Official Panasonic GT50 Series Discussion Thread [No Street Price Talk] - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
Old 05-23-2012, 06:10 PM
yenal's Avatar
Originally Posted by rahzel View Post
Option 2 if PQ is your number one concern. A calibrated ST50 will look better than a GT50 in THX mode. THX mode is good for a preset but it's not great compared to a calibration.
Option 3 is good if you have a calibration disc AND a meter. A calibration disc by itself will only get you so far. To do a full and proper calibration, you need a meter.
I think the only time I would recommend a GT50 is, you prefer the styling, the extra features appeal to you and/or you're not getting it calibrated.
THX Cinema and THX Bright room are both more accurate out of the box compared to Cinema and Custom, but both Cinema and Custom mode can be calibrated to look better than the THX modes.
I'd love to buy a meter as a hobbyist. What is a good starter meter?
yenal is offline
Old 05-23-2012, 06:11 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Yenal, what are your needs?
If you get the ST50 you'll have one good mode that you can either apply the D-Nice settings to or have professionally calibrated. If you have that one mode calibrated you can have it calibrated for a bright room. And then you're done.
You saw what I said at the shootout, so I won't repeat myself.
In addition to the 3 THX modes (one for 3D) the GT50 also has a Custom & Cinema mode.
Since neither the ST50 nor the GT50 have isf tools in the cms using D-Nice's settings might sufficient for many. THX bright room looks so good that I may not feel the need to get it calibrated at the end of the year. This could be true for those with a ST50 using D-Nice's settings too. All I know is, that I like THX well enough, that if D-Nice's settings don't appeal to me, then I won't feel like I must get it calibrated since I like THX bright room mode that much. I have tinkered with Custom and I see that it has the potential to be even better than THX Cinema
Also, my needs go beyond watching tv so the dual core processor and multitasking is important to me.
sheshechic is offline
Old 05-23-2012, 06:16 PM
yenal's Avatar
I just ordered the ST50. I could not resist the low price. I will try to calibrate it to my needs. I'll possibly buy a meter.
In case of D-Nice settings, I really don't want to run the slides for 100 hours
yenal is offline
Old 05-23-2012, 06:18 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Originally Posted by kev1031 View Post
Here is the scene from Planet Earth. Again, picture can't tell the story.
On GT50 - the rock and ice doesn't look as sharp, appears soft, but the color of rock seems to be more natural
ON LED C7000 (motion plus set off) - the rock and ice has more definition and sharper
I looked at it several times on these two TV, I simply plug and unplug HDMI cable as TV is right next to each other, then rewind and play
This particular scene (very beginning of disc 1) caught my eyes because I saw GT50 first, it seems blurry, I switched to LED and notice the big difference.
I do like the color on GT50, it is more superior. THX cinema is too dark for me, I think I can accept THX bright room as I watch more, but my wife simply do not like the overall darkness on GT50.
Maybe our eyes are accustom to LED....I don't know, but if I can get the PQ to be sharper on GT50 I would consider keeping it.
How do you feel about Soap Opera Effect? What processing settings did you have turned on with your LED?
Old 05-23-2012, 06:19 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Great buy! I think you'll have a blast. Good luck with your new tv.
If you're going to use his settings then follow his directions at hdj to a T. Get the slides from over there, they are different.
Old 05-23-2012, 06:21 PM
paligap's Avatar
Quoted: 112 Post(s)
Liked: 42
Originally Posted by htwaits View Post
By the way, Planet Earth is 1080i because it originated on TV. If you want a better check try a Blu-ray movie that's known to have good picture quality.
It depends. The BBC version of Planet Earth is 1080p. I have it, and it has exquisite PQ.
Sony XBR-75X940D
Oppo BDP-103D
Denon 4520
Custom UFW-15 (2)
Rocket RS850 (2), Rocket Bigfoot Center, Rocket RSS300 (2), Rocket RS250MKII (4)
paligap is online now
Old 05-23-2012, 06:41 PM
rahzel's Avatar
Liked: 148
A good starter meter would be a i1 display lt/2 (same meter, different software between the 2/LT). If you want something more accurate and that will last longer (colorimeters deteriorate and lose accuracy after a certain amount of years) the i1 display 3 pro is a very good meter but obviously more expensive. Try to store your meter in a dry, cool and dark area. I have mine in a drawer with desiccant packs. I believe you can also rent meters from spectracal.
For software, colorhcfr + AVS 709 calibration disc is a good free route. Or you can buy software like calman, chromapure etc and calibration discs with test patterns like Spears & Munsil.
There's quite a bit to learn, so be prepared to do some reading if you go this route. Any questions, the guys in the Display Calibration section can help.
