Return Panasonic or use conceirge service? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-15-2012, 09:55 PM - Thread Starter
Ozzie Isaac's Avatar
Liked: 101
I received my 55ST30 today. Unfortunately it has a dead green subpixel. I bought it from Amazon. Should I return through them, not sure if they have anymore 55ST30's since they are no longer listed, or should I try Panasonic's conceirge service? The pixel is about 3 inches right of center.
Ozzie Isaac is offline
post #2 of 8 Old 03-15-2012, 10:13 PM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 895
I'd do whatever is easiest for you. I don't know anything about the concierge service but I would definitely call amazon and see what your options are. You definitely shouldn't pay anything out of pocket being a new tv.
ambesolman is offline
post #3 of 8 Old 03-15-2012, 10:23 PM
raehza's Avatar
Had a "flickering" pixel on my brand me Samsung Plasma. It went away after watching TV for a few mins/hours. Maybe yours will go away too.
Ray
Projector: AE7000
Screen: 5x12 Wilson Art Laminate Designer White
Receiver: Denon 2112Ci
Fronts: DefTech 8020ST
Center: DefTech 8040HD
Side Surround: DefTech SR 8040 BPs
Rear Surround: DefTech PM 1000s
Subwoofers: 2x HSU VTF 15H's
raehza is offline
post #4 of 8 Old 03-16-2012, 12:25 AM
emp99's Avatar
I would return it through amazon.
Much safer and easier.
emp99 is offline
post #5 of 8 Old 03-16-2012, 01:49 AM
Ace1965's Avatar
Return it.
Ace1965 is offline
post #6 of 8 Old 03-16-2012, 07:07 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Can you see the dead pixel from your normal viewing distance? If not, and if you don't want to spend more money on the new 55ST50, then i'd keep the TV (at least for now) if you're certain that Amazon does not have any replacement TV's left and hope that the pixel fixes itself in the next few weeks.
If you can see the dead pixel from your viewing position and it bothers you, your choices are (A) see if Panasonic will replace your defective panel under warranty (they usually will if it is ruining your viewing experience), or (B) return the TV to Amazon under your 30 day return policy.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7 of 8 Old 03-16-2012, 09:04 PM - Thread Starter
Liked: 101
Ok, i contacted Amazon and they will check if they have any stock available. If they don't and I return it should I go GT30 for 300 more, or st50 for 550 more? I am open to options, since I zeroed in on the ST30 and pretty much stopped looking 8 months ago, just waited for the right time.
I cannot go bigger than 55" .... No more wall space.
post #8 of 8 Old 03-17-2012, 10:16 AM - Thread Starter
Liked: 101
Amazon has no more 55ST30s available. I'm going to take Randy's advice and see how it does in the real world i.e. not sldes. For the price I don't think I will find a better tv, dead pixel or not.
