Panasonic ST30 vs UT50? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-09-2012, 12:16 PM - Thread Starter
djmaniac's Avatar
Hello,
I recently just purchased a 42" ST30 as it was mentioned to be one of the best plasma TV's at that size. Today I saw the new 42" UT50 is going for about the same price as the ST30, so does anyone know how the new UT50 series compares with the ST30 series?
djmaniac is offline
post #2 of 6 Old 03-09-2012, 12:49 PM
mobilejunkie's Avatar
Ut is a new series that give super bottom shelf features but still 3D. It has 2 hdmi, no sort of "infinite black" panel, etc.
I just picked up a 55st30 to compliment my 50vt25 and I love it. Looks great and great on IR so far.
mobilejunkie is offline
post #3 of 6 Old 03-09-2012, 01:02 PM
sage11x's Avatar
Quoted: 1099 Post(s)
Liked: 1059
Unless the known issues of panasonic's 2011 panels bother you-- I'd stick with the ST30. Filter alone is worth it to stay with last years model.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #4 of 6 Old 03-14-2012, 07:00 PM
dean2's Avatar
i just bought the ut50 and i think it looks fantastic.
dean2 is offline
post #5 of 6 Old 03-14-2012, 11:34 PM
Iron Condor's Avatar
It's a brand new TV so nobody really knows how good it is. It'll probably end up being on par with the ST30 since there is no S line now and the ST50 went up a notch. The 42" is technically Panasonic's top 42" Plasma now, so who knows what level of panel is in there.
Iron Condor is offline
post #6 of 6 Old 03-19-2012, 10:00 PM
Bobbyh300's Avatar
May I ask what settings you are using? I just bought the same tv, and trying to find the best set up for it thanks !
Bobbyh300 is offline
