Official Panasonic VT50 owners thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
Old 05-10-2012, 04:31 PM - Thread Starter
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
Just enjoyed avatar on mine. No issues that I noted just enjoying!! Time to go play with some 3d now.. Crappy pic from my iPad... Apparently I left the cable box on and the glasses plugged in for it to.
CaTaSTrOphiK is offline
Old 05-10-2012, 04:42 PM
General Kenobi's Avatar
Quoted: 357 Post(s)
Liked: 640
Are all the inputs in the side, nothing facing down? Seems like a pain to feed the cables through the wall this way... guess some right angle adapters will be a must.
Looks very nice though, very nice.
Kenobi's 31 Days of Horror:
2012
2011
2010
2009
General Kenobi is offline
Old 05-10-2012, 04:43 PM
Tempest261's Avatar
Liked: 26
Getting a little concerned about the various reports of a "side vertical band". Can someone with this issue please take a good picture of the problem?
Calibration Equipment:
Meters: X-rite i1 Pro 2, X-rite i1 Display Pro
Software: Spectracal Calman DIY, ControlCAL
Televisions:
Panasonic TC-P65VT50 (currently own)
Samsung UN55D8000 (returned) Calibration and Settings Thread
Plasma IR Removal:
Post 1 - Post 2 - Post 3
Tempest261 is offline
Old 05-10-2012, 04:45 PM
weedeater's Avatar
Originally Posted by plasmaFTW View Post
And people that are worried about image retention are being unrealistic. I have an older ST that I properly broke in and use primarily for a PC monitor. I don't even have cable or satellite. I use it for my PC, Blu-ray, and gaming . You'll be fine watching football all day long.
B
PS. More pics to follow as I get it running in the backroom for the breakin slides.
I think the reds are a little harsh, but the facetones are nice.
weedeater is offline
Old 05-10-2012, 04:53 PM
Kadath's Avatar
Quoted: 330 Post(s)
Liked: 203
Originally Posted by htwaits View Post
I'm not sure I understand your reply.
He asked for a generic idea of what calibrations cost, you suggested he take it to PMs and 3 pages later and nobody else even replied. Seemed like a chilling effect. That's why I rolled eyes. Might not have been intentional but that seems to be the result.
Buncha savages in this town....
Sam Posten
Kadath is offline
Old 05-10-2012, 04:54 PM
WOLVERNOLE's Avatar
Quoted: 66 Post(s)
Hmmm, why do the colors in your pictures look just like the color faults in my monitor?
WOLVERNOLE is offline
Old 05-10-2012, 04:57 PM
DesertDog's Avatar
Originally Posted by weedeater View Post
Rumor has it that the set is compatible with a BlueTooth keyboard. Can you try that? Or maybe try a USB keyboard/mouse?
I don't have a bluetooth keyboard, but I can confirm that a USB one works. I just plugged mine in and the set right away prompted me for which type of keyboard (language type). It was fully usable in the web browser after that. Typing worked and the arrow keys moved the cursor for navigation. Unfortunately I wasn't so lucky with my trackball (Kensington ExpertMouse). It wasn't recognized and will not control the cursor. Maybe a basic mouse would work.
I also just tried loading twit.tv's live stream which is powered by ustream. The player worked correctly, but once again the full screen toggle didn't work. So far rev3 is the only one I've found that it works at all.
DesertDog is offline
Old 05-10-2012, 04:58 PM
weedeater's Avatar
Originally Posted by savora View Post
I have a couple of questions about calibration.
1) If you get it calibrated and then shipped, is that ok to do?
2) If there is a firmware update, do you have to get the tv calibrated again?
Sorry, I am a novice about this stuff.
1) Mr. Rogo answered that for you.
2) No. But it should not come as a surprise that the settings may return to factory values. BUT you will have a copy of the calibrated settings that you can re-enter and go from there.
Old 05-10-2012, 05:09 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2013 Post(s)
Liked: 2182
Originally Posted by stepmback View Post
How is the off angle viewing of the vt50? I plan on getting a 65vt50 some time in the next couple of months but am concerned about single pane of glass causing issues with viewing off angle. My setup would put one seat off angle by as much as 30 degrees from straight ahead.
