Official Panasonic GT50 Series Discussion Thread [No Street Price Talk] - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #361 of 9924 Old 04-17-2012, 09:34 PM
gbimmer's Avatar
Originally Posted by sheshechic View Post
Gbimmer, hows the shadow detail?
Pretty amazing, especially on "dark" movies like The Dark Night. I pretty much watch everything on the THX modes and I'm not noticing any lost detail; of course, I'm coming from a 2 year old mid-range Samsung LCD so I probably can't give the same kind of perspective as people here who are coming from other high end equipment.
gbimmer is offline
post #362 of 9924 Old 04-17-2012, 09:42 PM
sheshechic's Avatar
Quoted: 114 Post(s)
Liked: 167
sheshechic is offline
post #363 of 9924 Old 04-17-2012, 10:40 PM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Last week Chris from Cleveland Plasma called and asked, “How would you like to come over and check out the new GT50? Looks like I could even get a Samsung E8000 series plasma in for a face off!” Remembering how impressed I was with Panasonic’s ST50 just a short time ago and how last year’s top Panasonic and Samsung plasmas had such a competitive race, I didn’t take to long to think that one through. Before I knew it, I was making the drive up to Cleveland.
The GT50, like the ST50, has an excellent ability to soak up ambient light and preserve contrast in normal lighting. Even with bright lights on, reflections were very muted with the TV powered off, and the screen stayed commendably dark. If your spouse insists on turning the overhead light on while watching TV, as my wife does, the GT50 just may help keep peace and sanity in your home.
The feature list includes a built in wireless adapter, and the GT50 updated it’s firmware from 1.03 to 1.08 after setting up the network connection. I was pleased to see THX Cinema and THX Bright Room picture modes, and 3D mode had a THX3D Cinema picture mode in addition to the common Standard, Vivid, Cinema, Game, and Custom modes.
Before calibration:
Unfortunately for many less technically inclined owners, the GT50, after initial setup, reverts to one of it’s least attractive picture modes: Standard. The image was very muted and dim in this state, and, while there was a decent sense of depth to the image, the picture was totally lacking in excitement. Flesh tones were on the ruddy side, though I was pleasantly surprised that they were not screaming red fireballs as I have seen in the past in this mode. Pans and motion were too smooth with 1080P/24 Blu Ray content.
Switching to Cinema brought relief, though a slightly greenish tinge plagued the picture.
THX Cinema looked fairly similar to Cinema, though THX brought a slight increase in sharpness and pop over Cinema mode. Blacks were excellent, often blending into the bezel even in a fairly dark environment, though fades to black still did not match that of the 9G Kuro. Color shades still didn’t look spot on, but overall, THX Cinema gave a very impressive picture. Skin tones were fairly natural, and dark images did not sink down into black. In fact, shadow detail seemed to be handled very well in this mode, looking well balanced and with a good amount of detail visible. The Dark Knight looked stunning, with tons of pop and detail. Despite some lingering questions about subtle color shades, THX Cinema mode came very close to the best out of the box performance I’ve seen on a television, and it let the GT50’s excellent qualities shine through.
THX Bright Room was very impressive. It brought out shadow detail while keeping the blacks dark and whites bright. With the lights on, the image had plenty of pizzazz, and the tuning seemed well suited to it’s intended use in bright rooms. On the downside, there appeared to be some added graininess in many scenes which robbed the image of some naturalness. Colors looked good, though they lacked a bit of richness. At times, it seemed that there was something a bit unnatural in the highlights of brightly lit faces. However, despite these criticisms, THX Bright Room did it’s job, giving people who value accuracy a good looking mode for bright viewing.
Custom mode looked impressive at first glance, though shadow detail was lacking and the picture looked too garish and enhanced overall.
Calibration:
Minimum Luminance Level measured .0053 fL. The modified ANSI contrast was 5371:1, with white measuring an impressive 33.3 fL and black .0062 fL.
Maximum light output with a full white field was between 20.36 and 21 fL depending on the picture mode, and a 100% white field shifted slightly warm (+4% R, -6% B) in comparison with a small window of the same intensity. All this means that the GT50 is able to keep larger areas of the screen brighter and with less serious color shift than most plasmas.
Initially both THX Cinema and Custom mode were calibrated, but after evaluation THX was chosen to be the reference mode. Either mode would be a good candidate for calibration.
The Dynamic Brightness torture test on the AVS 709 disc showed noticeable fluctuation, but I have not done this test on enough plasmas to comment on how this result compares.
The light output from Custom and THX Bright Room modes were astonishingly high; they are the highest numbers I ever remember measuring on a plasma!
