Official Samsung PNXXE7000 - PNXXE8000 owners thread - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #4321 of 4436 Old 08-08-2014, 06:46 AM
Quoted: 13 Post(s)
Liked: 32
Originally Posted by ruiz00tx View Post
I was just looking at the invoice. 2 main boards are listed, 1 power board, and 1 wifi module. The guy told me he didn't change the main board. I thought something was fishy. Should I call the repair company first, or samsung directly?
Didn't you see what he did? Is it working now? Does the picture/color look right or did they get screwed up?
You have 30 days on the repair to get them back if it's not fixed. I would not alienate the repair folks at this point in case you need a return visit. If it's working, he did replace the power board.
If it was me, I'd forget about it. No need to stress out about a process you won't change. Just be happy about getting the TV repaired out of warranty.
ferl is offline
post #4322 of 4436 Old 08-15-2014, 05:14 PM
cdub5's Avatar
So I called samsung since I've been having the tv not turning on issue. Unfortunately I didn't get the same results as others on this forum. I was escalated to ECR and although being calm and friendly my only options were to buy an extended warranty or they offered to have a service center call me to to give me an estimate of the cost for repair. I was persistent, stating that I own several samsung tv's, and that this tv is less than 2 years old, that it was expensive, and I find it unreasonable that I have to pay to fix such a "young" tv. She didn't budge. Very frustrated. Really considering attempting to fix myself, but if rather not.
cdub5 is offline
post #4323 of 4436 Old 08-18-2014, 12:00 AM
Liked: 0
I registered on this forum just to say that my PN60E7000 (bought in 2012) started acting up this week. It turns off randomly and can only be turned back on after unplugging it (at one point, I've had to unplug it thrice in a span of ~2 hours though) so even though the solution works, it's terribly inconvenient. It also makes me worry that the TV is on the verge of dying. It's even more worrying that other people have this problem, too, and that it seems very similar to the problems addressed by the class action settlement for Samsung's '06-'08 models.
I just wanted to thank you guys for the tips and be accounted for as another e7000 owner with the same problem.
doinee is offline
post #4324 of 4436 Old 08-18-2014, 03:07 PM
cdub5's Avatar
You could always try calling Samsung and see if you get better results than me.
cdub5 is offline
post #4325 of 4436 Old 08-23-2014, 10:56 PM
j0hnnyyyy's Avatar
I'm trying to connect my tv to the wireless internet but is only connecting by lan. Is there anyone that can help fix my issue.
j0hnnyyyy is offline
post #4326 of 4436 Old 08-30-2014, 07:49 AM
tylerSC's Avatar
Quoted: 576 Post(s)
Liked: 139
I am trying to set up the On TV menu in the Smart Hub with a Samsung 530 cable box. After I put in the zip code, it says install and pair the IR Blaster. Well, I must have misplaced that item. Do I need to order a specific Samsung IR Blaster, or is there a generic version that works on all devices? And what is a good inexpensive vendor that sells such an IR Blaster?
tylerSC is offline
post #4327 of 4436 Old 09-01-2014, 05:44 PM
tylerSC's Avatar
Quoted: 576 Post(s)
Liked: 139
After I connected the Samsung 530 cable box via HDMI, the E7000 TV has randomly started shutting off and turning back on again. Also, I changed from wired internet connection to wireless. So is it likely the WiFi causes this problem, or the HDMI? I did not have this problem when the TV was connected only to OTA antenna and direct wired ethernet cable. I see where this has been an issue.
tylerSC is offline
post #4328 of 4436 Old 09-02-2014, 07:52 AM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
AFAIK: The wi-fi problem only exhibits when you first power-on the TV. It won't randomly reboot the TV after watching for 15 minutes. I am unaware how an HDMI connection could cause this, but I suppose anything is possible.
ncted is offline
post #4329 of 4436 Old 09-05-2014, 01:02 PM
Malorum's Avatar
Liked: 0
Just wanted to reiterate this. Long time lurker here. I've had the exact same issue on my PN64E8000 for a week or so now. Unplugging it works for maybe a few minutes then it shuts off on its own. Prior to this all 3 HDMI ports stopped working. I called Samsung and unfortunately my TV is out of warranty even with the 3 month extension. They are sending a tech out in the next few days to diagnose it. I am not happy at all that i will have to pay out of pocket for what seems to be a recurring issue with a lot of owners. Hopefully i can get the ECR department to grant me a one time repair.
