Quick Panasonic 42ST30 question - AVS Forum
post #1 of 4 Old 04-21-2012, 12:40 PM - Thread Starter
Dan134's Avatar
Hi all,
Just purchased the 42ST30 plasma last night and it's amazing...easily the best TV I've ever had (or even really seen).
I'm in the process of breaking it in but had a quick question I'm hoping one of you has the answer to:
Is there a way to adjust the H and V screen position? If so, does it need to be done from the service menu? Let me know! Thanks.
Dan134 is offline
post #2 of 4 Old 04-21-2012, 01:04 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 73 Post(s)
Liked: 462
Originally Posted by Dan134 View Post
Hi all, Just purchased the 42ST30 plasma last night...Is there a way to adjust the H and V screen position? If so, does it need to be done from the service menu?
It cannot be done, not even in the Service Menu. Why do you want to do this? Source problem?
Randy
TC-P55ST60, TC-P50GT50, TC-P46G10, TH-42PZ700U, TH-42PX50U, HP LC2600N, TiVo Series3, TWC Cisco 8742HDC DVR, Onkyo TX-SR333, URC R40 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 4 Old 04-21-2012, 01:13 PM - Thread Starter
Dan134's Avatar
When I change the HD size with my PS3 hooked up via HDMI, the actual image seems to shift horizontally to the left or right a little bit. I'm not sure what the technical term is, but the image is just slightly too small to fit on the screen, but isn't centered.
Again, not a huge deal. Doesn't bother me too much, but the issue piqued my interest.
Dan134 is offline
post #4 of 4 Old 04-23-2012, 02:08 AM - Thread Starter
Dan134's Avatar
I figured it out, my bad. It's the pixel shift orbiter. I thought something was wrong with my screen or something. =)
Dan134 is offline
User Tag List