Difference in measurements between small 10% size window and larger 25% window was very slight.
The ChromaPure Advanced Color Management measurements were run in calibrated THX mode; the results were impressive with no strange behavior and nearly all dE below 2. This means that colors will be accurate no matter what shade of purity or intensity.
After calibration:
One of the GT50’s main strengths is it’s excellent contrast, which when combined with the strong light output gives an image with extraordinary pop. Images with a mixture of bright and dark objects have a depth and liveliness that is seldom seen in other plasmas. Disregarding the flickery 48 Hz mode, the GT50 had great motion when fed a 1080P/24 source. No, it was not displayed at a multiple of 24; but most people would be hard pressed to tell, including yours truly. Movie pans were not too choppy or too smooth; they just looked right. Shadow detail was very good in THX mode before calibration, and after calibration they were even more neutral. Despite the low gamma coming out of black, dark objects did not look washed out in the least. The picture appeared stable, with no visible pumping or fluctuation. I saw no signs of the Dirty Screen Effect and whites were brighter and purer than on most plasmas.
In a few fleeting moments I got the impression that the brightness layering in brightly lit faces and clouds was not quite right, but it was more an occasional impression than a real problem. Colors and skin tones were excellent; easy on the eyes but accurate and realistic.
THX Bright Room looked great with the lights on, though it lacked the depth and richness of THX Cinema in a dark room. Combined with the GT50’s light sponge of a screen filter, THX Bright Room makes the GT50 the best plasma for brighter environments that I have ever seen, by far.
The GT50 is an outstanding plasma that looks simply amazing in anything from dark theater rooms to average living rooms. The colors and contrast are extremely satisfying and put the GT50 among the top tier of all displays.
Shootout with Samsung D8000 plasma to come!
Face off: GT50 vs. E8000
Contrast was reduced in the GT50’s THX Cinema mode to match the light output of the E8000 in Movie mode. Sources included 1080P/24 Blu Ray and 1080i DirecTV. Cinema Smooth was turned on in the E8000.
Lights on, TV off:
GT50 is slightly better at reducing reflections. Both stay quite dark, but the GT50 is slightly better in that regard.
Lights off, Blu Ray:
Black levels are more similar than different, though the GT50 is darker by a hair. Certain times the black difference is more easily seen that other times.
E8000’s overall presentation is a bit more earthy-toned, giving it a slightly more cinematic feel as opposed to the GT50’s video feel.
Though the measurements would suggest a large difference in shadow detail, with real content the difference is extremely slim, with the GT50 just barely coming out of black faster. I have to look for the difference, but there’s a little more texture visible in dark clothes and objects on the GT50. The E8000 is actually more accurate in that regard, but many people like a bit of extra shadow detail.
Sometimes skin tones are just a tiny bit less red on the E8000. Usually the difference is slight. However, in the Digital Video Essentials Restaurant scene, the difference is more pronounced. I feel the E8000’s skin tones look more true to life in this clip.
The E8000 handles texture and layering in brightly lit faces and other very bright objects more naturally at times.
The GT50 has a tiny bit more pop in bright scenes, with whites looking a bit brighter. Whites can take on a slightly bluish and/or violet hue on the GT50, in comparison to the E8000’s slightly duller, greener toned whites.
Both have excellent depth.
I can see just a bit more fluctuation in the E8000’s image.
Overall presentation is just a bit more lifelike on the E8000 as opposed to more enhanced looking on the GT50.
Lights off, 1080i DirecTV:
Fades to black a are little better on the GT50. Hockey rink looks far more realistic on GT50, with brighter, purer whites. Neither shows much Dirty Screen Effect on hockey with movement and pans, but the GT50 shows more ice texture. A few fleeting times I thought I saw slight DSE, but I might have been looking too hard for it. Neither set fluctuates too much, both are seemingly stable.
The E8000’s skin tones can be a bit greenish, or the GT50’s skin tones can be a bit reddish, depending on the programming.
Conclusion: The E8000 is my preference by a nose for Blu Ray movies played in light controlled environments, with a slightly more cinematic, relaxed, and lifelike image. However, in other instances the GT50 is a very clear winner: viewing in typical living room lighting is much better on the GT50, as is hockey.
Update: I have found that calibrating Custom mode rather than THX gives even better results, with a more natural rendering of brightly lit faces.
The Panasonic 50 series as a whole has been susceptible to developing an oval yellowish blob on the right side soon after the set breaks in that lasts for perhaps a year or two. It tends to only be visible in images with full white backgrounds, like some commercials or computer desktop screens. However, over time, it disappears and uniformity becomes excellent again.