Malorum is offline
post #4330 of 4436 Old 09-12-2014, 10:22 AM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
Anyone know how to remove the wireless configuration on these sets? I had been using mine to watch Netflix and Amazon Instant, but I want to disconnect it after an ad popped up while I was watching regular TV after a recent firmware update. This was a pop-up ad while I was watching on the antenna input. It gave me the option to exit which I did, or press the select button (the one in the middle of the directional pad) for more information.
Clearly, the TV received this ad over the internet and displayed it based on what I was watching. I have blocked the TV from connecting to my wi-fi, but I would like to remove the configuration completely. Anyone know how to do this?
Ted
ncted is offline
post #4331 of 4436 Old 10-02-2014, 05:37 AM
opm22's Avatar
Liked: 0
Exclamation
Hello, I do own a Samsung Plasma TV model 64 E8000 and I'm trying to determine if it is has a bad panel or just a bad t-con board? I uploaded some pictures and I also tried to talk to the guys in lcdparts.net. Their symptoms page is great, but could not help in this case.
PS: image distortion is presented in all inputs and even in the OSD menu.
ID:	290881   Click image for larger version
ID:	290889   Click image for larger version
ID:	290897   Click image for larger version
opm22 is offline
post #4332 of 4436 Old 10-20-2014, 08:10 PM
btmower's Avatar
Quoted: 21 Post(s)
PN64E7000 here... same issue as others on the forum. About a month ago it started shutting off randomly. Sometimes I can unplug it and flush the power from the boards and it will work for a few hours. Other times, it won't come back on at all.
It was purchased in Nov 2012... so not quite 2 years old.
I followed the advice of some others on this forum and called the executive support line. My interaction when as follows:
1 - Call Executive support: "Sorry, we can't do anything"
2 - Transferred me to gen-pop tech support
3 - Gen-pop tech support: "Unplug it, do firmware update, sorry you need to buy a warranty"
4 - Transferred me to warranty sales
5 - Warranty sales: "Sorry, we don't offer extended warranties on plasmas"
6 - Me: "I'm mad, I demand to speak to a manager in executive support"
7 - Transferred to a different Executive support line
8 - Executive support: "Sorry, nothing we can do"
9 - Me: "Pretty please" (and lots of complaining)
10 - Executive support: "Ok, we'll do a one time repair for parts ONLY"
So I dropped my TV off at a local repair company. I will be responsible for labor only, parts should be fully covered. I do not know what they would do if it were something huge like a faulty panel. I also hope they test it extensively, because the issue is so intermittent.
I'll update this thread once I get my TV back. Fingers crossed!
btmower is online now
post #4333 of 4436 Old 10-25-2014, 07:42 PM
btmower's Avatar
Quoted: 21 Post(s)
So it ended up being the board I last suspected, the POWER SUPPLY BOARD... All the repair experience I have and many of the TV techs I spoke to ruled out the power supply due to the voltages being correct throughout the TV when it did work. I described the problem to several repair techs who all agreed that the power supply was probably fine, and that the main board/y-sus were the likely culprits.
The good news.... Samsung covered the parts
The bad news.... I had to pay for labor ($125)
FOR ANYONE HAVING THIS ISSUE: IF SAMSUNG WON'T COVER YOUR REPAIR, ORDER A REPLACEMENT POWER SUPPLY! EVEN IF YOU DON'T THINK THAT IS THE ISSUE!
They're only $50-60 online and very easy to replace... It goes against all logic that the issue was the power supply, but maybe you can save yourself some money and fix it yourself.
post #4334 of 4436 Old 10-25-2014, 10:47 PM
cdub5's Avatar
Figured I would share my story on this current subject.
