Official Panasonic GT50 Series Discussion Thread [No Street Price Talk] - Page 250 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #7471 of 9909 Old 03-07-2013, 03:49 PM
Bill Mac's Avatar
Quoted: 1269 Post(s)
Liked: 1446
Originally Posted by Practolog View Post
I dont ask u to change some settings i just ask u measure TP of voltage to help me i need to adjust my after upgrade
I understand that you were not asking for me to change any settings. As I asked earlier why not measure the voltage on your own plasma. Seeing that you got the original S/M settings from another member earlier. I think you should just sit back and enjoy your plasma instead of over thinking everything as you are.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #7472 of 9909 Old 03-07-2013, 03:57 PM
JSpectre88's Avatar
Liked: 54
i know the truth when u put pb=low no dither in dark areas coz panel work in extra steps of grads u can see it by horizontal line of pixel protect its increase twice like mll and u can see thats in cinema the same))
Alright, no one is debating you on this now. However, your suggestion cuts the entire brightness in half, to fix a small dithering problem that only affects dark grays. A problem that's so small, it's barely recognizable on a full dark gray slide from regular viewing distance. It's there, I can see the difference from low to mid, but why should I care about something so utterly insignificant?
JSpectre88 is offline
post #7473 of 9909 Old 03-07-2013, 03:57 PM
rypaul's Avatar
Liked: 24
If you can see dithering 5+ feet away you are either a robot or you have a defective TV
rypaul is offline
post #7474 of 9909 Old 03-07-2013, 04:02 PM
Practolog's Avatar
No its not a difectife its always bug of Panny phosphor((( Samsung didnt have that issue((
sheshechic likes this.
Practolog is offline
post #7475 of 9909 Old 03-07-2013, 04:08 PM
rypaul's Avatar
Liked: 24
Notice I said five feet away. I do not dispute the artifacts. My point is like everyone elses is that
yes the picture like every other TV on this planet is not 100% pure and accurate if you stand right
in front of it but at a reasonable viewing distance the human eye cannot tell the difference. Which
if that is the case then it really does not matter. Ask yourself this, who is supposed to be watching
these tv's? If the answer is a machine from 2 inches away then yes you have a problem but if it's
a human from eight to ten feet then all of the worry over this dithering issue on your part is a
waste of energy and time. This is the last thing I have to say about dithering in dark areas
rypaul is offline
post #7476 of 9909 Old 03-07-2013, 04:19 PM
JSpectre88's Avatar
Liked: 54
Fine. Is it a problem worth cutting your brightness in half for.
post #7477 of 9909 Old 03-07-2013, 04:25 PM
JSpectre88's Avatar
Liked: 54
When I mess with Panel brightness the effect I am seeing is more a change in the image noise in dark area similar to what you would see with high gain settings.
I am not sure if this is what he is interpreting as dithering... Enlighten me please somebody who knows the truth about all this.
He's talking about the dithering in dark greys (1-4% specifically), not just the dithering normally seen from a plasma. It's more pronounced, and from 6-8 feet away you can see the pixels are dancing slightly, but the screen still appears solid gray. If I wasn't looking at a still slide I would probably not be able to tell the difference at all. It's an insignificant issue that he has blown WAY out of proportion, as you guessed.
post #7478 of 9909 Old 03-07-2013, 04:40 PM
rypaul's Avatar
Liked: 24
I am just curious what everyone here are using as an A/V receiver that plays nicely with the GT50.
I just want to make sure whatever I buy does not change the quality of the image before it is sent
to the TV in case I use the receiver as the main hub.
I had also planned to reuse my existing speakers so it need to accept raw wire. Thanks in advance
rypaul is offline
post #7479 of 9909 Old 03-07-2013, 04:51 PM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
You guys are debating with a guy that clearly voids warranty without care. Off course whatever he debates would be to an extreme.
JukeBox360 is offline
post #7480 of 9909 Old 03-07-2013, 04:58 PM
rypaul's Avatar
Liked: 24
Hence why I am moving on topic wise. I made a promise to myself to stop horse flogging when I turned thirty.
rypaul is offline
post #7481 of 9909 Old 03-07-2013, 05:03 PM
Latinoheat's Avatar
Quoted: 1088 Post(s)
Liked: 830
I have an Onkyo RC-360 hooked up to my GT50. Awesome receiver has everything I could possibly want at this time, multiple HDMI inputs, 3D, ARC, Network, 7.2 channels, HD Audio, 1080p up scaling etc, even is 4K ready. It's a 2011 model and have never had any issues. In other words onkyo is a good bet, I would recommend Denon as well.
As for wanting to send the quality image pass through is also not a problem. To be honest I only send the image passthrough only on bluray, for HD cable is upscaled to 1080p and it looks that much better. wink.gif
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #7482 of 9909 Old 03-07-2013, 05:28 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2035
Either Denon or Onkyo will do what you want. I've never had any experience with an AVR that didn't have binding posts that would accept raw speaker wire. wink.gif
htwaits is offline
post #7483 of 9909 Old 03-07-2013, 05:33 PM
JSpectre88's Avatar
Liked: 54
I don't believe you void your warranty unless you cause some form of damage from messing around in the SM.
