Official Panasonic UT50 Series Discussion Thread - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #2431 of 2656 Old 04-28-2013, 10:19 AM
sharvey02's Avatar
A quick question about specific 3D issue.
Hello there. I've read this entire thread from August posts until now to see if this was mentioned. I know with the active 3D ghosting and crosstalk are sometimes issues but I have a specific question about Avengers 3d.
I also know with high contrast the image can have more issues but my main problems are in scene 7. With the scene of Loki the transforms to the moon. As the camera revolves I can actually see my image swap and get very blurry and a bar on the left side of the screen that almost seems like the scene isn't synced. This also happens on I believe scene 6 where Iron Man is underwater and as he flies up and the cityscape is in the background everything is blurry. This continues all the way through the end of the scene where Jarvis removes his suit.
My main question is this has NOT been a problem in any 3D movie we have seen yet. Prometheus, Lion King, Life of Pi, Hobbit, Titanic, Avatar, Abe Lincoln Vampire Hunter, Transformers, Immortals, Beauty and the Beast, Tin Tin.
Not only has this never been a problem before but what was strange to me was how the ENTIRE scene violently shifted in Scene 7 with Loki it wasn't just some ghosting or crosstalk on a specific object it was the entire scene and the offset image on the left side almost appearing layers incorrectly.
I listed my other movies to see if anyone has had issues with this in other films or hopefully someone can tells me if Avengers 3D on their UT50 has the same issues.
Thanks in advance, look forward to any help and advice.
sharvey02 is offline
post #2432 of 2656 Old 04-28-2013, 12:24 PM
nbnt's Avatar
Just a quick question, when playing 24fps movies, is it better (less juddering etc) to send 24hz signal to this TV, or 60hz?
I searched for an answer but couldn't find a solid one.
nbnt is offline
post #2433 of 2656 Old 04-28-2013, 12:48 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
in the PICTURE Menu, the choices are 60 and 48; for me 48 is unwatchable, give it a try with some 1080p/24 material and let us know your experience
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #2434 of 2656 Old 04-28-2013, 01:03 PM
nbnt's Avatar
Thanks for the reply, but I don't have such option, is this only on the US model? Mine accepts 1080p/24hz signal.
nbnt is offline
post #2435 of 2656 Old 04-28-2013, 01:07 PM
Quoted: 197 Post(s)
Liked: 511
yes, mine is a uS version, where are you?
post #2436 of 2656 Old 04-28-2013, 01:10 PM
nbnt's Avatar
In ME, so mine is probably a UK one.
nbnt is offline
post #2437 of 2656 Old 04-28-2013, 01:21 PM
Quoted: 197 Post(s)
Liked: 511
sorry, I can't be of any help
post #2438 of 2656 Old 04-28-2013, 05:24 PM
Golfdad123's Avatar
Are there any UT50 owners out there who also own a 2013 S60 model? I've read good reviews of the S60 and wondering if they'd be that much better than my UT50 (I doubt it). I have a few days left before my 90 days are up at Costco. I've been happy with my UT50, just curious if anyone has seen both in a home environment.
Golfdad123 is offline
post #2439 of 2656 Old 04-29-2013, 12:04 PM
Baron Blood's Avatar
Quoted: 60 Post(s)
Try asking at the AVForum in the UK
Baron Blood is offline
post #2440 of 2656 Old 04-29-2013, 10:05 PM
Muadib2012's Avatar
If you do try the Panasonic glasses, let us know how that works out please.
I haven't used the panny glasses yet because I found the XPAND YOUniversal Electronic 3D Eyewear and I tried them. well they didn't work, I will return them and ask the panny. its sad because I really liked them, they look more resistant, comfortable and, they block more unnecessary light from the sides.
Muadib2012 is offline
post #2441 of 2656 Old 04-29-2013, 10:13 PM
Muadib2012's Avatar
Originally Posted by hellmonkey View Post
Quick question, Im going to be purchasing a wall mount for my tv. Does the tv come with wall mounting screws, or do those come with the wall mount itself?
the screws comes with the mount wall kit. in amazom you can find it for 27.99 and it supports Panasonics plasmas up to 65". I had that one
post #2442 of 2656 Old 04-30-2013, 02:00 PM
Monoaural's Avatar
For those having issues with loud buzzing, mine was covered under warranty. Tech said he knew exactly what it was, and replaced all the screws with ones that have lockwashers. Nice and quiet, just a little tiny buzz when you are right next to the screen now. My loud buzzing didn't pop up until I rearranged the living room and moved the tv.
