UT50 gain access to Pro settings in Service Menu? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 03-05-2013, 04:42 PM
RicoBrazil's Avatar
Hi. Can you tell me if this change eliminates the effect of the ABL (Automatic Brightness Limiter)?
I accessed the service menu, but I didn't know which option should be changed (if it exist).
RicoBrazil is offline
Old 03-05-2013, 08:25 PM
JSpectre88's Avatar
Liked: 54
You can't disable the ABL.
JSpectre88 is offline
