Official 2012 LG PM6700 Series Discussion Thread [No Street Price Talk] - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 349 Old 06-26-2013, 09:09 PM
wongkwp's Avatar
Exactly the same thing happened to me, I received mine last week and the screen was cracked upon opening the box.
wongkwp is offline
post #332 of 349 Old 06-27-2013, 05:51 AM
Jeimuzu's Avatar
Newegg?
Jeimuzu is offline
post #333 of 349 Old 06-28-2013, 12:00 AM
wongkwp's Avatar
Originally Posted by Jeimuzu View Post
Newegg?
Yes,,,,
wongkwp is offline
post #334 of 349 Old 06-28-2013, 05:18 AM
Jeimuzu's Avatar
Yes,,,,
Same here, received it a few days ago, should have heard the warning bells when the box was taped up and not in the usual hard plastic zip ties thing. I think they sent me an open box item or return as new. mad.gif
Jeimuzu is offline
post #335 of 349 Old 07-04-2013, 07:15 PM
The Timmy's Avatar
I got this set several months ago and am overall quite satisfied. I do have an issue with the 3D that I have not seen mentioned yet here and also have yet to find anything in my internet searches covering it (though not knowing what the issue is called, the correct search terms are anyone's guess).
the issue is as follows:
when watching 3D content, the display appears as if it is constantly adjusting much like the way a cameraman that can't decide what to focus on. the "double-image" will come together and spread apart at seemingly random intervals and durations.
this is not an issue with eye-strain, nor does it have anything to do with the glasses that I can tell-- you can see the set doing it without wearing the glasses where on the left and right edges of the screen, you can see vertical black bars going narrow and wide.
I haven't been able to tell if it is dependent on the amount of "action" showing on screen, or if it is completely random.
This issue occurs with seemingly any type of 3D I try to watch:
3D bluray discs (PS3 through HDMI to Onkyo [TX-NR616] receiver to TV), 2D to 3D conversion any source), side-by-side 3D (mostly from images and video played from PC via HDMI cables), content from the built-in "3D World"
I'm pretty sure the HDMI cables are the newest version and quite capable of 3D content.
has anybody else had this issue? this surly isn't normal.
The Timmy is offline
post #336 of 349 Old 07-09-2013, 10:01 PM
lotechnz's Avatar
I'm a 60PM6700 based in New Zealand, we're still stuck on the 04.04.03 and I'd like to mess with mirror cast which apparently works on the newer 05 firmware.
Has any one successfully installed the US firmware outside the US? I'd thought I should ask before jumping head first into trying it.
lotechnz is offline
post #337 of 349 Old 07-11-2013, 12:39 PM
rgandel's Avatar
I´m from Brazil and here my TV was updated with 5.XX but I didn´t find this option ...
rgandel is offline
post #338 of 349 Old 08-01-2013, 04:23 PM
Core Memory's Avatar
Have you tried installing the US firmware?
50PM6700
60PM6700
Core Memory is offline
post #339 of 349 Old 08-13-2013, 06:13 PM
jlo8720's Avatar
Quoted: 38 Post(s)
anyone have any idea what the last two FW updates brought? something related to streaming local media?
LG 60PM6700 (2012)
Uverse >>>Xbox One
Yamaha RX-677 w/ 5.1
Chromecast
Sony XBR-43X830C (2015) - Xbox One S, Android TV
jlo8720 is offline
post #340 of 349 Old 09-23-2013, 04:04 AM
disfigured's Avatar
Anyone experiencing a kind of horizontal blind effect at certain moments when the picture changes radically? I've only begun to notice it after the last FW update, although it could have existed before that.
The TV does really well in this area when it comes to the normal bleeds and other delays associated more with LCD/LED TVs. But at certain moments I'll get a horizontal set of lines for a split second. Sometimes contained with in the borders of a certain area, usually determined by movement not necessarily color. It's not completely screen wide. I can't screencap it either, upon replaying and advancing the picture frame by frame it doesn't appear. It happens most of on "Nothing but Trailers".
I never noticed it before until the last FW update. Could it be a setting? My Sat Feed (Direct TV)?