Monoaural is offline
post #2443 of 2656 Old 05-01-2013, 02:12 PM
Quoted: 197 Post(s)
Liked: 511
OK, the SAMSUNG cool.gif glasses work fine. Tried CARS2 3D, Panasonic 3D Material from Net, and Comcast 3D On-Demand, NO (0) problems, paired in about 2 seconds. biggrin.gif
http://www.amazon.com/gp/product/B00BIP816Q/ref=ox_ya_os_product
they do NOT Fold, so I stored them in the handy, dandy Amazon shipping box... wink.gifsmile.giftongue.gifbiggrin.gif
post #2444 of 2656 Old 05-01-2013, 05:09 PM
Rice Rocket's Avatar
Lots of reviews of UT50 compatible 3D glasses here: Panasonic 2012 Compatible 3D Glasse
My recommendation: For $29, get the more comfortable and rechargeable Xpand X105BT from Amazon.
Rice Rocket is offline
post #2445 of 2656 Old 05-04-2013, 09:45 AM
generallee's Avatar
Glad they work for U. I need to get a small pair for when my granddaughter visits and a couple of cheap spare's for visitors.
I have a new Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player
also and last night ran my first true 3D movie "Life of Pi". It was super......but I must admit I will use 3D only on
special occasions. The Panny glasses worked fine but half way through the movie the sync icon appeared on the screen to let me know that the battery was at 50 %.
Since I am still learning I guess I need to go to another forum to find out what the correct setting for 3D depth should be. I think the options are 0 to 4. The movie looked like it had correct depth at the default settings.
Another, quirk I need to understand is when the player started the TV wanted to know if I should select BD, something else or full screen 3D. While I was trying to figure this out, the default 3 D message appeared on the screen so I had to fish for the TV remote to make that message go away and by the time this task was done, the BD, something else, full screen 3D option had gone away. I am guessing that the questions were originating from the Panny TV and not from the 3D player.
The player does turn the Panny TV ON and OFF and also controls the volume on the sound bar but the message "speakers Off" message appears every time the volume is adjusted. (Duh!) Is there a way to turn this message off (without turning the internal speakers on again)? The ehelp is almost as worthless (but not quite) as the Denon AVR setup manuals.
generallee is offline
post #2446 of 2656 Old 05-04-2013, 03:33 PM
morphinapg's Avatar
Quoted: 1317 Post(s)
Liked: 820
Those settings don't change depth, they change convergence. In other words, they adjust the image forwards or backwards in 3D. If you adjust the image forwards, then objects originally intended to be at screen depth will appear in front of the screen. If it's adjusted backward, then those objects will appear to be located inside the screen. Default preserves the original artistic intent, so I tend to stay with that. Adjusting it can have some unnatural effects on the edges of the screen as well.
Living Room: Sony XBR65X930D, Sony HTCT780, Base PS4, Philips BDP7501
Bedroom: LG OLED55C6P, Denon AVR-X1300W, PS4 Pro, Philips BDP7502, AV.io 4K
Check out my video game movie edits
morphinapg is offline
post #2447 of 2656 Old 05-05-2013, 08:54 AM
ProfD's Avatar
Quoted: 25 Post(s)
What are the best wall mounting kits for a p50ut50? Thanks!
ProfD is offline
post #2448 of 2656 Old 05-05-2013, 09:23 AM
Quoted: 197 Post(s)
Liked: 511
Don't know about BEST, but some of the best prices @ monoprice
post #2449 of 2656 Old 05-05-2013, 09:43 AM
ProfD's Avatar
Quoted: 25 Post(s)
Accidental post.
ProfD is offline
post #2450 of 2656 Old 05-05-2013, 09:43 AM
ProfD's Avatar
Quoted: 25 Post(s)
Whay about the even cheaper mounts for sale on amazon? Many of them have free shipping and tons of positive reviews.
I don't want to overpay... but I also don't want to buy a wall mount for my p50ut50 that is "too cheap" and it falls off the wall or something...
ProfD is offline
post #2451 of 2656 Old 05-05-2013, 10:10 AM
Quoted: 197 Post(s)
Liked: 511
Mine's on a built in bookshelf; maybe someone else can help.
post #2452 of 2656 Old 05-06-2013, 11:46 AM
Quoted: 60 Post(s)
I've got a question about the USB port.
