The OFFICIAL SAMSUNG PNXXE6500 OWNERS THREAD - Page 15 - AVS Forum | Home Theater Discussions And Reviews
post #421 of 429 Old 03-16-2013, 06:04 PM
savage97's Avatar
Can anyone that has this set help me out? I just purchased a new 60" F5300 the picture quality is good but the reflections I'm getting on it are terrible. I wouldn't say that I have a real bright room but I do have two windows across the room from the tv. Watching it today even with the blinds and curtains closed I could still see reflections of them in the tv and it made it tough to watch anything. Many nights my wife will also read a book with a lamp on also. I'm not sure if it's because this tv doesn't have a filter or if it's because it just can't get bright enough during the day but either way the reflections are a deal breaker. So my question is would a E6500 handle my situation better or would I be better off going to an LED?
savage97 is offline
post #422 of 429 Old 03-16-2013, 07:19 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
The E7000 had a decent filter, but not sure about E6500. The 530 and 550 series are very reflective, but I prefer the glossy look if you can control glare. Unfortunately, the entry level models from all manufacturers are reflective. So you may have to step up to a Panasonic ST60, and I am not sure if the 5500 from Samsung this year will add a better filter. Some LEDs are also very glossy, whereas others are semi-matte. You will have to look carefully since apparently glare is an issue for you. I believe the Samsung ES6000 LED is semi-matte, whereas higher end models may be ultra clear glossy.
tylerSC is offline
post #423 of 429 Old 03-25-2013, 01:13 AM
General PattOwn's Avatar
The 6500 definitely does a better job at reducing reflections. The only time I can see a light is when it's reflected right towards me, and even then it isn't too bad. After reading reviews from people who bought anything under a 6500 I couldn't do it. Reflection is a huge dealbreaker, even with me having it in a dark room
General PattOwn is offline
post #424 of 429 Old 03-27-2013, 08:26 AM
K1NeT1C USMC's Avatar
Just bought a new 51" e6500. Love it! Better then my LED D7000 tv. Led have uniformity issues in terms of levels so I'm happy with my purchase. I Have a little buzzing but that's normal with plasmas. Any hints on settig gamma though? Not sure how to set without having a fancy spyder calibrater?
K1NeT1C USMC is offline
post #425 of 429 Old 04-28-2013, 03:51 PM
Leeboy's Avatar
Hey gang, I just got a ipad, can I Bluetooth music from my ipad to the tv? I know it has Bluetooth keyboard, but I don't see it anyplace to search for Bluetooth devices?
Leeboy is offline
post #426 of 429 Old 05-03-2013, 05:12 PM
bxm83's Avatar
Try a DLNA enabled app. It should pop up. I like iMediaShare. It works pretty well and will make it easy to stream youtube and other videos to your TV.
Leeboy likes this.
bxm83 is offline
post #427 of 429 Old 11-19-2014, 09:46 AM
Liked: 0
YouTube synchronization problems
I've had my e6500 60" for 2 years now and it's a phenomenal set - no complaints what soever... beautiful picture - great smart hub and true value among sets without sacrificing any picture quality...
we watch a lot of YouTube through the app in smarthub and notice that the videos start to play ok but after 2-3 minutes the sound stops and then the video playback stops while the sound catches up and vice versa - i.e. the video plays without sound and then stops and then sound comes on until video playback and sound 're-sync' and then the all is well for 1-2 minutes and then the same thing happens...
I initially thought this was a signal strength issue via Wi-Fi and I ended up connecting a hard ethernet cable directly from TV to router and this problem is still happening so I know it's not the network.
any ideas as to how fix this problem or why it's happening?
thx
trucker911 is offline
post #428 of 429 Old 01-16-2015, 03:35 PM
Vlad_Dracule's Avatar
Dont know if this is the best spot for this... I have a PN51E6500 and the online update only gets me to ver 2002. On the site it shows they are at 2003.1 http://www.samsung.com/ca/support/model/PN51E6500EFXZC
I tried updating using a USB key but it just never finds any update files. My only thought is that the folder name has "US" in it.... does Canada get a different upgrade?
EDIT: Correction.. the version on the site is 2001.3 so mine is actually newer I think... I think I'm getting dyslexic in my old age...
EDIT #2 : Just in case anyone is wondering for some reason neither of my consoles will pass Dolby Digital through the TV (HDMI to the TV and then optical from TV to AV Receiver). For some reason my PVR (Motorola VIP) does no problem though... its infuriating.
Vlad_Dracule is offline
post #429 of 429 Old 02-10-2015, 01:25 AM
DeputyMoniker's Avatar
Anybody know if this model will handle 240p over component?
DeputyMoniker is offline
Samsung Pn51e6500 51 Inch 1080p 600hz 3d Slim Plasma Hdtv , Samsung Pn60e6500 60 Inch 1080p 600 Hz 3d Slim Plasma Hdtv
