Official Panasonic VT50 owners thread - Page 310 - AVS Forum | Home Theater Discussions And Reviews
 89Likes
post #9271 of 14203 Old 01-15-2013, 06:27 PM
Einskaldir's Avatar
Appreciate the responses guys! Thanks!
I just returned from my local Best Buy and I have to say, that was an easy task. I just snuck in right before they closed and they have me set up to receive another this Saturday. As was mentioned, since I have the box and packing materials, the delivery guys will go ahead and repack the damaged TV themselves so I won't bother disassembling it and trying to do it with my wife. I didn't expect it to be this easy to be honest as I've read about horror stories, although I think most of those come at or after the 30 day period. And to clarify, the new 30 day return period started tonight so it reset. I just wanted to make sure you guys knew in case some of you were curious.
Here's to hoping the next TV won't have any dead pixels (and won't be dropped 2 inches against the floor either due to faulty stand construction by the delivery guys!). At least now I have a flash drive that I know works and which I can pop in as soon as they unpack and setup the new TV to check for more dead pixels.
Einskaldir is offline
post #9272 of 14203 Old 01-15-2013, 07:03 PM
BadClams's Avatar
Posted this on the other-forum, but it's kinda dead... thought I'd ask here too:
Just opened my 65VT50 and wondering: does it come with just a single smallish multi language owners guide??? Thought there'd be a big-book-o-info with it?
Gracias
B
BadClams is offline
post #9273 of 14203 Old 01-15-2013, 07:07 PM
robnix's Avatar
Quoted: 740 Post(s)
Liked: 549
Gracias
B
There's a PDF manual on the product page on the Panasonic website.
Looky here!
robnix is offline
post #9274 of 14203 Old 01-15-2013, 07:13 PM
jjk454ss's Avatar
Originally Posted by gla4g View Post
Just got my 65" VT50. The slideshow popped up when I inserted the SD card. But how do I get to the slide show settings??
I know this is 7 months later, but can someone help with this? I don't see these settings either.
Slideshow Settings
Frame: Off
Photo Effect: Off
Transition Effect: Off
Photo Size: Normal
Burst Playback: Off
Display Interval: Slow
Repeat Playback: On
Edit: Found them under Viera Tools>Media Player>Photos, then hit the Option button on the remote.
jjk454ss is offline
post #9275 of 14203 Old 01-15-2013, 07:19 PM
nabsltd's Avatar
As far as I can tell, the PDF manual is the source for the "Help" text built in to the TV. It's good for quick checking of something, but not really for reading the whole thing.
Neither is good for explaining technical details. If you don't already know what the jargon means, the manual won't help.
nabsltd is offline
post #9276 of 14203 Old 01-15-2013, 07:31 PM
billmich's Avatar
Quoted: 261 Post(s)
Liked: 60
Originally Posted by whipit View Post
All the 2012's and up will be bluetooth so the 2013 tv's should be compatible with 2012 glasses. Pansonic is coming out with a fifth gen set of glasses to go along with the new tv's, most likely some minor improvements.
I'm more concerned about getting extra pairs for my 2012 set
billmich is offline
post #9277 of 14203 Old 01-15-2013, 07:48 PM
robnix's Avatar
Quoted: 740 Post(s)
Liked: 549
That's the best they have for the consumer. This forum is your best bet for legitimate technical questions.
Looky here!
robnix is offline
post #9278 of 14203 Old 01-15-2013, 07:53 PM
jjk454ss's Avatar
I downloaded D-nices Panel Prep Slides, I copy them to a SD Card, but when I go to play the slideshow my TV shows extra files and when the slideshow gets to them it displays "Cannot read file". I formatted the sd card, I tried putting the slides into a folder and just playing the pics in the folder, I still get the slideshow trying o play these files and is playing this message. Any ideas?
jjk454ss is offline
post #9279 of 14203 Old 01-15-2013, 07:56 PM
BadClams's Avatar
They don't play nice when loaded via a Mac. Use a PC and you're good to go.
BadClams is offline
post #9280 of 14203 Old 01-15-2013, 08:10 PM
Shagz's Avatar
FYI, using a usb flash drive to run .mp4 pixel jogger and whitescreen wash. i did notice when the movie loops. there is a top bar that posts for a few seconds that the movie looped and the time.
BE CAREFUL., i did notice slight IR with the 1:00 time of the move in the upper right of my screen.
Slide pics in slideshow do not show the loading bar when they looped.
Shagz is offline
post #9281 of 14203 Old 01-16-2013, 03:21 AM
diamondbacvenomx's Avatar
Originally Posted by mo949 View Post
So this is a tough one to answer and you'll probably get lots of different viewpoints, but I'll share my answer. In the last two months I've owned both my first LCD/LED (samsung ES8000) and my first plasma (vt50 obviously). I returned the LCD for banding defects and ended up with the vt50. When I was in the showroom its funny how all I could appreciate was the brightness of my LCD. When I had to return it, I was quite disappointed to realize that getting a banding free one was impossible too. But having had both tvs in my living room for periods of time I've gotten to appreciate how much better the plasma picture really is and how not so subtle good PQ is once you've had to stare at it for a couple of hours with varied content. But I will say, my initial choice of LCD over plasma was based more on fear of IR than just the perceived PQ quality of the LCD. Thankfully I've overcome that fear, but recognize for different people and different viewing habits it could be a deal breaker.
