Official Panasonic ST50 Series Discussion Thread [No Street Price Talk] - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #181 of 10076 Old 03-14-2012, 01:04 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
Say what? Are you asking if full field white has been brightened because I don't know the definition of "crystal white"? If so, the answer is no.
BTW, white is defined as x.0327 y.3290 per HD (BT709) and SD (SMPTE-C) specifications.
Originally Posted by Spelbreker View Post
D-nice i need to know this. Did Panasonic fixed there brightness issues on white background which was dull, with the ST50. Does it looks more crystal now compared too Samsungs?
D-Nice is offline
post #182 of 10076 Old 03-14-2012, 01:12 PM
caiman's Avatar
Hey D-Nice, a followup to the FBr question. I guess I'd like to know what "rare" means. The main (possibly only) thing I'll use the set for is movies. No hockey, basketball, or other stuff with which people tend to experience the FBr more readily. Now I know this isn't a cut and dry issue so I don't expect a precise answer, but in your best estimation how often will I notice the fluctuations with typical movie watching? Thanks.
caiman is offline
post #183 of 10076 Old 03-14-2012, 01:17 PM
CrescentMoon's Avatar
D-Nice,
you mentioned that banding is still present on ST50. Is there any visible improvement or it's the same as in 2011? And posterisation / phosphor trailing?
CrescentMoon is offline
post #184 of 10076 Old 03-14-2012, 01:17 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
I don't know. Your eyes are not tied to my brain so I can't evaluate what your eyes can or cannot see I saw FBr on Sunday with source material sent via DirecTV. Zero FBr on the reference display (PRO-101FD) with the same material.
D-Nice is offline
post #185 of 10076 Old 03-14-2012, 01:17 PM
dtbreen76's Avatar
I know you are asking D-Nice, but thought I would chime in over this. I returned my S30 because I could not stand the FBr issue. I felt I was very sensitive to it and it would happen frequently. Like you, I am more concerned about movies (on blu ray player), and that is where I saw the FBr. I exchanged for an ST30, which Panasonic created a patch for. I have watched several movies on the ST30 at this point and I have yet to see any FBr. This means that their fix was a drastic improvement. I doubt they ignored the issue when they created the 2012 models I just don't want to see you steer clear of the excellent picture that I am enjoying over this huge FBr issue, which is actually no longer much of a concern at all.
dtbreen76 is offline
post #186 of 10076 Old 03-14-2012, 01:24 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
Posterization and color banding means the same thing to me. Since I do not have a 2011 available to use in the comparision, I really don't know how it truly compares to the 2011 line. If it has been reduced and I had to guess by how much, I would say 10-15%. I don't see phosphor lag on any PDP, so I cannot answer that part of your question.
At this point I think this should be classified as a "Panasonic trait" as it has been plaguing their displays for as long as I can remember.
Originally Posted by CrescentMoon View Post
D-Nice,
D-Nice is offline
post #187 of 10076 Old 03-14-2012, 01:34 PM
Spelbreker's Avatar
Spelbreker is offline
post #188 of 10076 Old 03-14-2012, 01:36 PM
Spelbreker's Avatar
Yes i actually mean the white colour on the screen is it more crisper. Does white looks white or is it still dull bith grey.
post #189 of 10076 Old 03-14-2012, 01:42 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
I need you or someone else to translate this post. What does "crisper" mean? Bluer white? Brighter white? A combination of both?
D-Nice is offline
post #190 of 10076 Old 03-14-2012, 01:45 PM
Spelbreker's Avatar
Brighter white whichs doesn't look dim or dark compared Samsung.
post #191 of 10076 Old 03-14-2012, 01:51 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
Brighter white whichs doesn't look dim.
On the ST50 I have, white measured 16.7fL on a 100% full field white pattern with a panel brightness of Mid. I have not measured High but I would not expect it to be that much brighter, if it actually is brighter on that paticular pattern. I have yet to measure a Samsung that does anything over 18fL on the same pattern.
D-Nice is offline
post #192 of 10076 Old 03-14-2012, 01:57 PM
maygit's Avatar
Again as hes stated, the dimness appearance is all settings based. Straight out of the box with little or no tweaking the 2011 samsungs were brighter in appearance compared to panasonics. Once properly calibrated, both 2011 brands had similar brightness in appearance. See HDTV Shootout for a better explanation. The 2012 panasonics resemble a similar out of box brightness to the 2011 samsungs out of the box but calibrate even higher, i believe, than what the 2011 brands were at.
maygit is offline
post #193 of 10076 Old 03-14-2012, 02:04 PM
hhaller's Avatar
Quoted: 72 Post(s)
Liked: 51
Hmm. I wonder how a similar-sized, calibrated ST50 would stack up against a calibrated VT30? De facto Day/Night modes (Custom/Cinema?) vs. ISF modes?
