Why my st30 looks better than my vt30 ? - AVS Forum | Home Theater Discussions And Reviews
Old 03-05-2012, 02:02 AM - Thread Starter
Mrkingdavid23's Avatar
Using the same setting and everything on cinema mode my st30 had been in use around 9 months and my vt30 have around 250 hours the vt30 was manufactured in October .
Mrkingdavid23 is offline
Old 03-05-2012, 09:47 AM - Thread Starter
Old 03-05-2012, 10:06 AM
JMUdukes07's Avatar
Originally Posted by Mrkingdavid23 View Post
Probably because it sounds like you are using the same settings.
Settings differ from panel to panel between the same product lines. Considering these 2 sets are from different product lines you probably need to calibrate or at least play around with some settings on the VT.
Setting them to have the same exact settings won't work.
JMUdukes07 is offline
Old 03-05-2012, 05:33 PM
BillP's Avatar
Quoted: 258 Post(s)
Liked: 199
Use D-Nice's settings for each display.
BillP is offline
Old 03-05-2012, 09:38 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Also, as your panel ages it will actually get better in terms of picture quality.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
Old 03-05-2012, 10:53 PM
CSIG1001's Avatar
Liked: 25
Ian
yeah it seems my panel ST30 60" i am using dnice settings at Low panel brightness. I am getting used to a good calibrated picture . mid panel brightness is too high and not correct .. Seems like my tv is getting better , especially at night HD tv was looking really good. I probably got 500 hours on it now
CSIG1001 is offline
Old 03-06-2012, 12:51 AM - Thread Starter
thank you very much for all the help, where can i find d-nice setting for the vt30 thanks ?
Old 03-06-2012, 05:09 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Here's the link to D-Nice's settings thread. The first post is for the panel aging process. Post 4 through 7 is for the VT series, so pick your size and serial number prefix.
http://www.avsforum.com/avs-vb/showthread.php?t=1371710
whipit is offline
Old 03-14-2012, 12:37 AM - Thread Starter
thanks .