<a class="attachment loginreq" href="/attachments/7961" title="">Panasonic TC-P50GT50 THX Cinema.pdf 264.4248046875k . file
<a class="attachment loginreq" href="/attachments/7960" title="">AdvancedColorManagementReport gt50 wd.zip 392.3603515625k . file
File Type: zip AdvancedColorManagementReport gt50 wd.zip (392.4 KB, 195 views)
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is online now
post #364 of 9924 Old 04-17-2012, 11:02 PM
Tamakin's Avatar
Chad, did you notice a huge difference between the ST and GT? I'm super close to pulling the trigger on the ST and need some last minute advice. Thank you
Tamakin is offline
post #365 of 9924 Old 04-17-2012, 11:10 PM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
I don't have them side by side, but going by memory the only significant difference is the GT30's Bright Room mode. Gray gradations are supposed to be better, and they certainly look as good as I've ever seen, but I can't remember if it's different than the ST50.
post #366 of 9924 Old 04-17-2012, 11:11 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 3013 Post(s)
Liked: 3208
Originally Posted by Mandrake View Post
Yes! If tomorrow for Chad's review means 12:01 am, I might just stay up. Dang anticipation meter is running hot!
Come on now that review was up about 12:01 AM Pacific Time.... No response ? The early bird may catch the worm, but the late bird has more fun !
Cleveland Plasma is online now
post #367 of 9924 Old 04-17-2012, 11:12 PM
Tamakin's Avatar
thank you!
Tamakin is offline
post #368 of 9924 Old 04-17-2012, 11:25 PM
sheshechic's Avatar
Quoted: 114 Post(s)
Liked: 167
Woot!
post #369 of 9924 Old 04-17-2012, 11:30 PM
sheshechic's Avatar
Quoted: 114 Post(s)
Liked: 167
Thank you Chad.
I ordered the ST50 and it's going in a room that's bright, the tv faces the kitchen and I watch tv with a light on. I guess I'll see how it does on Thursday. It's good to know there's another excellent choice available.
post #370 of 9924 Old 04-18-2012, 12:18 AM
Big Ron 911's Avatar
Thanks for the review. Looks like I made the right decision for my first plasma (50" GT50), heck...my first HDTV. Now, to choose the correct 3D Blu-ray player.
Big Ron 911 is offline
post #371 of 9924 Old 04-18-2012, 12:39 AM
leroyjr1's Avatar
So are the black levels better than last year models?
leroyjr1 is offline
post #372 of 9924 Old 04-18-2012, 04:26 AM
Sound & Vision's Avatar
Quoted: 147 Post(s)
Liked: 48
Nice review...... Although not apples to apples comparison on what I am about to ask.... I am wondering how the newer GT50 stacks up against last years VT30 in Black level and overall brightness performance.
Sound & Vision is offline
post #373 of 9924 Old 04-18-2012, 04:34 AM
Italian Dude's Avatar
Chad, can you elaborate on the 48 Hz mode and the flicker? Was it only when fed a 24 source? And what about setting the TV at 60Hz instead for viewing BD? Did you observe a better picture as one other has commented?
Thanks for the review and posting it so early in the morning.
Italian Dude is offline
post #374 of 9924 Old 04-18-2012, 05:38 AM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
Originally Posted by gbimmer View Post
Got mine this weekend. No blobs, but a slight vertical banding on the right when I tried the gray slides (seems to be somewhat common) and its not ever noticeable on anything but the test slides. No brightness pops on the hours of playoff hockey I've been watching, but I did notice a few momentary pops in the warmness during a couple games (the ice would get a reddish hue for about 1/2 a second), but my guess is that its a signal issue. Overall, I'm satisfied. No brightness issues whatsoever during full sunlight. I ordered a few acoustic panels to put behind the TV to stop the buzzing during hockey games (I'm 10 ft away against a flat concrete wall), but that's about it. Amazon VOD seems kind of borked right now. I'm on 50mbps Fios and the picture gets a judder every 4-6 seconds. A friendly reminder: Reset your cable box! I was getting major judder in basketball games and freaked out till I reset the STB.
Good to know hockey does not cause any fluctuating brightness. The warmness pop is more than likely a change in the natural light setting at the hockey arena itself. As an example, i know the Garden where the Bruins play has a couple large led banner style displays running all the way around the rink. They change color from time to time and i notice when they are red it reflects off the ice surface making it look warmer.
As long as there are no actual brightness increases or decreases (like on my E8000) i think i mite be in for one of these.
