What to buy? LG 55LM7600 vs Panasonic TC-P65ST30 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Which TV?
LG 55LM7600 0 0%
Panasonic TC-P65ST30 0 0%
Voters: 0. You may not vote on this poll
post #1 of 6 Old 04-19-2012, 04:02 PM - Thread Starter
Cugolfer33's Avatar
I currently have the LG 55LM7600 on order but wont arrive for a month according to amazon. I have a 60" LG plasma right now and wanted to get bigger or at least 60". However got really good deal so assume same price for both but which should I get. I know these are completely different tvs and the LG is only 55" (vs 65" for panny) but need some thoughts or recommendations.
Home theater use, blu ray, cable, gaming, 3D.
Cugolfer33 is offline
post #2 of 6 Old 04-19-2012, 04:34 PM
TornadoTJ's Avatar
Quoted: 1613 Post(s)
Liked: 510
60" or 65" ST50
Not ST30. Too many improvements on the new sets.
TornadoTJ is offline
post #3 of 6 Old 04-19-2012, 08:20 PM
Ace1965's Avatar
The biggest one. ST30
Ace1965 is offline
post #4 of 6 Old 04-19-2012, 09:35 PM - Thread Starter
Cugolfer33's Avatar
Originally Posted by TornadoTJ View Post
60" or 65" ST50
Dont have money for st50.
post #5 of 6 Old 04-20-2012, 11:14 AM
Dierkdr's Avatar
Liked: 54
I currently have the LG 55LM7600 on order.... I have a 60" LG plasma right now and wanted to get bigger or at least 60". However got really good deal.... I know these are completely different tvs and the LG is only 55" (vs 65" for panny) but need some thoughts or recommendations.
What is "wrong" with your 60" LG?
That is, what do you hope to gain by replacing it with a different panel?
Or, conversely, what FLAWS do you hope to Avoid with a new set?
Going from a 60" panel, neither 55" nor 65" is a tremendous size change - but the difference BETWEEN 55" and 65" IS substantial (55 -> 65" = approx. 40% larger area) - therefore Viewing Distance AND Typical Program Material should factor into your decision.
We have a 60" ST30 now, and at 9feet blu-rays are GREAT - but Upconverted SD DVDs and many so-called "HD" tv broadcasts look better at about a 12 foot viewing distance!
Also, while game play on the 2011 Panasonics seems very good (apparently due to little lag on the panels), there have been a fair number of reports of IR problems. We don't game, but our set DOES show much more "Short Term IR" than either of the other 2 (older) plasma sets we have: just a couple of minutes - literally - of a Menu will leave an echo that lasts a long time on reasonably "static" material. (Visible against "institutional" background colors: grays, beiges, dirty yellows, medium greens...).
Good luck with your decision.
Dierkdr is offline
post #6 of 6 Old 04-20-2012, 05:22 PM - Thread Starter
Cugolfer33's Avatar
I thought tv was great until gaming on my projector. There is alot of lag on LG and downsizing apartment so wont beable to keep projector. Therefore looking to get new tv to fit both needs. Sure wish I could get a 100" tv as the projector is awesome even though its 720p, the 3D is unreal.
Panasonic Viera Tc P65st30 65 Inch 1080p 600 Hz 3d Plasma Hdtv
