Official Panasonic ST50 Series Discussion Thread [No Street Price Talk] - Page 298 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #8911 of 10079 Old 02-16-2013, 10:48 AM
mrwho25's Avatar
on the receiver, the ARC slot says 'tv out' Is that the issue? I figured it wouldn't matter since it's an ARC port but maybe it does.. I really would like to avoid trying to move everything around to try and make it work, without having to buy longer hdmi cables. Do i need to use some 1.3 cables? I have a few, maybe that would work with the receiver better?
mrwho25 is offline
post #8912 of 10079 Old 02-16-2013, 10:48 AM
willieconway's Avatar
Quoted: 166 Post(s)
Liked: 156
Originally Posted by mrwho25 View Post
I didn't see any option in the receiver's menus for arc, jus HDMI pass through and control, both of which are on. I'm trying to get sound from the xbox and bluray player, which are connected to the tv's hdmi ports. And yes, i've double-checked a few times and the arc ports are connected from the TV to the receiver
I saw your post in another thread too. You need to make everything pass through the receiver, that's what it's there for. Connect the Xbox and the BD player to the receiver, and then the receiver to the TV. ARC is only for sound originating from the TV e.g. from the TV's tuner or from apps. A cable or satellite box should also go via the receiver.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D.
My Blu-Ray collection
willieconway is online now
post #8913 of 10079 Old 02-16-2013, 10:52 AM
mrwho25's Avatar
Right, I wasn't sure what thread would get responses faster tongue.gif I swear I've made it work this way before with a different TV, having everything go into the TV and then an ARC connecting to the receiver, but maybe I'm not remembering right. Thanks for the help!
mrwho25 is offline
post #8914 of 10079 Old 02-16-2013, 10:59 AM
Latinoheat's Avatar
Quoted: 1159 Post(s)
Liked: 963
So you have Xbox and bluray player hooked up to receiver hdmi than hdmi out to hdmi 2 input on tv? And tv says home theater speakers and hdmi setting on tv says digital? You should be getting sound.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, HTPC, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC,Klipsch Reference R-62II,Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #8915 of 10079 Old 02-16-2013, 11:02 AM
mrwho25's Avatar
no, i had them plugged into the TV's hdmi ports, then i used the hdmi 2 arc output to go to my receiver's arc hdmi port. Apparently I have to do it like you said, with everything going into the receiver isntead of the TV. But how can I do 3D on my blu ray and xbox? (or get an image at all, I've always routed stuff to the TV and then I think used a fiber optic cable for the audio) I don't think this receiver passes 3D through to the TV, and I just bought this thing before I got this new TV
mrwho25 is offline
post #8916 of 10079 Old 02-16-2013, 11:08 AM
Latinoheat's Avatar
Liked: 963
post #8917 of 10079 Old 02-16-2013, 11:18 AM
mrwho25's Avatar
well that's awesome, I didn't see anything displayed on the receiver or mentioned in the manual, but that's good to know, thanks
mrwho25 is offline
post #8918 of 10079 Old 02-16-2013, 11:24 AM
Bond 007's Avatar
Quoted: 2663 Post(s)
Liked: 2115
http://www.amazon.com/Sony-STRDH820-Channel-Receiver-Black/dp/B004QOA920/ref=sr_1_1?s=electronics&ie=UTF8&qid=1361042609&sr=1-1&keywords=sony+str+dh820
Licence to Kill
Bond 007 is offline
post #8919 of 10079 Old 02-16-2013, 11:34 AM
mrwho25's Avatar
Well I feel dumb... lol thanks. Alright, guess I'll start re-arranging things and should be able to get things working again. Thanks everyone
mrwho25 is offline
post #8920 of 10079 Old 02-16-2013, 12:57 PM
p3Orion's Avatar
Quoted: 13 Post(s)
Liked: 42
Alternatively, you could plug each component into the separate hdmi ports on the TV, like you had previously, and then run an optical cable from your receiver to the TV. Select TV (or whatever the default optical output setting on the receiver is) on the receiver to get sound from your speakers.