Thanks for any thoughts on the matter.
disfigured is offline
post #341 of 349 Old 12-05-2013, 11:43 PM
jlo8720's Avatar
Quoted: 38 Post(s)
Anyone use the wireless display feature on this TV. Its certified miracast (my lg nexus 5 is too) but my phone doesn't register or recognize the tv
Sent from my Nexus 5 using Tapatalk
LG 60PM6700 (2012)
Uverse >>>Xbox One
Chromecast
jlo8720 is offline
post #342 of 349 Old 01-15-2014, 11:38 AM
Neild's Avatar
Got a used 50PM6700 recently and noticed a strange effect. It seems to retain contrasting images from previous images. It doesn't seem to be a physical type of IR though, as the image retained doesn't matter if it was present for 3 seconds or 2 minutes.
For example if I use any menu functions, they are composed of grey boxes. If I then flip to a black screen, the faint border of the grey box can be seen. Higher contrast blu-ray menu text will retain also.
In case anyone is assuming, the TV is definitely not running in 'torch' mode. I calibrate in a dark room and I tend to prefer dimmer white than most people. Even on the built-in Picture Wizard I'm nowhere near white clipping.
Software version is 5.00.08
Previously noticed the same effect on LG PK550, but chalked that up to the PK550 being brand new, whereas the PM6700 has >3000 hours. I have some other plasma TV's (Panasonic, Samsung) that never show this effect.
Is this something that can be affected by the MLL tweak?
Neild is offline
post #343 of 349 Old 01-15-2014, 11:39 AM
Neild's Avatar
Seems to be a newer software version (5.03.03) available.
Any word on what it fixes (or breaks :-) )
Update: Can't seem to get a proper download of 5.03.03 from LG site, each one seems to be corrupt/incomplete (?)
Neild is offline
post #344 of 349 Old 01-15-2014, 02:06 PM
Moogy's Avatar
I have to admit, while the normal viewing of this TV seems great, I'm very disappointed with the 3D. I purchased the glasses specifically for this TV, turned on any post-processing through my receiver, and while it "works" it just doesn't look good. I can't put my finger on it; perhaps it's the nature of Active 3D, but I certainly don't like it much. Watching Avatar is more of a chore than it is a "cool 3D experience".
Moogy is offline
post #345 of 349 Old 01-16-2014, 06:11 PM
Neild's Avatar
Anybody able to get a clean download of this 5.03.03 firmware? Every time I try to download it, the result is truncated/corrupt.
The embedded file is dated Dec 16 and is called GP4_ATSC_BB_MP_PDP_mtk5369_A1_RevNo84710_V05.03.03_usb_V2_SECURED.epk
Neild is offline
post #346 of 349 Old 01-26-2014, 08:50 AM
van_halen's Avatar
Chad B,
Thanks for the review and I know this is an old topic, but is it possible for you to show all the video settings used after the calibration ?
Or anyone that have calibrated ,including this advanced color calibration can post your own settings?
Thanks in advance.
van_halen is offline
post #347 of 349 Old 02-03-2014, 09:40 AM
jlo8720's Avatar
Quoted: 38 Post(s)
Can you not connect via WiFi?
LG 60PM6700 (2012)
Uverse >>>Xbox One
Chromecast
jlo8720 is offline
post #348 of 349 Old 02-09-2014, 05:36 PM
jgriesel's Avatar
I also had problems trying to download by the System Update menu. LG finally posted the firmware update on the web, so I was able to do a download and USB update.
jgriesel is offline
post #349 of 349 Old 05-29-2014, 08:23 AM
blazinup n tx's Avatar
Originally Posted by Chad B View Post
I'm sorry, that's against my religion.
Actually, sharing advanced settings is very prone to error. There are some basic settings that do carry over fairly well from one set to the next, but once you get into the more important settings like the white balance it's pure luck if those settings get your set any closer to where it should be. Add to that the fact that a lot of these settings interact, so having the wrong white balance settings could throw off your brightness and contrast, and you can see why it can become quite a mess to put faith in someone else's settings even on the same model. You can download and burn the AVS 709 test disc for free and it will help you get the basic stuff right.
Can you provide a link to the download of the test disc please.
blazinup n tx is offline
Samsung , Plasma Hdtv , Displays , Panasonic , Lg 50pm6700 Plasma Hdtv , Lg 60pm6700 Plasma Hdtv