As for debating with him, I wouldn't call a one sided argument, a debate. wink.gif
post #7484 of 9909 Old 03-07-2013, 06:02 PM
Bond 007's Avatar
Quoted: 2376 Post(s)
Liked: 1913
Originally Posted by JSpectre88 View Post
I would connect everything to the AVR, that's what I did at least.
I only have one HDMI cord going from the TV to the AVR.
+1
Licence to Kill
Bond 007 is offline
post #7485 of 9909 Old 03-07-2013, 06:07 PM
swizzchard's Avatar
Ok for Harmony issues. Go into the Harmony software, Click on devices, press the troubleshoot button in the Tv section
highlight the "Panasonic responds to some commands either too many times or only occasionally." section,
click next, highlight "1" click Save and then update your remote.
I have a harmony 300 and went into myharmony.com, however I do not see a troubleshoot. My problem is single button press increments the command by 2: volume, numeric picture settings, non-numeric picture settings...
I basically click the button, and put my hand over the IR transmitter to prevent the second send... frown.gif
swizzchard is offline
post #7486 of 9909 Old 03-07-2013, 06:14 PM
Bond 007's Avatar
Liked: 1913
That may not be an option on the website. You may have to use the Harmony software.
Licence to Kill
Bond 007 is offline
post #7487 of 9909 Old 03-07-2013, 06:16 PM
Bond 007's Avatar
Liked: 1913
Nearly any avr will meet those requirements. I like Yamaha. Whats your budget?
Licence to Kill
Bond 007 is offline
post #7488 of 9909 Old 03-07-2013, 06:31 PM
BDP33's Avatar
Anyone here running an HTPC? I'm running an i5 2600k and just using the onboard Intel graphics with Arcsoft Total Media Theater 5. I was just curious if anyone was using something similar and what your settings were refresh rate etc.
BDP33 is offline
post #7489 of 9909 Old 03-07-2013, 06:45 PM
jpl20's Avatar
I had a handshake issue when going from my Scientific Atlanta stb to my Denon to my display, I had to run a separate hdmi from the stb, and another from the Denon for the blu ray. To be able to run the sound from the stb to the Denon I ran an optical out. Just my $0.02
jpl20 is offline
post #7490 of 9909 Old 03-07-2013, 06:50 PM
Bill Mac's Avatar
Liked: 1446
I'm using a Denon 4311 and it works quite well with the 60GT50. You can use raw wire but I'd use good quality banana plugs if you can. That way making your speaker connections is very easy and you won't have any issues with stray wiring.
http://www.amazon.com/GLS-Audio-Locking-Generation-Connector/dp/B000QIYIRC
Bill
Bill Mac is offline
post #7491 of 9909 Old 03-07-2013, 06:55 PM
Bill Mac's Avatar
Liked: 1446
I'm having no issues using HDMI from my SA 8300HD cable box to my Denon 4311 then to the 60GT50. Sometimes the sequence in how your components are powered up can cause HDMI handshake issues.
Bill
Bill Mac is offline
post #7492 of 9909 Old 03-07-2013, 06:56 PM
moonbeam13's Avatar
Using a Denon 2112CI here with my 55GT50 and I'm very happy with it.
Panasonic GT50 55"
Oppo 103 Blu-Ray Player
Denon 2112CI AVR
moonbeam13 is offline
post #7493 of 9909 Old 03-07-2013, 07:11 PM
rypaul's Avatar
Liked: 24
Thanks to all who gave advice on receivers. I currently am eyeing the Onkyo RC-460. I like the fact that it has 2 HDMI outputs. I have
it in mind to use these to create day and night custom settings instead of using a seperate box.
rypaul is offline
post #7494 of 9909 Old 03-07-2013, 07:12 PM
rypaul's Avatar
Liked: 24
Oh my budget is anything under U.S. $400
rypaul is offline
post #7495 of 9909 Old 03-07-2013, 07:17 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
You might want to read some of the early postings in the VT50 calibrations thread regarding Panasonic's policy on owners messing in the SM. wink.gif
sheshechic is offline
post #7496 of 9909 Old 03-07-2013, 07:18 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Everything runs into my Denon 2113. I upgraded from a Yamaha and couldn't be happier.
post #7497 of 9909 Old 03-07-2013, 07:24 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
How many speakers? I'm keeping my eyes peeled for a Denon AVR-1713 for the living room (5.11). Audessey MultiEQ XT is far better than Yamaha's YPAO especially if you have a less than ideal speaker setup.
post #7498 of 9909 Old 03-07-2013, 07:46 PM
rypaul's Avatar
Liked: 24
Right now I only have a 5.1 setup. I have not thought out a 7.1 or 7.2 setup for my living room yet.
rypaul is offline
post #7499 of 9909 Old 03-07-2013, 07:51 PM
JSpectre88's Avatar
Liked: 54
I would like to see them prove it, in any event less than you "bricking" the TV.
post #7500 of 9909 Old 03-07-2013, 07:55 PM
Bond 007's Avatar
Liked: 1913
Does that have any sort of room calibration? I just looked at it and didnt notice any?
Licence to Kill
Bond 007 is offline
Panasonic Viera Tc P65gt50 Plasma Tv , Plasma Hdtv , Panasonic Viera Tc P55gt50 55 Inch Plasma Tv , Panasonic Viera Tc P50gt50 Plasma Tv , Panasonic Viera Tc P60gt50 60 Inch Plasma Tv