This is my setup because for some reason my Denon AVR-1712 shows a couple of rows of black pixels on the left side when I connect the components to the receiver and a single hdmi to the TV. Apparently the receiver needs a firmware upgrade to remedy this, but the 1712 doesn't have network connectivity so I would have to bring it to a service center.
p3Orion is offline
post #8921 of 10079 Old 02-16-2013, 01:40 PM
Bond 007's Avatar
Liked: 2115
Your 1712 will not update via usb?
Licence to Kill
Bond 007 is offline
post #8922 of 10079 Old 02-16-2013, 05:03 PM
dose's Avatar
Originally Posted by Bond 007 View Post
1) Dithering is not an issue more than any other tv.
2) There is no Dynamic Contrast setting that I know of.
3) Buzzing is no more an issue than with any other plasma.
4) You can hook up any type or brand of surround sound you want.
5) The st will not reflect significantly worse than any other tv in that spot. At that angle can you even see the reflection? Particularly in the green seat I wouldnt think that you could even see a reflection.
Thanks for the replies. I'm not sure if I can see a reflection at that angle as I've just moved house and that will be the layout smile.gif I imagined that there would be a slight reflection but I could be wrong.
As for the Dynamic Contrast, apparently the GT50 has this whilst in game mode and it can't be turned off, so I wondered if it was a feature on the ST50s too.
dose is offline
post #8923 of 10079 Old 02-16-2013, 05:05 PM
Bond 007's Avatar
Liked: 2115
The st does not have dynamic contrast.
Licence to Kill
Bond 007 is offline
post #8924 of 10079 Old 02-16-2013, 06:36 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
Are you using the receiver to upconvert HD cable content before it goes to the ST? If so does it improve PQ?
wattheF is offline
post #8925 of 10079 Old 02-17-2013, 03:51 PM
dose's Avatar
That's good to know, thanks for the reply.
dose is offline
post #8926 of 10079 Old 02-18-2013, 06:19 AM
sethmp's Avatar
Just a little update to my network wifi problem. I called panasonic to let them know that my tv will not recognize my wireless network(or any other network). We ran through a few options and manually entered alot of diifferent numbers, IP address, DNS, etc.. Nothing worked. I was told a tech would be calling me in 1-2 business days. So i'll wait and see. Hoping nothing is wrong with this set. It's been damn near perfect for me so far
sethmp is offline
post #8927 of 10079 Old 02-18-2013, 07:14 AM
CLEHD's Avatar
I am sure that you have tried this, but I am just relaying my experience. When I first got the ST (I mean the first day) it was having issues recognizing/finding my wireless network. I could have hard-wired it as the modem is right next to it, but that is a different story for a different day. Anyways, I unplugged it and tried again and it found it and connected right away. It has always been finicky, though. Even to this day it will "lose" the connection. But, all that I have to do is go through the find connection screen that pops up and it connects.
Best of luck in your attempts at a solution!
CLEHD is offline
post #8928 of 10079 Old 02-18-2013, 09:34 AM
sethmp's Avatar
unplug the tv or the modem/router? I unplugged the modem but that had no effect. I went to the find connection screen and it searches for it and again nothing. I'll just have to wait and see what panasonic's people can come up with.
sethmp is offline
post #8929 of 10079 Old 02-18-2013, 10:10 AM
CLEHD's Avatar
The TV. When I first got the TV it sat on the stand that my previous 42" sat on while I waited for the new stand to arrive. When I unplugged the TV to move it to the new stand and re-tried the wireless setup is when it connected.
CLEHD is offline
post #8930 of 10079 Old 02-19-2013, 02:34 PM
rich7sena's Avatar
I just got my ST50 open item for a fantastic price. I was wondering for break in (assuming this set hasn't been broken in already) if I can just watch it in cinema mode right out of the box, or should just use standard mode.
rich7sena is offline
post #8931 of 10079 Old 02-19-2013, 02:41 PM
chunon's Avatar
Quoted: 2508 Post(s)
Liked: 2234
Cinema should work with conservative settings, standard mode is horrible and will give you excessive dithering and low light output.