Will it play EXFAT files?
I have a friend who is going to send me a movie on a 32GB USB drive but he can only record it reformatting the drive stick to EXFAT.
I know my Oppo won't play it but what about the UT50?
Anyone know?
post #2453 of 2656 Old 05-07-2013, 01:37 PM
jaycam's Avatar
Hello, I'm wondering if any one else uses the Hulu Plus app on their UT50. I have Comcast in the Chicago area; they recently bumped up their speed to about 25mbps. With Hulu I've had to lower the quality to SD. With either of the HD settings I get bad stuttering and long buffer times. I read about DNS settings can affect it but I've changed them and the issue still persists. Any one have any other ideas?
jaycam is offline
post #2454 of 2656 Old 05-18-2013, 09:43 AM
mckellyb's Avatar
I've had the UT50 for about three weeks, now, and, well...WOW!
I mean, it's amazing. Still waiting on my HD DirecTV receiver, but local broadcast HD is almost disturbingly clear.
However, I've run into odd behaviour surrounding USB/SD card. Using the media player in the TV, it tends to display only one, on rare occasion two, files on either drive, even thought there may be 15 files on it. All are the same format, file names are 'normal', all variable sizes, pressing the INFO button shows this is file 1/1, folder name is /, and number of files is accurate.
Unfortunately, the manual is not helpful stating: How data is displayed differs depending on data storage conditions.
There is not clue one about what affects it and how. Has anyone figured this out, or is it limited to having one file on, in this case, a 64GB SD card, at a time.
Sorry for asking for help on a first post, but this thread is so detailed, it's helped me incredibly, and is mighty comprehensive.
edit: Ah, HA!! I see .mp4 and .vob files work, but .avi do not. Got it.
mckellyb is offline
post #2455 of 2656 Old 05-18-2013, 07:24 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
.avi may not work because it's just a container like .mkv, it's not a codec or format. If the files were MPEG-2 with AC-3 audio, I would expect it to work. If it's DIVX or XVID then it may not recognize the codec.
anikun07 is offline
post #2456 of 2656 Old 05-19-2013, 11:26 AM
Sushihunter's Avatar
Originally Posted by Jeff Jamieson View Post
Anyone with any experiences buying a refurbished/retail return UT50? I've found a 55UT50 in my area for $599, which seems like an incredible deal, but it does not have a manufacturer warranty. It does have a one year inhouse warranty from the store however. My understanding from the stores website is that all their products are tested and in 100% working order.
http://www.openbox.ca/product_info.php?products_id=644
Any input apprecieated
I have a couple of friends who have bought from OpenBox.
One is fine after 6 months - no problems.
Second one had the TV fail after a couple of months and OpenBox replaced it with another TV. They did have to go to a second store after the first one refused to replace it though. I guess it depends on which salesman/store you are dealing with.
I bought my 60UT50 next door at Visions Electronics. I wanted the full one year warranty, plus the extra for paying with a MasterCard - and I got AirMiles.
YMMV
Sushihunter is offline
post #2457 of 2656 Old 05-22-2013, 11:16 AM
rampras's Avatar
Wireless Adapter
TYWL20U seems to be out of stock everywhere. Are there any alternative USB wifi dongles. I have a P55UT50 ...
rampras is offline
post #2458 of 2656 Old 05-22-2013, 11:21 AM
chunon's Avatar
Quoted: 2494 Post(s)
Liked: 2231
Originally Posted by rampras View Post
Wireless Adapter
Pretty sure there is a netgear dongle that will work don't recall the model number
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #2459 of 2656 Old 05-22-2013, 04:14 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I would contact Panasonic and see if there's a new model for this year that compatible with the TV.
anikun07 is offline
post #2460 of 2656 Old 05-29-2013, 09:34 AM
Jerrym303's Avatar
Wireless Adapter
Hi, I got a n5hbz0000055 panasonic adapter with my GT30 set. I never used it as I wire directly. I took it out the bag to test it on my new TC-P55UT50 and it was recognized immediately, so this one works. I have mine on ebay right now, PM me her if interested.
Jerrym303 is offline
Panasonic , Plasma Hdtv , Displays , Panasonic Viera Tc P60ut50 Plasma Tv