Just fine, like all plasma's
Cleveland Plasma is offline
Old 05-10-2012, 05:20 PM
Chad B's Avatar
Quoted: 496 Post(s)
Liked: 1195
Originally Posted by Tempest261 View Post
Anyway, here's my question: I definitely have the patience and I think I have the know-how (or I'm getting close) to do a pretty good calibration manually with the standard DIY license... however the Autocal deal for this month (1/2 off) is somewhat enticing. In your opinion, can Autocal do a better calibration than one done by hand, especially by an amateur like me? What about a pro like you or D-nice? How does it truly compare? On top of that, is it consistent with it's results with something like the VT50?
In my experience, the correct groundwork has to be laid in order for autocal to work well. I did not feel that the bundled layouts were helpful in that regard at all. I attempted to do that with a custom workflow I made just for the VT30, and I will say that even in the one I made it is hard to get across my intent.
Once the correct groundwork has been laid, the autocal makes things easier and faster, at least for grayscale and gamma from 20-100%. Often when it gets down to 10% I find I can do a faster and more accurate job by stopping it and taking over manually, partially because I know what to expect and partially because autocal takes such small steps and readings take a while at 10%.
This is very important, esp on the VT30, and is totally overlooked in the bundled workflows: the autocal results have to be verified after it's done and the results have to be fine tuned, and depending on how much of a perfectionist you are it may take from a minimum of 2 passes to over a dozen fine tuning passes after autocal has done it's thing.
The autocal doesn't do so well with CMS, though it's not a total failure there. It just doesn't have a human brain.
So to answer your question, the autocal will not get you the results that D-Nice and I get. In fact, it can leave color banding and sunburnt skin tones as well as any BB calibrator. But it can be a tool, when used in certain ways, that can make things a little easier and faster.
I am commenting mostly on my experience with the VT30, since the VT50 had the calibration issues.
Chad B is online now
Old 05-10-2012, 05:26 PM
Tempest261's Avatar
Liked: 26
Thanks Chad. That's what I needed to hear. I'll wait a few years for them to sort this feature out. I'd rather be patient and do it right by hand. Besides, I find it kind of fun .
Televisions:
Plasma IR Removal:
Old 05-10-2012, 05:33 PM
subavision212's Avatar
Quoted: 62 Post(s)
Liked: 38
Can anyone explain the advantage of the VT one sheet design? Is it purely cosmetic? And how different would images be from on the GT series. Thanks.
subavision212 is offline
Nethawk's Avatar
Liked: 118
Chad, if you did it all over again would you buy the VT or stick with the GT?
Nethawk is offline
Old 05-10-2012, 05:45 PM
turbe's Avatar
Liked: 95
Also, people have to keep in mind that after the process, you will be changing Contrast and Brightness, and...
Originally Posted by D-Nice View Post
After the auto cal, you are suppose to set it to whatever your preferred/correct contrast and brightness setting should be. Well, changing the contrast and brightness settings after the calibration voids the calibration as the display will no longer read what it did when the contrast and brightness were set to.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
Old 05-10-2012, 05:56 PM
plasmaFTW's Avatar
I have the top end Logitech BT keyboard and mouse. I'll give it a whirl later and report back. I'm at my discount generator right now (work).
B
plasmaFTW is offline
Old 05-10-2012, 05:59 PM
swminn7's Avatar
I accidently posted a similiar message in the GT50 forum, so please bear with me. If the GT50 and VT50 THX settngs are the same, and using the out-of-the-box settings, would I be correct in inferring from previous postings that I use THX Bright Room settings for day, and THX Cinema for night for my upcoming VT50? My understanding is that these settings give very good results if we do not want to calibrate professionally.
swminn7 is offline
HAmmer32261's Avatar
Hard getting used to how much darker the picture is than my old Samsung LCD
I got it in THX cinema mode.
John
HAmmer32261 is offline
Old 05-10-2012, 06:08 PM
TitusTroy's Avatar
Quoted: 1027 Post(s)
Liked: 860
Originally Posted by PathofNeo View Post
I'm in the same boat. I'm interested in the 55VT50 but really wish they made a 60". A 65VT50 is probably overkill (mainly price) for me and a 55VT50 is barely big enough
I agree...60" is the ideal size for me...anything bigger would be best served in a dedicated home theater type of environment
TitusTroy is offline
Old 05-10-2012, 06:20 PM
rogo's Avatar
Quoted: 1595 Post(s)
Liked: 1791
So, the "one-sheet" design itself won't affect picture quality. Essentially, the VT has a single piece of glass that is also the "bezel" surround the image.
