how can i test FBr on a New Panasonic 42ST30 ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 03-31-2012, 02:44 PM - Thread Starter
HDVFreak's Avatar
is there any video link to download it and test my tv
i didn't got it yet,
HDVFreak is offline
post #2 of 21 Old 03-31-2012, 03:54 PM - Thread Starter
HDVFreak's Avatar
??? please guys
HDVFreak is offline
post #3 of 21 Old 03-31-2012, 04:15 PM
Techgurl's Avatar
No, not that I'm aware of... I asked the same question and was refered to the following movies "Sucker Punch" and "Rise of the Plant of the Apes". I only saw it in Sucker punch, I think, it was very very faint... and again even then I'm unsure.
Techgurl is offline
post #4 of 21 Old 03-31-2012, 05:57 PM - Thread Starter
HDVFreak's Avatar
thank you , i'm going to downoad sucker punch ,
but can you please tell me in what scene you saw FBr ?
HDVFreak is offline
post #5 of 21 Old 04-01-2012, 04:33 AM
Techgurl's Avatar
i don't know your definition of download, but you will need good quality, a torrent file probably won't work. I'd rent it.
Anyway, I wish I could be more precise but it seems to happen with the first 30 minutes of the movie, like when our Herione walks through a door you/or at least me could see a very faint shift. (and this has been the only movie or program, so far, which is outstanding because i've watched my set a lot.)
On another note, I am very picky and sold a S2 because of floating blacks and in comparsion since Panny released the patch the FBr are next to non-existant. If it were me I'd be more concerned about the Green blob/pink tint issues especially if you're still within the return period.
Ps i'll be honest mine was so faint it's not worth looking for...
Techgurl is offline
post #6 of 21 Old 04-01-2012, 07:35 AM
mfrey0118's Avatar
This worked for my ST30 (which has now had an A board swap). Play Pandora app. Wait until it goes into screen saver mode. If your panel suffers from FBr, you will see the background lighten and darken noticeably depending on where the rotating screen image is and how much of the screen it takes up.
If your panel is post-FBr fix you may still see shifts, but they will be subtle and only 1 to 2 times per full rotation.
60" 1080p 3D Plasma Panel
3D 1080p Blu-Ray player
4K 7.2 Channel AVR
mfrey0118 is offline
post #7 of 21 Old 04-01-2012, 09:53 AM
mailiang's Avatar
Quoted: 970 Post(s)
Liked: 641
FYI: According to Panasonic, only models manufactured up to August 2011 require the new software. Models manufactured after that have been updated and not considered defective.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #8 of 21 Old 04-01-2012, 10:32 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
Originally Posted by HDVFreak View Post
??? please guys
Just check the build date on the back of your TV. If it's August or newer than it's up to date, in which case don't go looking for FBr because even if you do find it there's nothing else you can do to reduce it any further so why bother looking?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #9 of 21 Old 04-01-2012, 11:05 AM
Techgurl's Avatar
Hi randy,
One reason it might be worthwhile to go looking if he is still in the return period-ie- grab an St50, etc. When I first got my set I examined it very very closely....because I never want to have to deal with floating blacks again, or any other annoying flaw I could not get use too... Floating blacks, Ouch
Techgurl is offline
post #10 of 21 Old 04-01-2012, 11:06 AM
Techgurl's Avatar
??? please guys
How long have you had your St30?
Techgurl is offline
post #11 of 21 Old 04-01-2012, 12:18 PM
"Don't PM Me Bro"
Quoted: 527 Post(s)
Liked: 782
Hi randy, One reason it might be worthwhile to go looking if he is still in the return period-ie- grab an ST50, etc.
But they don't make the ST50 in his 42" size. The 42" ST30 was the last and best 42 incher that we'll ever see and is a keeper. If it's a pre-August build, then it's worth keeping and having Panasonic update the A-Board.
Randy
post #12 of 21 Old 04-01-2012, 03:53 PM - Thread Starter
HDVFreak's Avatar
hi , thank you guys for answers
to make my case clear ,
i didn't buy this tv yet ,
i just saw it and like it .
and in my country there is a 42 inch ST30 !
HDVFreak is offline
post #13 of 21 Old 04-01-2012, 05:52 PM
"Don't PM Me Bro"
Quoted: 527 Post(s)
Liked: 782
Ah, what country?
The TC-P42ST30 was available in North America for all of 2011 until it was discontinued. Panasonic decided to not make a 42" ST50 for 2012 but maybe they offer it in your country?
Randy
post #14 of 21 Old 04-01-2012, 07:26 PM - Thread Starter
HDVFreak's Avatar
Originally Posted by RandyWalters View Post
Ah, what country?
thanks again Randy,
what country?
UAE
HDVFreak is offline
post #15 of 21 Old 04-02-2012, 11:58 AM
pmil7991's Avatar
I have the GT30 and I used the same technique you mentioned above to see the FBr. You don't need to use the Pandora app though. Anything that causes the screen saver to kick on. I used Amazon Instant Video app, but just being in Viera Connect will eventually cause the screen saver to start spinning. My GT30 is a March build. After the FBr fix, this change in background color went away.
pmil7991 is offline
post #16 of 21 Old 04-03-2012, 06:29 PM - Thread Starter
HDVFreak's Avatar
thanks pmil7991
so if i buy a ST30 and i saw FBr ,
there is nothing to do about it !
HDVFreak is offline
post #17 of 21 Old 04-04-2012, 02:50 AM - Thread Starter
HDVFreak's Avatar
there is nothing to do if i got FBr issues
yes or no
and by the way , i'm really sorry about my BAD ENGLISH , LOLz
HDVFreak is offline
post #18 of 21 Old 04-04-2012, 06:59 AM
"Don't PM Me Bro"
Quoted: 527 Post(s)
Liked: 782
so if i buy a ST30 and i saw FBr , there is nothing to do about it ! yes or no
Well if you end up with a unit that was built between Feb 2011 and July 2011 and you see FBr, you have three possible options: (A) Keep the set and try not to look for FBr or not let it bother you when you see it, (B) return the TV to the retailer, (C) contact Panasonic UAE and see if they offer the FBr patch or A-Board swap warranty visit that "fixes" it like they do here in the USA.
But if you get one built after August 2011, it already has the "Fix" built in and the TV should be fine.
Randy
post #19 of 21 Old 04-04-2012, 08:07 AM - Thread Starter
HDVFreak's Avatar
Randy ,you're The BEST!
Thank you very much
HDVFreak is offline
post #20 of 21 Old 04-04-2012, 08:25 AM - Thread Starter
HDVFreak's Avatar
Randy + Techgurl + all
cheers!
HDVFreak is offline
post #21 of 21 Old 04-04-2012, 11:59 AM
Techgurl's Avatar
I bought my 55" ST30 at Sears and specifically asked for their latest shipment, which turned out to be in November and I got an October set. If it were me (and your not buying online) I'd ask your retailer what their latest shippment was... it worked for me.
But if your not Set on a 42' I still recommend swinging for the ST50.
Techgurl is offline
