Need Advice On A New Plasma TV - AVS Forum
post #1 of 10 Old 03-19-2012, 05:57 PM - Thread Starter
theaf1don's Avatar
I have an older 42" 720p Panasonic plasma tv that I want to replace for my apartment. I'm thinking of getting newer 60". I'm looking to spend around $1k-1.5k. I really don't care about any apps or wifi or anything since I already have an Apple TV that handles all that. I'm going with plasma because all my tvs have been plasma and the every time I buy an LCD, I feel like the blacks aren't dark enough and the picture isn't as vibrant. Any ideas?
theaf1don is offline
post #2 of 10 Old 03-19-2012, 06:00 PM - Thread Starter
theaf1don's Avatar
Oh ya I forgot, I don't like 3D so I'd rather not pay for that.
post #3 of 10 Old 03-19-2012, 06:15 PM
BillP's Avatar
Liked: 37
I'd go Panasonic ST30 (2011 model) or ST50 (2012 model). Unfortunately, the best 2D displays also throw in 3D (you sacrifice 2D PQ if you go with a 2D-only plasma).
BillP is offline
post #4 of 10 Old 03-19-2012, 08:42 PM
mailiang's Avatar
Quoted: 91 Post(s)
Liked: 292
I respectfully disagree. If you don't need 3D and can find a 2D S30, you may save a few bucks. According to what I've seen on display, Scott Wilkinson's review at HT.com:http://www.hometheater.com/content/p...30-plasma-hdtv, along with the fact it shares the same panel and post processor, the S30 offers almost identical 2D performance when compared to the ST. As far as the 2012 models are concerned, the UT series is replacing the S, and although similar, they now have eliminated the AR filter. If light reflections are an issue for you, then by all means take a closer look at the ST50 instead.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #5 of 10 Old 03-20-2012, 04:42 PM - Thread Starter
theaf1don's Avatar
Ian
So I can get a used buy good condition P60S30 for $1k, or I can get a new P65ST30 for $1.7k. What do you think?
post #6 of 10 Old 03-20-2012, 05:43 PM
BBC60's Avatar
65ST30 for $1.7k
I got the 60ST30 and am very happy.
BBC60 is offline
post #7 of 10 Old 03-20-2012, 09:21 PM
mailiang's Avatar
Quoted: 91 Post(s)
Liked: 292
If you shop around, you should be able to find a new P60S30 for under $1.5, including shipping, on-line. Regardless which one you chose, make sure they are sold by an authorized dealer.
Ian
mailiang is offline
post #8 of 10 Old 03-20-2012, 10:25 PM
Techgurl's Avatar
If you don't care to drop in size then you can snatch the 55st50 for around your budget. Normally, I wouldn't recommend a new model especially considering that I bought a Panasonic plasma for the last 3 years an S1, S2, and the ST30 and the picture quality was minimal between the 3. (S2 and 2010 models have floating blacks, and this flaw I feel can be spotted by even the average viewer, therefore, I strongly recommend staying away from them.)
Now back to the point, I going to recommend the ST50 blindly because the hype seems really good from ISF calibrators D-nice and Chadb, not just some internet jargon article trying to make a sell. These guys are pretty good at telling it how it really is. D-nice quoting the ST50 as a beast and so forth. I'm not even going to mention black levels but supposely color accurary got a pretty good makeover and these sets are a quite a bit brighter. My st30 (2011) is a little on the dim side unless i run uncalibrated settings. I hope this helps.
Techgurl is offline
post #9 of 10 Old 03-20-2012, 10:59 PM - Thread Starter
theaf1don's Avatar
Just saw your reply guys. I ended up ordering the 65ST30 for $1,700 from Amazon. I hope its a decent panel for the price?
post #10 of 10 Old 03-21-2012, 01:26 PM - Thread Starter
theaf1don's Avatar
User Tag List
