Official Panasonic UT50 Series Discussion Thread - Page 89 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #2641 of 2656 Old 03-03-2015, 08:56 AM
Baron Blood's Avatar
Quoted: 60 Post(s)
Originally Posted by morphinapg View Post
I guess they were trying to say Windows Media Player in Vista doesn't support DLNA like it does in Windows 7 and 8, so you'll need something else like the other programs that were mentioned. I don't personally have any experience with those however so I can't say what's good.
Ok...
I think I'll go the Chromecast Dongle route.
Thank you VERY much for helping me.
Baron Blood is offline
post #2642 of 2656 Old 03-03-2015, 09:13 AM
whipit's Avatar
Quoted: 100 Post(s)
Liked: 86
Originally Posted by Baron Blood View Post
Do I need a DLNA server with this new setup being discussed lately where I connect with a ethernet cable to my router and stream with Windows Media Player?
Thanks for the Wild Media Server suggestion but I don't want to pay for it.
The DLNA on the tv needs some kind of server when hooked to a PC. So you'll need Win 7 or a server program.on your Vista. I didn't know Wild was a pay server. PS3 media server is free.
The update 'should' be for internet apps so they work properly but yea over the years I've heard of peoples tv's having issues, pretty rare though.
whipit is offline
post #2643 of 2656 Old 03-03-2015, 09:58 AM
whipit's Avatar
Quoted: 100 Post(s)
Liked: 86
Ok...
Shortly after chromecasts release they disabled local file streaming from a pc. I never used one but there's a thread here at AVS on the chromecast.
Chromecast: Google in the Living Room, Take Two
whipit is offline
post #2644 of 2656 Old 03-03-2015, 12:26 PM
Quoted: 60 Post(s)
When I heard about Allcast I Googled it and apparently there WAS a fallout but they made up (worked out a deal) and now work together again
I joined the Google forum the other day and asked the question if Allcast would work on Windows Vista and the answer was yes.
Anyways, I'll make sure the Dongle can be returned if it doesn't work out.
Thanks for the heads up anyways.
whipit likes this.
post #2645 of 2656 Old 03-21-2015, 07:52 PM
Liked: 0
Netflix issue: I previously was able to stream 1080p on my UT50 55" with Dolby 5.1 I can now only stream 720. Netflix says there's no problem on their end. They can see the tv attempting to pull 1080 then falling back to 720. I have a 100 mbps connection and I consistently get 90-100 on tests. I can stream 1080 on the YouTube app but not on Netflix, which is my primary use for the TV.
BTW, OTA HD looks awesome on this tv, better than any cable connection I've ever had -- including Fios. Too bad plasmas are the walking dead.
Thanks in advance for any suggestions.
Cheers,
Tom
Thomas Rossi is offline
post #2646 of 2656 Old 06-13-2015, 01:30 PM
12Bass's Avatar
Liked: 8
Although the above post is a little old, I can confirm that Netflix only streams a maximum of 720p to my TC-P42UT50 with a 25Mbps connection. Because of this, and the slow Viera Connect interface, I am using a BDP-S6200 for streaming purposes, plus the Sony also streams 3D Netflix content. Not sure, but I suspect that the 1080p problem is on Panasonic's end (possibly firmware) and that they are not interested in fixing anything on their 2012 models at this point.
12Bass is offline
post #2647 of 2656 Old 06-16-2015, 11:07 AM
Bruce2019's Avatar
Quoted: 350 Post(s)
Liked: 194
You can use your game console, or app player, there are tons of possibilities.
Netflix is also superior to all my cable hd channels.
Bruce2019 is offline
post #2648 of 2656 Old 07-01-2015, 08:00 AM
VarmintCong's Avatar
Guys, my 2 year old took a Maglite to my UT50, screen's cracked, my wife says it won't power on at all, like it doesn't even make a noise when you turn it on. Could this be just a power surge and it just needs to be unplugged and plugged back in?
If it's dead, any hope of getting it repaired? I refuse to buy an LCD.
VarmintCong is offline
post #2649 of 2656 Old 01-13-2016, 05:53 PM
Quoted: 60 Post(s)
Man, that sucks.
I have no idea but it kinda puts my problem in perspective.
Yesterday I thought I was unplugging my BD Player HDMI cord while the TV was on and set to Cable.
It ended up being the cable so when I plugged it back in my calibrated settings were gone.
Fortunately, most of what happened (I hope) was it switched from Cinema to Vivid. (I only calibrated Cinema)
Switching back fixed the colors.
However, now I'm being bothered by certain shows where they're not as bright as I'm use to.
I remember someone kindly posted here a simple switch in the hidden menu that brightens the TV but damned if I can remember or find it.
I certainly don't want to do any other tweaking.
I did find out how to access the service again so I'm hoping someone will be kind enough to remind me what that simple adjustment was that brightens the picture.
I'd contact my calibration guy but I'm having trouble finding him too since I can't remember his name.
It sucks getting old.
post #2650 of 2656 Old 01-13-2016, 06:05 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I don't know which setting your referring to, but as far as calibration goes, only warm 2 and cool 2 are the only color corrections. Brightness and contrast can be adjusted in the picture mode settings (cinema, vivid). Cinema is the only mode that has a good gamma curve. It's always up to the viewer as to the preferred picture, but for picture reproduction there's only one with room for adjustments of brightness/contrast.
anikun07 is offline
post #2651 of 2656 Old 01-13-2016, 06:27 PM
Quoted: 60 Post(s)
Hi Anikun,
It was a one click change in the hidden service menu (hold down volume and click info 3 times)
It made the TV slightly brighter and I seem to recall someone saying the downside was the TV will wear out faster.
post #2652 of 2656 Old 01-14-2016, 02:41 AM
whipit's Avatar
Quoted: 100 Post(s)
Liked: 86
@ Baron: Is there anything on these pages that sounds familiar?
service menu.pdf
whipit is offline
post #2653 of 2656 Old 01-14-2016, 07:26 AM - Thread Starter
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 520 Post(s)
Liked: 775
I'd contact my calibration guy but I'm having trouble finding him too since I can't remember his name. It sucks getting old.
I don't have an answer but noticed you have the same Avatar as mdavej over in the remotes forum:
Acoustic Research XSight Remote
I knew i saw that somewhere . . .
_______________________________________
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #2654 of 2656 Old 01-14-2016, 09:23 AM
Quoted: 60 Post(s)
Attachment 1183674
Cheers.
Unfortunately no though
I did find the calibrator guy online though...I'll contact him.
post #2655 of 2656 Old 01-14-2016, 10:30 AM
whipit's Avatar
Quoted: 100 Post(s)
Liked: 86
Cheers.
Oh well, it was worth a try. If you find out what it is please post that info here, thx
whipit is offline
post #2656 of 2656 Old 01-14-2016, 12:09 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
^^^ Yes, please!!!
SanchoPanza is offline
Panasonic , Plasma Hdtv , Displays , Panasonic Viera Tc P60ut50 Plasma Tv
