Buying a new TV for gaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 03-30-2012, 04:37 AM - Thread Starter
Maxlaplante's Avatar
Hi guys,
I am looking for a new plasma TV, coming from a LG LCD 37". The only game I play daily is BF3.
What would be the best plasma ~55" to play battlefield 3 on xbox?
Thanks for your time,
Max
Maxlaplante is offline
post #2 of 17 Old 03-30-2012, 04:39 PM
DaveZ06's Avatar
Grab yourself a Panasonic ST, model. Fantastic picture quality and the lowest input lag of any plasma on the market.
DaveZ06 is offline
post #3 of 17 Old 03-31-2012, 12:55 PM
sage11x's Avatar
Quoted: 1043 Post(s)
Liked: 1018
Be wary of IR. The new panasonics seem to be more prone to it than they were just a couple years ago. It shouldn't be an issue as long as you mix up your content regularly-- but I know you battlefield guys like to play for a minute and matches last a good while.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #4 of 17 Old 04-01-2012, 07:17 AM
DR.DTS's Avatar
Quoted: 25 Post(s)
For Gaming in mind foremost I'd personally just look at a LED. Plus if you're coming from a 37" the smallest plasma is 50". And as Sage mentioned, with the current set of plasmas IR (image retention) can be an issue.
DR.DTS is offline
post #5 of 17 Old 04-01-2012, 07:29 AM
DaveZ06's Avatar
Actually, the smallest is a 42' Panasonic. Again, if he wants to buy new, I suggest getting the Panasonic ST50. Image retention really isn't a big deal and you can't find an LCD with as low of an input lag number as you could with the Panasonic.
DaveZ06 is offline
post #6 of 17 Old 04-01-2012, 04:12 PM
sage11x's Avatar
Liked: 1018
42" ST50 doesn't exist stateside. In fact, I don't think Panasonic will be selling any 42" plasmas in the states other than the 720p XT50... And only time will tell if that one ever sees the light of day.
Some Panasonic lcds have input latency as low as their plasma brethren. In particular, the 37" from last year (forget the model number) was well regarded. I'd wait to see the tests on the 2012 before making a determination but I'd expect them to follow suit. The motion resolution won't be as high as a plasma but, again, Panasonic is known for being strong in this area. Of course, with 60fps games this won't be much of an issue.
sage11x is offline
post #7 of 17 Old 04-03-2012, 09:19 AM - Thread Starter
Thanks for the anwsers guys.
Unfortunatly I dont have access to the ST models in my area, All I have access to is the GT and UT?
Have you heard about the UT?
post #8 of 17 Old 04-03-2012, 09:24 AM
TornadoTJ's Avatar
Quoted: 1703 Post(s)
Liked: 536
UT is basically the ST without the anti-reflective filter and the super-black panel (ST has deeper blacks than the UT). It has fewer inputs (if you are like me you don't care) and the wifi is optional instead of standard as on the ST.
TornadoTJ is offline
post #9 of 17 Old 04-03-2012, 09:33 AM - Thread Starter
Ok thanks Tornado.. So between the GT and UT, which one would be the best for gaming? I assume watching movies and tv would still be a nice display?
Max
post #10 of 17 Old 04-03-2012, 09:45 AM
CoryB23's Avatar
My brother-in-law bought a 50UT50 on Sunday and hooked his PS3 up last night. Hasn't done any gaming on it yet, but I'll weigh in once I hear or get a chance to try it out as well. I know he loves the picture for the Blu-Rays he's watched already.
CoryB23 is offline
post #11 of 17 Old 04-03-2012, 09:49 AM - Thread Starter
Awesome Cory, looking forward to hear from you! Put a post-it on your desk to remind you to come and comment about your brother-in-law 50UT50
Max
post #12 of 17 Old 04-05-2012, 12:12 PM
Digex's Avatar
Any updates on that UT and PS3 gaming? I wanna know also.
Digex is offline
post #13 of 17 Old 04-05-2012, 04:48 PM
ipoop2much's Avatar
why hasnt the samsung d8000 been mentioned? i own the 64d8000 and game regularly on it. absolutely no IR. none whatsoever! plus since its last years model you could probably find one for a great price.
ipoop2much is offline
post #14 of 17 Old 04-10-2012, 07:09 AM - Thread Starter
Bumb for CoryB23 review on his brother-in-law tv
post #15 of 17 Old 04-10-2012, 07:51 AM
CoryB23's Avatar
I'm still here, but haven't had a chance to check it out while up and running. He hasn't gamed on it much yet to speak of, but will in the coming weeks.
CoryB23 is offline
post #16 of 17 Old 04-10-2012, 08:08 AM
mohanman's Avatar
Quoted: 40 Post(s)
Liked: 33
I have both VT30 and Sony 929 LED, I would suggest the LED for gaming. The picture is much brighter and vivid for gaming than the plasma and there is no motion blur whatsoever.
Just my two cents.
Mo
mohanman is offline
post #17 of 17 Old 04-10-2012, 03:21 PM
PathofNeo's Avatar
Quoted: 79 Post(s)
Liked: 26
Just my two cents.
Mo
Interested you say this. I was just about to order a 55HX929 until I read about all the banding so many are having. I may still go ahead with it because I love local dimming tech and I can probably live with it. But most here will tell you that plasma is better for gaming due to less input lag. So if the 929 games well that's a bonus for me.
PathofNeo is offline
