, only less blotchy and more like evenly spaced vertical faint lines. Took me days to see it, but now I can't not see it. It's the only negative on an otherwise outstanding set. I'm bummed though.
Nooooo! A day away from getting my set and I find out there are gonna be lines when I watch football?! Say it ain't so.
slinkyd is offline
post #3339 of 10076 Old 06-03-2012, 03:27 PM
Quoted: 16 Post(s)
You may not see it during football. Only certain conditions really bring it out. I can see it during the scrolling pattern sometimes.
post #3340 of 10076 Old 06-03-2012, 04:01 PM
mikediamond's Avatar
At a viewing distance of 10 feet, on the 60ST50, would elevating the center of the screen 2 feet higher than eye level (or, bottom of the screen 3' 4" from the ground) significantly affect picture quality?
mikediamond is offline
post #3341 of 10076 Old 06-03-2012, 04:20 PM
jonnythan's Avatar
Not as long as you tilt it down a little bit. The louvre filter on this TV severely limits vertical viewing angles.
jonnythan is offline
post #3342 of 10076 Old 06-03-2012, 04:42 PM
its on a stand, not wall mounted , so i cant really tilt it
post #3343 of 10076 Old 06-03-2012, 04:44 PM
jonnythan's Avatar
I think that would be problematic. The bottom of mine is 29" off the ground and when reclining in my recliner 10' away i can just barely see the effects of the louvre filter on the top. I'm going to put a couple of washer on the mount to let it tilt down a degree or two to eliminate it.
post #3344 of 10076 Old 06-03-2012, 04:45 PM
I think that would be problematic. The bottom of mine is about 30" off the ground and when reclining in my recliner 10' away i can just barely see the effects of the louvre filter on the top.
yeah, the top starts to dim, right?
post #3345 of 10076 Old 06-03-2012, 04:47 PM
jonnythan's Avatar
Yup.
post #3346 of 10076 Old 06-03-2012, 04:51 PM
Yup.
very few reviews mentioned the terrible vertical viewing angles this TV has. oh well.
if you were going to angle the stand, how would you do it?
post #3347 of 10076 Old 06-03-2012, 05:00 PM
jonnythan's Avatar
Personally, I don't think I would do that. Too much danger of it falling. Is it possible to mount to the wall? You can get a mount for about $20.
post #3348 of 10076 Old 06-03-2012, 05:03 PM
tlockhart's Avatar
i will be mounting this tv above my fireplace, with a pretty heavy forward tilt
fireplace mantle extends about 4 feet up, and the tv will be mounted 2 inches off -
think ill have issues with the filter?
tlockhart is offline
post #3349 of 10076 Old 06-03-2012, 06:21 PM
jwilock's Avatar
Can somebody please help me ... I've read a lot about the break in process for plasmas. I've read post after post after post of people using the process. But i've spent literally the last 30 minutes trying to find the slides everyone is talking about. Google sends me to post after post where people talk about them. I found only one post that was supposed to link to them but the link led to an empty page. Help!
jwilock is offline
post #3350 of 10076 Old 06-03-2012, 06:43 PM
chas51's Avatar
register at high def junkies website.
check out D-Nices's stuffunder reviews tab at the top of the page.
chas51 is offline
post #3351 of 10076 Old 06-03-2012, 07:02 PM - Thread Starter
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 497 Post(s)
Liked: 764
That's because people don't watch TV at extreme vertical angles so it's not an issue. The Louvre Filter acts kind of like window mini-blinds; it rejects ambient room light and overhead lighting so if you stand over the TV and look downward, the image is dark. But if you lay on the floor and look up at the TV at the same angle the image is nowhere near as dark as it was from above. This is to facilitate wall mounting where the TV will be above eye level yet the image still looks good up to a point. But from above, it's horrible but that's ok because Nobody looks DOWN at their TV in normal viewing.
You should go to a store and look downward at a ST50/GT50/VT50 at say a 45 degree angle, then stoop down and look upward at it from below at a 45 degree angle and you'll see how much different it looks from top vs bottom.
I would build a huge wedge-shaped shim to place beneath the base to lean the TV a bit forward (it can take a little forward tilt without becoming unstable - i've tried it) then i'd affix an "earthquake strap" to the back of the TV or the base just to be safe.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3352 of 10076 Old 06-03-2012, 07:07 PM
Quoted: 16 Post(s)
I still have time to exchange my set with Amazon. Wondering if there's a shot I could get a set with less DSE. Thing is, this set doesn't buzz at all....ever. Nervous a replacement will have the same issues or worse with possible buzz.
post #3353 of 10076 Old 06-03-2012, 07:51 PM
stuart81's Avatar
I thought the filter was really going to bother me, but the job it does of rejecting ambient light is awesome. In the past I would watch movies really passively in my room. I'd put something on and just walk around and periodically glance at it while I was doing something else. If I do that with this set the image appears darker while standing. A minor annoyance really, considering what a good job it does in bright situations. Fair trade off IMO.
things are going to get worse and worse and never get better again.
Kurt Vonnegut
stuart81 is offline
post #3354 of 10076 Old 06-03-2012, 07:53 PM
jonnythan's Avatar
The picture on this TV is genuinely extraordinary.
post #3355 of 10076 Old 06-03-2012, 07:54 PM
Barana2080's Avatar
Maybe they didn't mention it because its not an issue.
Barana2080 is offline
post #3356 of 10076 Old 06-03-2012, 08:56 PM
pwiss's Avatar
+1
I am using D-Nice's settings and they really work great on my set. Skin tones are SO good and every thing looks very accurate. I am particularly impressed with motion handling. I was watching one of the aerial shows on Smithsonian HD and the camera pans looked solid. Quality feeds from my Fios box and anything on Bluray result in serious eye candy.
pwiss is offline
post #3357 of 10076 Old 06-03-2012, 11:16 PM
jav1's Avatar
Quoted: 23 Post(s)
Has anyone gone from a vt/gt to an st? I have a 65 VT on order but after reading so many great reviews I'm begining to reconsider. One thing I'm particuliarly interested in is DSE. See more posts about that on the gt/vt fourm than here. Are you folks seeing any DSE? Also wondering if those few extra "benefits" of the VT (more shades of gradiation, ultra black panel) result in real word improved PQ.
jav1 is offline
post #3358 of 10076 Old 06-04-2012, 12:31 AM
Danny Victory's Avatar
What mode are you using? Because the video I see in your link only says he seen it in Standard mode with CATS off. Also that it does not happen in Custom mode. What mode is it affecting you on your set?
Danny Victory is offline
post #3359 of 10076 Old 06-04-2012, 08:20 AM
deadphish's Avatar
Does anyone happen to know what the last couple of software updates have done? After a few months of ownership I am continually impressed by this TV.
deadphish is offline
post #3360 of 10076 Old 06-04-2012, 08:43 AM
BiotypE's Avatar
Quoted: 18 Post(s)
I was wondering the same thing. I did notice that Netflix no longer flashes when upgrading or decreasing the stream quality. That may have been one correction. Before this update, the screen would go black for a split second when it was adjusting the image quality based off available bandwidth.
The more I watch this set the better it seems to me. The black levels on this set are INSANE!!!
BiotypE is offline
Panasonic Viera Tc P65st50 Plasma Tv , Panasonic , Displays , Plasma Hdtv , Panasonic Viera Tc P55st50 55 Inch Plasma Tv , Panasonic Viera Tc P50st50 Plasma Tv , Panasonic Viera Tc P60st50 Plasma Tv
