Official Samsung PNXXE7000 - PNXXE8000 owners thread - Page 149 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #4441 of 4447 Old 09-14-2016, 10:26 AM
Ranger519v's Avatar
Shuts off after 5-10 minutes - power supply or main control board?
I've spent hours reading through this thread but cannot clearly discern whether I need a power supply or a main control board for my PN60E8000.
Upon good power on, unit will shut off anywhere from 5 minutes to hours later. Front lower left red led flashes in the following cycle:
short (a quick flash), medium (maybe 1 second), short, medium, short, medium, short, medium, short, long (4 seconds)
... repeat ...
I then unplug it, wait, replug and turn it back on. Works fine for 5 minutes to hours and then shuts down again.
I don't know how many are still following this thread but can anyone tell me whether I need a new power supply or main board (which is much more expensive)? I'd like to believe the LED cycle above would tell us something but I couldn't find anyone referencing the flash code it is giving.
Ranger519v is offline
post #4442 of 4447 Old 10-01-2016, 08:27 PM
Liked: 0
... repeat ...
I have the exact same issue with my pn60e70000, i'm trying to troubleshoot it. It randomly turns off and standby starts blinking. If I unplug it for a little while, it will come back on.
I had a previous issue last year where the power supply was dead with no standby, but I got lucky by resoldering the transitors near the center of the board and it came back to life. I tried resoldering a bunch of them again this time but no luck.
At one point, it seemed that I could tap on the panasonic relay near the ac input and get things working again. I ordered a new relay from mouser thinking that was the issue. After installing it, it worked for a little while but still started cutting off again. I did notice the new relay is much quieter than the old one so maybe it helped, maybe not. I also updated to the 1060 firmware but that didn't much either.
Anyhow, I found the service manual on samsung parts dot com for $12 plus shipping so i have that on order. I borrowed a good dmm so I'll I'll start probing around for bad components. It seems capacitors and mosfets are common suspects so I'll probably order some and give it a shot. I'm not sure if I'm dealing with a power supply or main board issue so i'm hesitant to order a new board kust yet. Plus, if I can figure out which component to replace to repair it for just a few bucks, I'd much rather do that than shell out several hundred for a new board or repair service. Any advice would be helpful.
m3amigos is offline
post #4443 of 4447 Old 10-02-2016, 06:51 AM
bustamelon's Avatar
Quoted: 17 Post(s)
FWIW, I had the same problem. Replaced the power board, no change. But disabling network seemed to solve it after the fact. I also have issues with flashing, where blacks flicker to grey. Haven't pinned this down to the TV as it doesn't happen in menus.
Sent from my SAMSUNG-SM-N910A using Tapatalk
bustamelon is online now
post #4444 of 4447 Old 10-04-2016, 02:29 PM
boondongle's Avatar
Quoted: 12 Post(s)
I've got a PN51E7000 that I purchased about 4 years ago. The display gets purple banding and splotches when the screen is bright. For example while watching Hockey or Hoth scenes from Empire Strikes Back.
Ended up buying a new Sony (this is my first and likely last Samsung) but wondering if anyone has a recommendation on what to do with this thing. New Panels are about $700. I've heard on older Samsung Plasmas the VS pots could be adjusted for voltage and may just open it up and give it a try....
I'd sell it on Craigslist but even working Plasmas aren't going for that much.
It doesn't do any of the power off stuff. It did it a couple times within the first year so I had the main board replaced as a precaution. I don't have need for it in any other rooms. It's covered up and just sitting in the garage for now.
But, it gave me an excuse to bump up to a sweet 65" 4K TV - and my wife didn't even seem to mind.
boondongle is offline
post #4445 of 4447 Old 10-05-2016, 07:13 AM
bustamelon's Avatar
Quoted: 17 Post(s)
HDMI Cable swap seems to have fixed my flashing issue. FYI
post #4446 of 4447 Old 07-05-2017, 08:54 AM
cerchiarax's Avatar
Quoted: 42 Post(s)
After a year of having the broken plasma in the garage, as I refused to throw it away even if the wife insisted its garbage. Last week I decided to open her up and do the the power supply repair as I saw the black burn mark. Sent the board to Otex Inc, as many in this thread have suggested, within the same week after shipping the old board they sent me the board all fixed up (crazy fast turnaround time). I wonder what they replaced besides just re-soldering... One would hope they may have changed the capacitors or something stronger from hopefully not reoccurring again. But long story short, TV is back to life. Thanks guys!
On another note, any of you guys using the SEK-1000 evolution kit? I'm debating if I put it back on or not. I did like having it on, just afraid that it may have caused the power supply getting fried. But I assume most people who had there power supply replaced, did not have the SEK-1000. At least hopefully...
cerchiarax is offline
post #4447 of 4447 Old 07-15-2017, 09:03 AM
dmercer3's Avatar
Quoted: 725 Post(s)
Liked: 401
... repeat ...
its almost 99% the main board, even if the burnt mark indicates a bad power supply the main board almost always still is the primary culprit.
The fix, they seriously just jumper an unused circuit. I almost did mine myself but the core refund via sears enabled me to get a new mainboard for about $30 ... this plasma is still more reliable than my 78" js9500 which retailed for $10,000.00+
End of the day, samsung is not focused on making reliable TV's anymore (and judging by the recent shootout they dont even care about performance).
Video: 78JS9500(MAIN) / 60E8000 Plasma [Previously:58c8000/75hu8550/78ju7500] BD Player: Samsung K8500
Audio: Marantz 7010 / SVS PB-13 Ultra / Klipsch RF-7ii RC-64ii Polk M70's IC-5800 (5.1.4)
dmercer3 is offline
Samsung Pn60e6500 60 Inch 1080p 600 Hz 3d Slim Plasma Hdtv , Plasma Hdtv , Samsung , Samsung Un65es8000 Led Hdtv