After my pn60e7000 started having the power issues that many others on this forum have had, or honestly will eventually have, I decided to do some research. Part of that brought me back to this forum. Like the others, my t.v. all of sudden had trouble turning on. All I would get was a clicking noise, and my stand-by light flashing in intervals of 2. Only resolution was to unplug the power cord from the back of the television for a few minutes, and then the tv would turn on. Again, the same results as others were experiencing. After reading some of the helpful responses on this forum, I decided to contact Samsung support to try and get an out of warranty fix like others had. Unfortunately I wasn't able to convince the woman to grant me the one time fix. In hind sight I should've been more persistent
Eventually my tv would no longer turn on, no matter what I tried, and since I was getting no help from Samsung on this issue, I decided to take matters into my own hands. My research I mentioned earlier also led me to story after story of people with Samsung televisions having the exact same issue many of us were/are having. So many in fact, that a class action suit was filed against Samsung, which forced Samsung to offer out of warranty repairs for specific models. Unfortunately our model television was not one of the ones (according to Samsung) that had this issue. I think we all know the truth to that. I also found that there was an easy fix to this common problem. Replacing the bad capacitors on the Power Supply Board. So I went through with the DIY repair since Samsung refused to help me. Ended up not going well. Lets just say, it didn't fix the problem, and luckily didn't cause more damage to the tv.
I decided to give Samsung a call again to see if they could help me out. To my surprise, the rep this time issued me the one time out of warranty repair that I've seen others getting. I was really excited! Problem was after speaking with the local tv repair company, they told me they couldn't do the fix under Samsung's dime because I already tried fixing it, and changed parts. I was completely honest with the repair company, and I understand why they couldn't do it as a warranty repair due to the fact that I "modified" it myself. What frustrates me is that I would have never attempted this fix if Samsung would've admitted their fault, and helped me from the beginning. Oh well, you live and learn.
Repair guy came out, and did exactly what I thought. He replaced the entire Power Supply Board. He said with these newer models, you can't just replace the capacitors. Looks like Samsung went from using cheap capacitors in the past, to now just using cheap power supply boards. Way to go Samsung!
I did look online for a replacement power supply. Apparently the entire world is out of stock, because I couldn't find one anywhere. Everyone was "out of stock". All in all it ended up costing me about $350 to fix the issue. I guess that's better than buying a new tv, but still absolutely ridiculous considering this is an almost $2000 tv that is less than 2 years old!
If it makes anyone feel better, the tv repair guy said all tv's made today pretty much suck. It's just whether you get lucky or not.
If I can give any advice to anyone having this issue, just stay persistent with Samsung in regards to them fixing this issue for you. If you get denied, just keep calling until you get a rep nice enough to help. You do need to speak with their ECR (Executive Customer Relations) dept. I believe it's called.
Maybe we should start our own class action suit against Samsung.
Hope this might help someone.
cdub5 is offline
post #4335 of 4436 Old 10-26-2014, 06:09 AM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
After hearing all of these repair experiences, I am kind of glad I got the Best Buy 4 year extended warranty, although I am uncertain what they would replace my set with if they cannot get replacement parts.
ncted is offline
post #4336 of 4436 Old 10-26-2014, 09:38 AM
cdub5's Avatar
ncted. The repair companies have access to parts direct from Samsung so don't worry about part availability if you have a warranty. Unfortunately Samsung won't sell these parts to the general public. At least i don't believe they do.
cdub5 is offline
post #4337 of 4436 Old 10-26-2014, 02:01 PM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
True, although Samsung isn't making new parts to use in new Plasmas, so I don't know how much actual supply is out there to fix my set should it break. It is nice to know I am covered either way.
ncted is offline
post #4338 of 4436 Old 10-26-2014, 05:45 PM
btmower's Avatar
Quoted: 21 Post(s)
I ordered a factory refurb main board and y-main from best buy parts store. They shipped me the y-main and then a week later told me the main board I ordered was no longer available. They did have a new one in stock, but it was $380.
They did have an alternate power supply board available. This is not the original part, but a different board made by a different company and it was only $50. I did not order it because I thought it was main/y-sustain related.