How did the whites look overall?
wattheF is offline
post #375 of 9924 Old 04-18-2012, 06:08 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Close in black level performance, but much higher light output capability on the GT50.
The black level I measured here on the GT50 isn't quite as low as the VT30, but sometimes the smaller sized models have slightly lighter blacks than larger sizes of the same models. It would be speculation on my part to say that's definitely what's happening here, but that's my best guess. D-Nice might be able to shed some light on this.
post #376 of 9924 Old 04-18-2012, 06:12 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
48 Hz mode is only available when feeding the TV a 1080P/24 signal. 48 Hz mode has visible flicker that I find annoying, so I leave the TV in 60 Hz mode.
Feeding the TV 1080P/24 from Blu Rays resulted in subjectively excellent motion, and it looks much better than switching the Blu Ray player to output 1080P/60.
post #377 of 9924 Old 04-18-2012, 06:54 AM
rahzel's Avatar
Liked: 148
D-Nice said the larger models should have better blacks. He also measured a drop in black levels after 268 hours from his initial measurement I believe around 100 hours on the ST50 (0.0049fL -> 0.0028fL).
rahzel is offline
post #378 of 9924 Old 04-18-2012, 06:55 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Very good. The review set was broken in with the slides for about 4 days.
post #379 of 9924 Old 04-18-2012, 06:56 AM
slimoli's Avatar
Quoted: 654 Post(s)
Liked: 299
Chad, thank you very much for the review. Wainting for the 65VT50 to replace my 65V10.
I was so happy without HDR...
slimoli is offline
post #380 of 9924 Old 04-18-2012, 07:02 AM
Quoted: 147 Post(s)
Liked: 48
Thanks...
post #381 of 9924 Old 04-18-2012, 07:23 AM
rahzel's Avatar
Liked: 148
Just to be clear, I think D-Nice's measurements were for the smaller model. adrian s said his 60ST50 dropped to 0.0026fL after 100 hours, so it might drop even more considering D-Nice didn't measure a drop until 268 hours.
rahzel is offline
post #382 of 9924 Old 04-18-2012, 07:42 AM
Bigjoemeat's Avatar
What size did you review? The 50inch? By the way nice review. Although I'm still skeptical which set will give a better picture from the review, ST or GT hmm. I really want the VT but 55inch is smaller than I want.
Bigjoemeat is offline
post #383 of 9924 Old 04-18-2012, 07:48 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Thanks! Yes, the 50".
post #384 of 9924 Old 04-18-2012, 07:52 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Good info. Thanks.
post #385 of 9924 Old 04-18-2012, 07:53 AM
Tempest261's Avatar
Quoted: 12 Post(s)
Liked: 33
Thanks for the great review, Chad! Can you please explain the technical reason as to why larger models should have better blacks? On a similar note, as the panel size increases, does the individual sub-pixel size increase at the same ratio? Or do they simply get spaced further apart? I'm wondering if a larger pixel spacing could cause a lower black level (and possibly a lower brightness level too?).
Calibration Equipment:
Meters: X-rite i1 Pro 2, X-rite i1 Display Pro
Software: Spectracal Calman DIY, ControlCAL
Tempest261 is offline
post #386 of 9924 Old 04-18-2012, 07:59 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Unfortunately I just cannot give you a knowledgeable and definitive answer on these.
post #387 of 9924 Old 04-18-2012, 08:39 AM
JPeezy13's Avatar
Chad, does the ST50 also have a Bright Room setting as well? I'm still doing my homework regarding the ST vs. GT and this will help with a big question of mine. Also, if the ST does have a Bright Room setting, how did it compare to the GT?
JPeezy13 is offline
post #388 of 9924 Old 04-18-2012, 08:39 AM
TornadoTJ's Avatar
Quoted: 1721 Post(s)
Liked: 539
Let's put it this way, NOBODY is going to watch the TV in 48hz mode. It's awful. But, I will vouch for Chad's impression with 24fps material displayed in 60hz, just set it there and forgetaboutit.
TornadoTJ is offline
post #389 of 9924 Old 04-18-2012, 08:50 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
No, it does not.
post #390 of 9924 Old 04-18-2012, 08:53 AM
JPeezy13's Avatar
No, it does not.
Perfect, thanks for the quick follow up. And also thanks for all the help and reviews you provide!
JPeezy13 is offline
Panasonic Viera Tc P65gt50 Plasma Tv , Plasma Hdtv , Panasonic Viera Tc P55gt50 55 Inch Plasma Tv , Panasonic Viera Tc P50gt50 Plasma Tv , Panasonic Viera Tc P60gt50 60 Inch Plasma Tv
