Pioneer KURO 5080HD odd flashing blue LED - No Picture??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-19-2012, 08:48 PM - Thread Starter
6SpeedTA95's Avatar
Quoted: 145 Post(s)
Liked: 45
Ok, for the second time in a week while watching my Pioneer 5080HD, it has clicked as if turning it on or off and the blue LED begins flashing with no picture. Cable box is still on, tv is still on but the blue LED won't stop flashing. I have to power everything off and back on and the picture comes back.
Anyone know what the blue flashing LED means? It's working fine at the moment but I am a little concerned now that this is twice in a week and it hasn't done it the prior 4 years of ownership.
6SpeedTA95 is offline
post #2 of 3 Old 09-15-2012, 12:12 AM
Midnight Rambler's Avatar
Did you ever get an answer to your problem ? Because I have a similar-aged Kuro that has just developed the same problem. I'm so bummed ...
Midnight Rambler is offline
post #3 of 3 Old 10-28-2012, 08:00 PM
totallyr's Avatar
I had the same problem a few years back, mine was with the OTA,. It's getting a bad signal, contact Pioneer there is a firmware update they will send you that will rectify this. I sent for it, fixed mine and 2 friends, good luck.
totallyr is offline