One interesting side note: When I talked to the Executive support line, the guy put me on hold when I mentioned that there are "dozens/hundreds of other TV's doing the same thing" He came back a few minutes later and said that they have no record of this TV having issues. That my model isn't included in the list of TV's having trouble. However, he then offered to do a one time fix and cover the parts. So... I suspect the issues with this model is creeping onto their radar. Obviously we all know it is a major issue.
I don't think this thread is going to end anytime soon... hopefully those who come later will see all these issues and have better results.
post #4339 of 4436 Old 11-18-2014, 09:46 AM
ephophex's Avatar
OK, AVS Forum folk, I'd like to solicit some opinions/facts on parts availability.
My Panny G25 is fantastic, but at 50", it's a bit small for my viewing distance and lousy eyesight. So when I saw a new PN64E8000 for an apparently insane price ($1000 less than the PN64F8500 I had been eyeing), I jumped on it. I figured it was my last chance to get a killer plasma for reasonable money, with the intent to keep it several years. I'm not a frequent upgrader.
This was with full knowledge of the problems listed here, and the tepid Amazon reviews (where most of the complaints seem to be related to buzzing and power problems). At the moment, it is in my living room happily looping movies on VLC until Friday. So far, so good - if I get *really* close, I can hear buzzing; but nothing I'd consider annoying or even particularly noticeable.
The prospect of two year power problems concerns me. Especially considering this is a 2012 model, what are the odds that replacement parts will actually be available for it in, say, 2017/2018 (I'm a relatively light user, so it might take longer than average if it happens at all)? Anyone have experience getting parts for several-year-old Samsungs?
ephophex is offline
post #4340 of 4436 Old 11-29-2014, 07:51 AM
Opinionated's Avatar
Would anyone know is the 60D7000 is compatible with the Screen Mirroring function of the Samsung Galaxy Tab 4? That is, be able to view and hear (wireless) what appears on the tablet's screen?
Samsung specifically writes that 2013 model TV's are compatible, but I can't find anything about the earlier models.
Opinionated is offline
post #4341 of 4436 Old 11-29-2014, 08:21 AM
zoyd's Avatar
Quoted: 1233 Post(s)
Liked: 980
zoyd is offline
post #4342 of 4436 Old 11-29-2014, 09:32 AM
Originally Posted by zoyd View Post
no, d-series does not support screen mirroring.
Thanks, but I mistyped, I meant the E7000 which I assume is considered a 2012 model as it was purchased in Sep 2012. Does the E support screen mirroring?
On another issue, I have not been here for quite a while and was just reading the unfortunate on/off trouble being experienced by some owners of the E8000. I don't see any E7000 owners complaining of the same issue, are the E7000 also affected?
Edit: I figured out that what was called allshare is now screen mirroring, so it should work with the tablet I will buy.
I'm still interested in an answer to my second question.
ferl likes this.
post #4343 of 4436 Old 11-30-2014, 02:42 PM
Liked: 0
After only 20 months might be my panel? Can you guys help
I have the PN51E7000FFXZA and purchased it in 03/13 thinking I was buying a Samsung which would mean that I would have a TV for many years to come. Well turned it on the other day and now I have a vertical line going through the picture that is colored (depending on what is on the screen). From what I can tell online it's either the logic board or the panel (I've been trying to figure it out cause I could actually do the repairs myself if I could get the part). The more I research the more it seems it is the panel which would mean I may as well get a new TV. Well seeing as how I'm now disabled I won't be able to buy one so I basically have a big ol brick.
The person I spoke to at Samsung basically told me "too bad" and offered to have a tech come out to repair it but I would have to pay for everything. I mean judging from what I read these TVs all seem to go out right after the warranty period. You can't even buy this panel anymore since Samsung requires you use a substitute panel when replacing this one which tells me they know they made a faulty panel but aren't going to own up to it. I've attached pictures, has anyone else had this problem. What's the best way to handle Samsung?
ID:	394017   Click image for larger version
AwesomeSauce80 is offline
post #4344 of 4436 Old 12-14-2014, 10:05 AM
Mr.Sneis's Avatar
Anyone have a link where these power supplies can be purchased? A part number?