hhaller is offline
post #194 of 10076 Old 03-14-2012, 02:27 PM
johnblowcls's Avatar
D-nice the st50 Fbr can be reduced over time or via software update to zero?It's more hardware or software ?
johnblowcls is offline
post #195 of 10076 Old 03-14-2012, 02:40 PM
mjpearce023's Avatar
Quoted: 34 Post(s)
Liked: 38
Maybe someone should start a separate FBR tread so we don't have to fill this thread up with the same 5 FBR questions over and over again.
mjpearce023 is offline
post #196 of 10076 Old 03-14-2012, 02:44 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
Ask Panasonic
D-Nice is offline
post #197 of 10076 Old 03-14-2012, 02:58 PM
karlmalone1's Avatar
Perhaps you need to start questioning those who claim there was a "significant" difference in brightness by asking what settings were used in the comparision.
Obviously the brightness would be similar when calibrated for the same environment. My point was that the 2011 samsungs COULD get brighter if they needed to, depending on the environment, while the panasonics maxed out at a fairly low peak brightness.
karlmalone1 is offline
post #198 of 10076 Old 03-14-2012, 03:23 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
And you are STILL wrong! I will make this very simple....
The 2011 Samsungs were not brighter nor could they "get brighter" than the 2011 Panasonics.
D-Nice is offline
post #199 of 10076 Old 03-14-2012, 03:36 PM
par4's Avatar
I really don't find this post funny. I don't care about black levels yet I own 5 Kuros? I'm grouchy because I choose not to sugar coat posts and/or write paragraphs to respond to posts that simply can be answered with two/three letters (yes, no) or one straight to the point sentence? Yeah ok
D- I think ol' Boyd was just funnin' with ya'. His namesake on "Justified" is sorta the giveaway.
par4 is offline
post #200 of 10076 Old 03-14-2012, 04:08 PM
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
Ha, another common Myth/ Excuse/ Weakness of Plasma
You see that's WHITE - not Dark , or OFF yellow, or tanned tinted white , Panny Plasma's do a terrible TERRIBLE job of reproducing real White, I don't care what your Test kit says.
RicFlair is offline
post #201 of 10076 Old 03-14-2012, 04:19 PM
netvlada's Avatar
From what i can see from d-nice answers to us i can only conclude thet samsung plasma d8000 is better value for money then st50.
netvlada is offline
post #202 of 10076 Old 03-14-2012, 04:41 PM
apom's Avatar
Aesthetically how much better looking is the 50 over the 30?
apom is offline
post #203 of 10076 Old 03-14-2012, 04:46 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
I'm not sure how you came that conclusion since I never anything that could create such a conclusion.
D-Nice is offline
post #204 of 10076 Old 03-14-2012, 04:54 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
Excuse of plasma?
Anyone who knows spit about video will tell you white is defined as x.03127 y.3290. That white applies to EVERY SINGLE DESPLAY TECHNOLGY used to display BT709 and SMPTE-C color images. This is a video science forum. I suggest you LEARN the science of video before popping off an ignorant post. Then again, I expect nothing more than what you have done with a username of RicFlair
D-Nice is offline
post #205 of 10076 Old 03-14-2012, 05:03 PM
alxrmero's Avatar
Excuse of plasma?
Wow D-Nice is on a roll today. I've gotta admit it's been funny seeing D-Nice put these clowns who think they know about Plasma's to shame
alxrmero is offline
post #206 of 10076 Old 03-14-2012, 05:12 PM
r1dude57's Avatar
Didn't Cleveland plasma get a set in for review last friday? ChadB was on his way over for a calibration, and haven't heard anything since.
r1dude57 is offline
post #207 of 10076 Old 03-14-2012, 05:13 PM
rogo's Avatar
Quoted: 1590 Post(s)
Liked: 1790
I want to know how many people are sending you money.
That sounds like a good business!
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is offline
post #208 of 10076 Old 03-14-2012, 05:17 PM
rogo's Avatar
Liked: 1790
For you mathematically challenged folks, the difference between 18 and 16.7 is that the former (that's the big one) is 7.7% brighter. In other words, not much.
rogo is offline
post #209 of 10076 Old 03-14-2012, 05:27 PM
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
Excuse of plasma?
I don't care what the numbers say , Plasma white is NOT white - it's white with grey tint - every guy who knows spit about Plasma will tell you the same.
Panny Plasma, any make or model G25 etc, will bleed red onto a sheet of Hockey white ice - the screen tints red.
This is undeniable fact; in fact it's science.
RicFlair is offline
post #210 of 10076 Old 03-14-2012, 05:47 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
Perhaps they are taking their time? Nothing wrong with that.
D-Nice is offline
Panasonic Viera Tc P65st50 Plasma Tv , Panasonic , Displays , Plasma Hdtv , Panasonic Viera Tc P55st50 55 Inch Plasma Tv , Panasonic Viera Tc P50st50 Plasma Tv , Panasonic Viera Tc P60st50 Plasma Tv