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #8932 of 10079 Old 02-19-2013, 04:23 PM
jjohns72's Avatar
Hi folks, i bought the 50" st50 last week at my local b&m store. hung it in my bedroom (replacing a very old lcd) and so far im wondering if i have a defective unit. i have no buzz or anything like that but the picture is just not very impressive to my eyes.
After first use i turned off the smoother effect which stopped the god aweful soap opera effect. Ive tried cnet and dnice settings and am still underwhelmed. the best description i can give is that its just a dull looking picture even with hd content. black is very black but it just doesnt seem to be a very clear or sharp image. Also noticed with the nba allstar pregame show a huge amount of pixelation with all the lighting affects and what appeared to be motion blur. reminded me of my old lcd. as a reference i have a 59" pnd8000 in my living room and love it so im no stranger to plasma.
Am i missing something here or do i just need to exchange it?
jjohns72 is offline
post #8933 of 10079 Old 02-19-2013, 04:50 PM
chunon's Avatar
Liked: 2234
Whats the resolution of your source ?
Sony 75XBR940E
chunon is offline
post #8934 of 10079 Old 02-19-2013, 04:57 PM
jjohns72's Avatar
1080i coming from directv dvr over hdmi
jjohns72 is offline
post #8935 of 10079 Old 02-19-2013, 05:01 PM
chunon's Avatar
Liked: 2234
You are using custom mode or cinema ?
Sony 75XBR940E
chunon is offline
post #8936 of 10079 Old 02-19-2013, 05:22 PM
HD-Master's Avatar
Quoted: 68 Post(s)
Liked: 151
Please list all of your picture settings.
HD-Master is online now
post #8937 of 10079 Old 02-19-2013, 06:24 PM
jjohns72's Avatar
Used custom with cnet settings and stock cinema.
jjohns72 is offline
post #8938 of 10079 Old 02-19-2013, 08:22 PM
p3Orion's Avatar
Quoted: 13 Post(s)
Liked: 42
I guess you don't have a blu-ray player? If you do watch a blu-ray movie and then compare that to satellite. I have a 55ST50 and blu-rays are amazing, but some HD satellite content is underwhelming. Too much compression going on. I watch a lot of soccer and while the close up images of the players look good, when the camera is farther back (most of the game) the picture quality is pretty bad.
Another possible factor is that the ST50 has a softer, more film-like image, which many people aren't used to and/or don't like.
p3Orion is offline
post #8939 of 10079 Old 02-20-2013, 07:41 AM
mlg33's Avatar
Hello,
Could you please tell me, for those who have 2012 Panasonic BD players (BDT500, ...) via VieraLink, which button on the TV remote makes the bluray Pop-up menu to appear on screen ?
I only use the TV remote while watching a movie, but I can't access this popup menu (nor the top menu) via a simple command on that remote.
Do I have to use the option button to go inside the BD player menu ?
Thank you.
mlg33 is offline
post #8940 of 10079 Old 02-20-2013, 01:27 PM
jk_bama's Avatar
Quoted: 21 Post(s)
I had two questions -
1) I have flatmounted the ST50 and therefore have connected all wires even though I am not using them now. I connected the optical out on tv.. is there a way to disable it thr menu. I see the red light glowing on the other end.
2) the picture quality is not as good as my lcd toshiba. I played some blu ray move from LG player at 1080 p and noticed uniformity issues. Am using 60 Hz .. tried 24 and that was bad. Dont know how to describe it.
Is there a way to check for PQ from some slides etc?
BTW went thr the 100 hour panel prep etc D- type.
jk_bama is offline
Panasonic Viera Tc P65st50 Plasma Tv , Panasonic , Displays , Plasma Hdtv , Panasonic Viera Tc P55st50 55 Inch Plasma Tv , Panasonic Viera Tc P50st50 Plasma Tv , Panasonic Viera Tc P60st50 Plasma Tv