The GT has a separate plastic bezel.
The two displays, however, have different filters and some different capabilities settings-wise. Those will affect image quality. How much? Someone who has seen both could answer better than I. What I can say is without a very critical eye the answer is going to be "not a ton". And even with a critical eye the answer will still be something less than earth shattering.
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is online now
Old 05-10-2012, 06:32 PM
TitusTroy's Avatar
Liked: 860
Originally Posted by DaverJ View Post
I understand this is a very subjective question, but I'm wrestling with the same thing. I have no way of seeing the VT30 and the VT50 side-by-side, so I would love to hear an informed, critical comparison of the two.
If the VT50 was "<10% better" than the VT30 OOTB, my decision would be easy - go with the VT50. But ">5% better", it's a hard call if that's worth $1000.
I currently have a VT30 and for me the question of upgrading to a VT50 would require more then a 10% improvement...for 'only' 10% it would be a no brainer to keep my VT30
Old 05-10-2012, 06:35 PM
Quoted: 62 Post(s)
Liked: 38
Thanks so much for the info. Looks like I'll be getting the 55GT50 based on your comments. I just want a new display to replace the 42ST30 in my living room and the 55GT50 has everything I want.
Old 05-10-2012, 06:45 PM
6SpeedTA95's Avatar
Quoted: 145 Post(s)
Liked: 45
What makes a tv 10% better vs 5% better or 50% better? that's completely subjective...
6SpeedTA95 is offline
Old 05-10-2012, 06:46 PM
Adamd's Avatar
Quoted: 594 Post(s)
Liked: 375
I'm so jealous of you guys in the US getting your vt50 already. Stupid Canada making me wait, Im almost ready to drive over the border and pick one up.
Adamd is offline
Old 05-10-2012, 06:48 PM
TitusTroy's Avatar
Liked: 860
where did I say it wasn't subjective?...I was stating that a 10% difference would not be enough for me
Old 05-10-2012, 06:55 PM
Nick Papagorgio's Avatar
45 hours to go and I'll be done with the slides. Then I'm watching my 65" VT50 all weekend.
Nick Papagorgio is offline
6SpeedTA95's Avatar
Quoted: 145 Post(s)
Liked: 45
Yeah, I get what you're saying, my point is one guys 10% is another guys barely noticeable is another guys 50% difference. Only way you'll know is to check them out yourself extensively and compare it to your VT30. The data seems to suggest it is significantly improved and the VT30 was no slouch.
Just be careful taking someone's 10% into consideration and realize that they may value something different than yourself. The improved brightness, black levels and shadow detail seem to make it worth the upgrade IMO...but I don't have a VT30 but I've viewed them a fair amount.
Old 05-10-2012, 07:09 PM
TitusTroy's Avatar
Liked: 860
if I didn't currently have a VT30 it would be a no brainer to get the VT50...it's not a question of is it better then the VT30- it definitely is...it's more a question of is it enough for me to ditch my current set and get a new one...the great thing is that the VT50 is launching at prices that are cheaper then when I bought my VT30 at launch
I'm mostly concerned about IR on the VT50...I don't want to buy it if it has the same IR issues as my current VT30
Old 05-10-2012, 07:18 PM
Tempest261's Avatar
Liked: 26
Yes, the VT50 is better, but whatever the case is, do you like your VT30?
If so, I'd 100% stick with it and be happy. It should last you a good 3-10 years, and by then OLED will be in full-swing. Despite what anyone tells you, the VT50 won't hold a candle to a good OLED. You don't want to play this upgrade game. Next year we'll all be jealous of the VT60 buyers (or even OLED displays).
Televisions:
Plasma IR Removal:
Old 05-10-2012, 08:32 PM
Industry Insider
Liked: 2182
"Usually" most models look a little better as far as overall picture year after year. One may want to update every year. Surely, one would get a gadget or two for sure. If you can afford it comfortably, why not. If not wait for a few models to pass by.........
Old 05-10-2012, 08:34 PM
Mkilbride's Avatar
Quoted: 55 Post(s)
Wish I could afford a new one every year.
Got the ST30 and pretty happy with it, but weird part is, seems to be looking worse as time goes on, dunno, only watching 1080p sources...
Mkilbride is offline
Panasonic , Panasonic Viera Tc P55vt50 , Plasma Hdtv , Displays , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv
