Official Panasonic ST50 Series Discussion Thread [No Street Price Talk] - Page 310 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
Old 03-28-2013, 06:38 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2046
Originally Posted by carminepesce View Post
Originally Posted by htwaits View Post
If you mix what you watch from different sources, you should be fine. smile.gif
Thanks so much htwaits!!!!
htwaits is online now
Old 03-28-2013, 08:06 PM
Chris5028's Avatar
Liked: 65
Just my 2 cents...
I have had the tv for two months and I have loved every minute of it!biggrin.gif
Thank you.
Chris5028 is offline
Old 03-28-2013, 08:29 PM
kasshern's Avatar
^^ +1 ... I love my 60ST50. Nothing but great picture. I don't regret one moment of my purchase. Watching TV is so much more enjoyable on the plasma.
kasshern is offline
Old 03-29-2013, 04:46 AM
Jammers10's Avatar
I'm thinking of pulling the trigger on a 60" Panasonic Plasma also. How far are you sitting from your TV? I'm just worried that it might be to big from the distance i am sitting from.
Jammers10 is offline
Old 03-29-2013, 06:47 AM
swizzchard's Avatar
Quoted: 22 Post(s)
How close is your MVP? Fwiw I got a 55 and sit 13 ft away and wish I had a 60...but I also have a wife that Sid the 60 would overtake the fireplace mantel.
Go big if you can and you aren't closer than 7 ft
swizzchard is offline
Old 03-29-2013, 08:56 AM
Jammers10's Avatar
I'm sitting about 8.10 feet away from the TV right now. Yeah man at 13 feet you could have easily gone to 70".
Old 03-29-2013, 09:12 AM
Cuda1169's Avatar
Quoted: 24 Post(s)
Liked: 73
I was sitting 8 feet from my 60ST50 and felt that was too close, even though THX recommendations were 7.8 feet. I now sit at 10 feet and this feels comfortable for me. It is very subjective as some prefer a closer sitting distance for a more immersive experience.
Cuda1169 is offline
Old 03-29-2013, 09:15 AM
walker17's Avatar
I Have a 65" st50 and sit aprox. 9 ft away, at times I wish for a larger set! Have had the tv for appros 10 mo. and am extremly pleased with it, no IR to speak of and definatly no buzzing, hope that helps for those that are concerned about long term use.
Walker 17
walker17 is offline
Old 03-29-2013, 11:25 AM
Jammers10's Avatar
Walker 17
Did it feel too big when you first got it? I know TV's shrink after having them for some time.
Old 03-29-2013, 11:46 AM
CheYC's Avatar
Quoted: 35 Post(s)
Liked: 56
I upgraded from a 50" to a 55" in December and remember feeling like it was so much bigger, now I wish I had a 65" lol.
CheYC is offline
Old 03-29-2013, 01:27 PM
kasshern's Avatar
I'm sitting 9 feet away and sometimes I feel I can go bigger. When I first got the TV, it felt small and I had to double check the size at the back of the TV just to make sure it's a 60"...LOL. Probably the only regret is not going bigger.
kasshern is offline
Old 03-29-2013, 04:29 PM
Jammers10's Avatar
Well i think i've made up my mind. Even if the 60" feels a bit big at first it will get smaller and i will regret it if i go any smaller. I don't have anything to gain going from 50" to 55".
Old 03-29-2013, 05:41 PM
Dierkdr's Avatar
Liked: 54
60ST50 - primary seating position is about 9 feet, straight on. Secondary seating (angle view) varies from 10 - 12, secondary straight-on seating is around 12 ft back.
9 feet is great for (most) blu-rays & HDDVDs - and marvelous for full-screen (16:9) material; that distance also works for better quality SDDVDs and some "HD TV" programming.
Wife finds 9 feet acceptable for nearly all viewing - I sometimes prefer the 12-foot distance for poorer quality material.
FWIW, we also have a 50" Pan, with primary seating about 10 ft straight on: SD DVDs and "HD TV" both tend to look Great on that panel!
An interesting observation: while the 60" panel has "grown smaller" when viewing Wide-screen material from our primary seats, full-screen programming still seems impressively Big, AND the 60" seems to look "Bigger" from across the room than from our normal seats!
Dierkdr is offline
Old 03-29-2013, 06:38 PM
Jammers10's Avatar
I sit close to 9 feet straight on.
Old 03-29-2013, 10:25 PM
rich7sena's Avatar
I've had my 55ST50 for a couple months now and I really like it, but there's an issue that has been bugging me.
When the TV displays full black or black bars, the entire left edge (about 1/8" from the bezel) from top to bottom seems to dither excessively. It's distracting because they rest of the screen would be so dark and this blemish runs the entire length of the left edge.
Has anyone else experienced this?
rich7sena is offline
Old 03-29-2013, 10:37 PM
JSpectre88's Avatar
Liked: 54
I have, easy fix. Just turn down your brightness a couple more notches.
JSpectre88 is offline
Old 03-29-2013, 10:49 PM
rich7sena's Avatar
Thanks so much.
Gotta love community.
Old 03-29-2013, 10:55 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2046
Thanks so much.
Old 03-30-2013, 01:00 PM
atc250r's Avatar
Originally Posted by chunon View Post
You bought this from an authorized Panny dealer ?
Yes, I did. Quite a large one infact, with their own service center too. That's where I am supposed to bring my TV to.
atc250r is offline
Old 03-31-2013, 09:00 PM
utee05's Avatar
Quoted: 32 Post(s)
I posted this in the buzzing thread but figured I would post here.
Hi All,
I have a 55ST50 that I got back in late July from BB. I broke in the tv using d-nice's slides and used his recommended settings. When I initially had the tv I did not hear any buzzing at all. Now recently about a week ago I started to hear buzzing. I hear it on lighter colored scenes as others have reported. I do not use the speakers from the TV. I use the speakers connected to my denon AVR. I have a HTPC hooked up to the AVR and then to the TV. No other connections. I have the TV wall mounted and can hear the buzzing from about 8ft away even with the speakers at a decent volume.
Should I just contact Panasonic to get a repair scheduled? I know most say warranties are not worth it but maybe I should've gotten the warranty through BB to save me the trouble and making it easier to get a replacement.
utee05 is offline
Old 03-31-2013, 09:03 PM
JSpectre88's Avatar
Liked: 54
Hi All,
Old 03-31-2013, 09:07 PM
utee05's Avatar
Quoted: 32 Post(s)
Already guess I'll be giving them a call tomorrow. What info do they require when calling for support? Do they require S/N cause I do not think I can get the info since the tv is wall mounted.
utee05 is offline
Old 03-31-2013, 09:12 PM
utee05's Avatar
Quoted: 32 Post(s)
Well just decided to update the software to the latest available. I know techs love to say 'Have you upgraded your software?' so to get that one out of the way might as well update and test it out.
utee05 is offline
Old 03-31-2013, 09:21 PM
Bond 007's Avatar
Quoted: 2387 Post(s)
Liked: 1918
+1
Licence to Kill
Bond 007 is online now
Old 03-31-2013, 09:22 PM
Bond 007's Avatar
Liked: 1918
The SN is on the side by the buttons. If you have not registered it I would do,it before you call. It only takes a couple of minutes. They will probably want to know where and when you bought it.
Licence to Kill
Old 03-31-2013, 11:32 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2046
If your S/N isn't on your BB receipt, then BB can probably get it for you from your invoice number.
Old 04-01-2013, 10:49 AM
utee05's Avatar
Quoted: 32 Post(s)
I'll be calling panny support later on today to schedule an on-site repair. BB did not have my S/N since I did not get extended warranty plan. Guess I'll need to take down the TV to get the info.
Will update on my repair.
utee05 is offline
Old 04-01-2013, 10:58 AM
Bond 007's Avatar
Liked: 1918
Its not on a sticker on the side with the buttons?
Licence to Kill
Old 04-01-2013, 11:12 AM
utee05's Avatar
Quoted: 32 Post(s)
Oh it is on the side? Hmm I thought it was on the back of the panel. Will give it look see.
utee05 is offline
Old 04-01-2013, 11:21 AM
Bond 007's Avatar
Liked: 1918
When you ask for advice you should read all the posts. Not just certain ones. I posted that last night. Have you registered the tv? Be aware that they may need to take the tv off the wall to service it anyway.
Licence to Kill
Panasonic Viera Tc P65st50 Plasma Tv , Panasonic , Displays , Plasma Hdtv , Panasonic Viera Tc P55st50 55 Inch Plasma Tv , Panasonic Viera Tc P50st50 Plasma Tv , Panasonic Viera Tc P60st50 Plasma Tv