Meters are expensive, but the nice thing about having your own is that you can do all of your displays, and you can touch them up after a few years when they start to 'drift'. The downside is, the results probably won't be as good as a professional calibration, unless you have a lot of experience and have good equipment.
rahzel is offline
Old 05-23-2012, 07:48 PM
buzzard767's Avatar
Quoted: 1640 Post(s)
Liked: 2407
An X-Rite D3 Pro purchased through Chromapure is, in my opinion, your better choice. The meter is going to drift less than the older models due to better sealing and the Pro settings will put you in the ballpark among the different display types. It costs a bit more but you won't get saddled with yearly maintenance charges ( WTH is that all about?) from other venders. Also, it will last much longer. You can learn on your displays and work on other displays (friends & neighbors) as well. If it turns out you like calibrating you can purchase an i1Pro Spectrophotometer on the cheap now that the i1Pro2 has been released and you can run profiles to the D3. The original i1Pro is approved by ISF & THX so you really can't go wrong.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is online now
Old 05-23-2012, 08:19 PM
yenal's Avatar
Originally Posted by Joxer View Post
No, those are not compatible with Panasonic plasma 3D HDTVs.
They are only for passive models, some of the LED sets.
The plasmas require the more expensive ACTIVE 3D glasses.
Thanks a lot for all the info guys. How much time does it take for a newbie to get up to speed and do decent calibrations? Is it basically just reading few tutorials and practicing them on your display? I am a software developer but who knows maybe I'll switch to a new profession :P
yenal is offline
Old 05-23-2012, 08:37 PM
DrRx's Avatar
This was recently posted elsewhere on the forum. Seems like a very good introduction!
http://www.curtpalme.com/forum/viewtopic.php?t=10457
DrRx is offline
Old 05-23-2012, 08:43 PM
Tempest261's Avatar
Liked: 26
See my sig- I am a recent calibration hobbyist myself, and I detailed my first few calibrations in that thread, along with the gear I purchased. It's pretty easy to do nowadays with about $400 and some patience.
Calibration Equipment:
Meters: X-rite i1 Pro 2, X-rite i1 Display Pro
Software: Spectracal Calman DIY, ControlCAL
Televisions:
Panasonic TC-P65VT50 (currently own)
Samsung UN55D8000 (returned) Calibration and Settings Thread
Plasma IR Removal:
Post 1 - Post 2 - Post 3
Tempest261 is offline
Old 05-23-2012, 09:12 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
You're right. I blew it. I have the same version but it's on HD-DVD.
htwaits is offline
Old 05-24-2012, 01:06 AM
vaxick's Avatar
Quoted: 77 Post(s)
Liked: 59
Originally Posted by lennyp View Post
Always good to dwell on the positive. My daughter started her summer Skyrim crusade last night (finished her final exams) - set the TV to game mode and no IR present after five hours of playing (not the best test but it does have a compass across the top of the screen).
You just made my day! Now that I'm done with my finals, I've been getting into a lot longer gaming sessions that I have in a long time. It's nice to know that even if I do end up clocking four or five hours into the game on my VT50, I might not have to deal with a nasty HUD sticking around on the screen for days.
vaxick is offline
Old 05-24-2012, 03:50 AM
buzzard767's Avatar
Liked: 2407
Keep your day job! Pay per hour is dismal considering equipment depreciation, study time on individual displays, travel costs, time expended, etc.
Read the basics and learn on your own home display. There is a little more time involved than most realize.
http://www.avsforum.com/avs-vb/showp...99&postcount=1
http://www.avsforum.com/avs-vb/showthread.php?t=852536
Buzz
Old 05-24-2012, 06:59 AM
rgh71's Avatar
Originally Posted by HLdan View Post
Cinema mode is nowhere close to THX on the GT50 and VT50 and you cannot simulate it. If you have the ST50 you can get it calibrated to your liking however I don't know if it will make it close to the THX mode.
I've used my new 60GT50 for a few hours now, and I really like THX Cinema over THX Bright. I haven't given it the full daylight test, but at night with a medium amount of room lighting, the Bright looks a bit washed out to me and the THX Cinema is quite nice. Maybe skin is a bit red to me though. What does anyone do to tweak their THX Cinema defaults?
rgh71 is offline
Old 05-24-2012, 07:19 AM
paligap's Avatar
Quoted: 112 Post(s)
Liked: 42
I have a few HD-DVDs, too. Last time I get involved in a format war.
Sony XBR-75X940D
Oppo BDP-103D
Denon 4520
Custom UFW-15 (2)
Old 05-24-2012, 10:34 AM
yenal's Avatar
LOL. I was joking. Don't worry I won't bring in more competition. So do I need the i1 Display Pro or i1 Pro. It seems like one is a colorimeter and the other one is spectrometer. If I need both it will be pretty expensive DIY solution.
yenal is offline
Old 05-24-2012, 10:42 AM
kev1031's Avatar
For movie, soap opera effect is no good, doesn't feel like watching movie. I turned on motion plus for sports on cable. Most of settings on LED should be off as I followed calibration forum for that TV at AVS.
After I set "sharpness" to 25 or 10 from default 50 under THX bright room, channel guide seems to look a bit better but still not as clear as LED.
