Hanging Plasma TV's on Drywall? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-13-2012, 12:02 PM - Thread Starter
kromix's Avatar
So I purchased the MonoPrice Ultra Slim mount to mount my PN51D7000 (49 lbs) and I'm worried about my mount strength what do you think?
I drilled around till I found what seems to be wood and put in two wood screws in the middle of the bracket.
I couldn't find anymore wood beams so I put on the left and right sides of the wood screws 8 Drywall Anchors, (4 on each side):
DO you think 8 of these Drywall Anchors combined with 2 wood screws into wood is enough?
I went with this method because I live in Florida and I have 1/2 drywall, a 1/2 inch void, and then concrete block, not alot of room to work with, and I figured using TapCon's into concrete block with 1/2 drywall and 1/2" void would not create a strong hold?
kromix is offline
post #2 of 3 Old 04-13-2012, 12:14 PM
Phades's Avatar
I've hung multiple plasma TV's on drywall with no actual beams with no problems. One was a 58" Panasonic, 100lb's, and another was a 64" Samsung, 90lbs. The Panasonic is at 3 years and going strong. On the Panasonic I used those same style anchors. Personally, I think you'll be fine.
Phades is offline
post #3 of 3 Old 04-13-2012, 12:16 PM - Thread Starter
kromix's Avatar
Originally Posted by Phades View Post
I've hung multiple plasma TV's on drywall with no problems. One was a 58" Panasonic, 100lb's, and another was a 64" Samsung, 90lbs. The Panasonic is at 3 years and going strong.
What did you use to hang em?
kromix is offline
