Viera Connect not highlighting selected app on st30... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-10-2012, 05:34 PM - Thread Starter
danielalanscott's Avatar
Hi all, new here, although I have been lurking for a while and gleaning tons of useful information. Currently assembling a ghetto home theater (Panasonic P55st30, Onkyo 5400, Xbox 360 and Panasonic 320 Blu Ray.)
Anyways, I have been looking and haven't seen this issue anywhere else. I turned on Viera Connect today for the first time and none of the apps highlight when I try to select them. The only areas that light up are the up/down arrows labeled "More/Back." It makes it a total crapshoot to select an app as I have no real way of knowing where the cursor is.
I read through the manual, looked online, scoured the menus and finally called Panasonic. The tech had me reset the tv and try it again. No luck. Also, each time I turn off the tv, I have to unplug and reinsert the ethernet cable, as the tv says it can't find it otherwise.
Panasonic wants to send out a tech (the tv is less than 2 weeks old, 12/2012 build) but I was hoping someone here could help.
-dan-
danielalanscott is offline
post #2 of 5 Old 03-13-2012, 03:27 PM - Thread Starter
Bump
post #3 of 5 Old 04-17-2012, 06:57 PM
desbaratto's Avatar
I have the same issue on my tv - have you found anything?
desbaratto is offline
post #4 of 5 Old 04-17-2012, 07:08 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Did you search the ST30 thread?
sheshechic is offline
post #5 of 5 Old 09-11-2012, 09:56 AM
MSB1971's Avatar
Hi there. Does anyone have a clue what this issue is. I have exactly the same problem on a TXP42UT50B. I have spoken to Panasonic, reset to factory settings more times than I care to remember and am now on my third TV. All with the same issue.
Any help gratefully received!!!!
MSB1971 is offline