I will give it another week or so, if PQ doesn't get better to my liking (more sharp, less soft, do prefer a bit brighter), I'll just have to give it up.
kev1031 is offline
Old 05-24-2012, 10:45 AM
Tempest261's Avatar
Liked: 26
You don't NEED both. The purists will say you do, but as an amateur you can get by just fine with the i1 display pro. Out of all of the "budget" colorimeters, it seems to be the most bang for your buck. It'll be profiled out of the box, and you'll only need it re-profiled (by something like an i1 pro) in 1-2 years, minimum.
Televisions:
Plasma IR Removal:
Old 05-24-2012, 10:50 AM
yenal's Avatar
May I ask where you got yours and the software? Also it seems like you did not use a free software. May I ask why?
yenal is offline
Old 05-24-2012, 10:56 AM
Tempest261's Avatar
Liked: 26
There isn't a whole lot of decent software out there. I used Spectracal's Calman DIY.
Televisions:
Plasma IR Removal:
Old 05-24-2012, 10:59 AM
yenal's Avatar
So is this the meter I should buy: http://www.amazon.com/Xrite-EODIS3-i...7882327&sr=8-1
I don't want to order the wrong thing. Also what about this ChromaPure software everyone is talking about? Is Calman better than that?
yenal is offline
Old 05-24-2012, 11:04 AM
Tempest261's Avatar
Liked: 26
Yep, that's the meter. It comes with OK software in the box for calibrating PC monitors, too.
As for Calman vs Chromapure vs ControlCal, I'm not one to ask. The shootout calibrators all used a mix of Calman and ControlCal, with Calman being their primary SW, and ControlCal as a backup due to some (now fixed) bugs between the VT50 and Calman.
Televisions:
Plasma IR Removal:
Old 05-24-2012, 11:05 AM
yenal's Avatar
Calman DIY is the same as professional software but you cannot make commercial use for it?
yenal is offline
Old 05-24-2012, 11:40 AM
Tempest261's Avatar
Liked: 26
Visit Spectracal's website for info on the different licenses.
Televisions:
Plasma IR Removal:
Old 05-24-2012, 12:35 PM
yenal's Avatar
I already have the WoW calibration disk. Do I need more calibration disks if I purchase Calman DIY?
yenal is offline
Old 05-24-2012, 12:39 PM
Quoted: 46 Post(s)
Liked: 61
you can use the AVSHD 709 disk.
http://www.avsforum.com/avs-vb/showthread.php?t=948496
Mike
wmwilker is offline
Old 05-24-2012, 01:39 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
I hope it was my last time too. I bought into HD-DVD on Black Thursday for what finally amounted to a $200 discount. Early in January Warner Bros. killed BD-DVD.
Most of the BD-DVD disks that I have were at close out prices. I swapped 18 of those with Warner for BD at $5.00 each. What a deal.
htwaits is offline
Old 05-24-2012, 07:52 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
Originally Posted by hov333 View Post
Hey wattheF, please let me know how you make out, and the same goes for the others out there that have or soon will be moving from the e8000 to a gt50.
I have verizon fios and the channel info bar was the first indicator that made me notice the softness of the gt50. PQ in terms of overall color and gradation is almost equal, maybe even a bit in panny's favor but I've noticed more of an interlaced effect on 1080i material on the GT, which basically refers to all fios/cable programming.
I'm really miss the sharpness of the e8000 and am considering going back but I need to know one thing...I know all these sets buzz depending on the amount of light its outputing BUT the panasonic is totally quiet when I have it switched to a blank source (ps3 while its off) or minimal content like the verizon logo (set top box off), or dark scenes.
The samsung's buzzing was constant, even with a blank input or dark scene it was just horrible. Did others notice this as well? I can live with fluctuating buzzing but not constant :/
I will let you know how i make out. More and more people keep coming out and commenting on the softness of the GT50 PQ. The funny thing is that it seems like only former Samsung owners that are commenting on this. The Samsung owners on the E8000 threads comment how Samsung has superior video processing (over Panasonic)...I dont know about that, but i do know that between the 4 dead pixels, constant buzzing and fluctuating brightness (during hockey) issues that i had with my 51'' E8000 along with all the great initial reviews i heard about the new Panasonic models, it was enough for me to request a refund. I got this refund directly from Samsung because my E8000 was a replacement for a defective C7000.
So at this point i feel like i am kinda commited to trying a GT50. Also with minimal adjusting to my entertainment center/tv stand i can fit a 55''. The Samsungs jump up to 60'' which would require alot more work and $ to fit.
I figure both sets will have their strengths and weeknesses. But i am hoping the weeknesses of the GT minor and are easy for me to overlook.
Now i just need the price to drop a little...come on!
wattheF is offline
Old 05-24-2012, 08:23 PM
Sonyboy's Avatar
Quoted: 69 Post(s)
Liked: 78
Check Pauls Tv. They have great prices right now on the st and gt series. The lowest I've seen by far on the gt series.
Sonyboy is online now
Panasonic Viera Tc P65gt50 Plasma Tv , Plasma Hdtv , Panasonic Viera Tc P55gt50 55 Inch Plasma Tv , Panasonic Viera Tc P50gt50 Plasma Tv , Panasonic Viera Tc P60gt50 60 Inch Plasma Tv