Mr.Sneis is offline
post #4345 of 4436 Old 12-20-2014, 03:26 PM
cerchiarax's Avatar
I started having the same problem other people in the thread have reported where my samsung plasma E7000 would randomly shutdown. I spoke with Samsung over the phone and they recommended I upgrade to the latest firmware, which seem weird to do since I had already got the latest firmware at the time and already had a evolution kit plugged in. So I went with what they wanted me to do and I removed the evo kit and there was infact a later version of firmware 1056. After that finished I put the evo kit again and after a few minutes the tv started shutting down again after every few minutes. I called back and spoke to Executive support as someone suggested in this thread and eventhough my warranty is expired Samsung is going to send a technician to fix the tv for free. My question now is the evo kit the culprit? Because right now since I couldn't get the the tv to stop shutting down since it was doing it more constantly I took out the Evo kit completely and now it doesn't seem to be shutting down. I assume the technician will actually do a diagnostic and not just change parts he thinks might be broken. Time will tell I guess... but anyone else that is having the tv shutdown randomly using the Evo kit?
cerchiarax is offline
post #4346 of 4436 Old 01-05-2015, 03:17 PM
toucansma's Avatar
I upgraded my PN60E7000 to the 1056 firmware recently. After that upgrade it seems to ask everyday for an update to the SmartHub software. I let the update occur and follow the directions, and it seems to keep asking everyday. Also Netflix now seems to take forever or stall out on videos (which is doesn't on other media devices on the same network). I tried searching the forums and do not see anyone else with the same issue for this set maybe I missed a post). Seeing if anyone else has had this experience and any suggestions. Thanks!
toucansma is offline
post #4347 of 4436 Old 03-03-2015, 08:46 AM
Liked: 0
i've had my pn60e7000 for a little over 2 years and have thoroughly enjoyed it up to this point. unfortunately, the TV is now dead. no standby light, no nothing. i've searched through the threads within this forum but it seems most people don't experience a completely dead TV (i.e. - no standby light) but rather a "flashing" light and / or clicking and power cycling.
it started when the TV shut off randomly and the standby light began blinking. i unpluged the TV and it came back on. a couple of minutes later the TV shut off again but this time, no standby light no nothing. i attempted to unplug / reset the TV but still can't get any power to it. after researching the issue, i've done the following:
i looked at the power supply board but didn't see any obvious issues so i ordered a complete replacement from tvparts4less.
i received the new board yesterday and installed it. after the install, i was able to power the TV on. i then unplugged the TV and put everything back together. i powered the TV on once again and began pushing the furniture back in place. once i looked back up at the TV it had shut off again and now I'm having the same issue (dead TV, no standby light, no power).
this leaves me with a few questions:
1. is the new power supply board bad now as well?
2. is there another component ruining the power supply board? if so, is there another common failure component that I can attempt to replace?
3. does anyone have any advice after reading through my issue?
any advice / suggestions would be greatly appreciated!
oby_1 is offline
post #4348 of 4436 Old 03-03-2015, 10:35 AM
Liked: 0
as an update to the post above, tvparts4less has said they will replace the new power supply board that they sent. however, i don't want to plug in another new power supply board until i figure out what is shorting them.
oby_1 is offline
post #4349 of 4436 Old 03-11-2015, 04:23 PM
ChuckZ's Avatar
I'm using firmware 1057 and my television has been freezing up in the SmartHub or just randomly shutting off and on a lot recently. This television has never had as many issues as it is having right now before.
Has this firmware screwed up anyone else's television?
ChuckZ is offline
post #4350 of 4436 Old 03-18-2015, 07:51 AM
dmercer3's Avatar
Quoted: 657 Post(s)
Liked: 357
not to be that guy, but make sure you are checking the simple stuff like the outlet you are plugging the tv into and the powerstrip, battery backup, circuit breaker. Just make sure you are getting clean energy to the tv first... then diagnose the TV.
Just want to make sure you dont forget about the little things.
dmercer3 is online now
Samsung Pn60e6500 60 Inch 1080p 600 Hz 3d Slim Plasma Hdtv , Plasma Hdtv , Samsung , Samsung Un65es8000 Led Hdtv
taboola here
