cnet reviews samsung e8000 plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-19-2012, 08:24 PM - Thread Starter
ipoop2much's Avatar
http://reviews.cnet.com/flat-panel-t...=rvwBody;page1
seems like an improvement in black level(im not complaining about my 64d8000 blacks so non-issue for me).....with slightly less accurate colors.
overall it seems samsung focused more on the whole smart tv craze than improving pq. still a great set though and as always this is someone elses opinion
on it. ill reserve judgement till i see my brother's in action.
ipoop2much is offline
post #2 of 15 Old 04-19-2012, 08:36 PM
karlmalone1's Avatar
They actually tested LOWER black level on the e8000 than the st50, that's surprising. (though for all intents and purposes they were identical). Then again it was a 60 inch e8000 to the st50s 55 inch.
karlmalone1 is offline
post #3 of 15 Old 04-19-2012, 09:00 PM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Looks good. Another contender, especially if 3D is a priority. Also, I don't believe the VT50 blacks are better then the ST50 according to the few reviews. Samsung also has less dithering, and false contouring.
conan48 is offline
post #4 of 15 Old 04-20-2012, 01:31 AM
Turrican4D's Avatar
Quoted: 719 Post(s)
Liked: 414
You already know that for 2012?
Also the Panasonics were better when it came to pwm noise in the shades near black.
Prof. Dr. Turrican M.D.
Turrican4D is offline
post #5 of 15 Old 04-20-2012, 06:09 PM - Thread Starter
ipoop2much's Avatar
the only reason id consider upgrading this year is the CS bug has been fixed,my wife doesnt notice the jump in MLL with it engaged on our 64d8k.....but i do
post #6 of 15 Old 04-20-2012, 06:29 PM
Barana2080's Avatar
I think I'll still pull the trigger on the ST50 instead of this Samsung. But need more threads about this topic to make my final decision.
Barana2080 is offline
post #7 of 15 Old 04-20-2012, 10:19 PM
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
Forget the 8000 and all the doo dads I'm waiting to see about the vt50 and the 7000/6500..
CaTaSTrOphiK is offline
post #8 of 15 Old 04-21-2012, 12:36 AM - Thread Starter
ipoop2much's Avatar
agreed. i went samsung d8000 last year,but the vt50 is looking MIGHTY fine
post #9 of 15 Old 04-21-2012, 06:08 PM
David_B's Avatar
Quoted: 14 Post(s)
Liked: 32
I'll wait for an OLED. They are to close to replace a 1 or 2 year old plasma right now with another plasma.
David_B is offline
post #10 of 15 Old 04-22-2012, 11:09 AM
sage11x's Avatar
Quoted: 745 Post(s)
Liked: 808
Looks like samsung has finally caught Panasonic on the great we're-still-worse-than-a-3-year-old-discontinued-product black level race!
Wonder if Panasonic saw this coming?
Wonder how much of a fire it lit under their asses to make the new ST50 a homerun?
Wonder if the E series regression in color accuracy and advancement in black level explains why Panasonic has typically lagged behind the competition in this regard?
Things that make you go: hmmm?
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #11 of 15 Old 04-27-2012, 04:53 PM
turnne1's Avatar
Quoted: 1755 Post(s)
Liked: 410
According to CNET the E is the best plasma Samsung has ever made
should be interesting
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
post #12 of 15 Old 04-27-2012, 10:09 PM
Matt Stieg's Avatar
This is going to be an issue:
I was also a bit annoyed to see that in fades to black, the screen of the E8000 turned off completely, a behavior typically associated with LCDs and not plasmas. It does so more quickly than the PN59D7000 -- fast enough that the black screen flashed off and on distractingly during the black fades at the beginning of "Watchmen," for example. Neither the Sharp Elite nor the other plasmas turned off when fed black screens.
I have the E550 and it's flat out annoying. If you check out the E550 thread I've documented several instances where it's occured for me so far. Just finished watching U2's Rattle and Hum a little while ago and it happened once late in the movie, but once is enough when you're involved in a film to annoy the crap out of you.
Hopefully this issue gains the traction of last year's brightness pops and Samsung responds with firmware.
Matt Stieg is offline
post #13 of 15 Old 04-28-2012, 12:27 AM
cocoon's Avatar
I have an E8000. The flickering is getting extremely annoying. Also CS Mode does not work as well my 2009 model Samsung.
Are there some issues with Panasonic GT50 or VT50 that one should worried about? 3D and 23.976fps blu-rays are my priorities absolutely zero sports.
cocoon is offline
post #14 of 15 Old 04-28-2012, 12:54 AM
HearingImpaired's Avatar
I don't know about the GT and the VT but the ST50 2d was rated higher than the Samsung E8000 in one review.
HearingImpaired is offline
post #15 of 15 Old 04-29-2012, 04:14 PM
turnne1's Avatar
Liked: 410
wow
if that is the the case then this years ST is better than last years VT?
and hopefully the design of the new ST is better...that bezel on the 2011 model was fugly
Warren
turnne1 is offline