The LCD had some serious pop on some scenes and I was a bit worried that I would never get that back with the new plasma vt. Now that I have my VT setup right I've got that 'pop' back. Although the LCD is able to produce much nicer brightness, the vt50 when calibrated seems to have the same brightness as my LCD when I had it dialed in. Where the LCD starts to fall down, imo, is in many scenes where its processors can't tweak the picture well (dynamic contrast etc) you end up with that washed out look because you are forced to see the tv picture closer to its raw form and you end up with very bad contrast since the tv is not allowed to cheat with its tweaks and is forced to use closer to its native contrast. One of the things I appreciate most about my plasma and its pq is that from scene to scene the colors and black/gray are consistent; the LCD was constantly trying to dim parts of the screen in some scenes via both software and hardware to the point where you would have quite a few cases where a scene is set in one room and when they switched camera angles the processors would make an object that looked light in one scene, dark in the other, and vice versa and the colors would be washed out sometimes, but then pop very well at other times (I really don't miss this).
Also, say you are looking at a field of red beutiful flowers on a scene, I've noticed on the plasma's picture I'm actually seeing all different types/shades of red that I never really noticed on my LCD/LED - could be that they were there before, but the improved contrast of the plasma is just 'highliting' it more for me, I don't really know except to say I see it and appreciate it. So if vivid means more color, then I give it to the plasma again.
So take this for what it is, I'm now biased by my LCD/plasma side by side experience and feel fortunate that I ended up with the plasma.
Hope that helps,
Excellent post. I really appreciate it. I watched transformers and star trek on the LED last night and albeit a great picture, I just dont see any 'POP' in the imagine. Again I've tried almost every setting posted under the official board. I could be chasing a pipe dream but I wont know for sure unless I see it person and take advantage of the exchange program and grab a plasma. I guess if the plasma doesn't satisfy me I can always exchange that back for an LED. Now the trick is which Panny Plasma to get....hrmmm. biggrin.gif
diamondbacvenomx is offline
post #9282 of 14203 Old 01-16-2013, 03:42 AM
mnc
mnc's Avatar
Quoted: 753 Post(s)
Liked: 564
Anyone know what I should set my sony 590 BD players output to; 4:4:4, 4:2:2, or Auto? Would there be any benefit using 4:4:4 and the 1080 Pure Direct together?
NHT speakers, Denon 4520, Panasonic 65VT50, DUAL PSA XS30SE's
mnc is offline
post #9283 of 14203 Old 01-16-2013, 04:21 AM
jjk454ss's Avatar
Thanks, I kind of thought this might be the case, I will have to find a PC to save the files and try again.
jjk454ss is offline
post #9284 of 14203 Old 01-16-2013, 05:12 AM
Adamd's Avatar
Quoted: 719 Post(s)
Liked: 419
I've noticed that my vt50 while on 3d the brightness pulses a bit and goes darker. Its not super noticable but its there. With my 3d glasses off I can not see it happen so it makes me think its maybe the glasses out of sync a little.... Or maybe it's just somthing these glasses do. It's not the normal flicker you get with active glasses because it happens every 3 to 5 seconds. Sometimes if I turn the tv off and on again it will not do it again but other times it won't matter. I'm kind of sensitive to any kind of flicker but I never noticed this with my vt30 and I have ut50 in my bedroom and I could not see it on there. Any help would be great!
Adamd is online now
post #9285 of 14203 Old 01-16-2013, 06:03 AM
calvy2's Avatar
What 3d glasses is every one using for vt50. I see conflicting reports on what the best ones are
calvy2 is offline
post #9286 of 14203 Old 01-16-2013, 06:21 AM
Jagged68's Avatar
I just got my first ones this week for the 2012 Pannys. The only 2 I know of are the Samsung SSG-4100GB and the Panasonic TY-ER3D4MU which are very expensive unless you can find a deal. The Samsung works very well, but they don't totally cover your eyes and can let external light in. They are also run on a single non-rechargeable watch battery. On the plus side, they aren't expensive and are very light on your head.
I may end up getting a bunch of the Samsung unless someone can recommend something better.
Jagged68 is offline
post #9287 of 14203 Old 01-16-2013, 06:21 AM
jjk454ss's Avatar
I was just going to see if anyone has used the Monoprice ones. I was thinking I'd get the Samsung for now since they are so cheap.
jjk454ss is offline
post #9288 of 14203 Old 01-16-2013, 07:57 AM
JohnDG's Avatar
Quoted: 12 Post(s)
I have both. I find that with my glasses (tri-focals) that the Samsungs fit easier over my glasses. External light is not an issue in the evenings, but might be distracting during the day.
I cannot discern a picture quality difference between the two.
jdg
JohnDG is offline
post #9289 of 14203 Old 01-16-2013, 09:08 AM
bryan338's Avatar
Quoted: 23 Post(s)
Any experience good or bad for the monoprice 3d glasses? I cant find any panasonic 3d glasses in my area. Thanks smile.gif
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10909&cs_id=1090901&p_id=9461&seq=1&format=2
bryan338 is offline
post #9290 of 14203 Old 01-16-2013, 09:17 AM
DWBoston's Avatar
Those glasses don't work with the 2012 Panasonic TV's. Those glasses are IR, the 2012 Panasonic glasses are bluetooth-based.
DWBoston is offline
post #9291 of 14203 Old 01-16-2013, 10:13 AM
stevel's Avatar
There is a separate thread for 2012 Panasonic 3D glasses. In it you'll see my experience with the Monoprice BT glasses - they don't work with the VT50.
Steve
stevel is offline
post #9292 of 14203 Old 01-16-2013, 10:32 AM
laulau's Avatar
Quoted: 79 Post(s)
Liked: 122
Also available are the ones from Dimensional Optics that come with a nice case and microfiber cloth.
http://www.dimensionaloptics.com/search.aspx?l=00010001000100090000
or from Amazon
http://www.amazon.com/PANASONIC-Compatible-3ACTIVE%C2%AE-Glasses-2012-Rechargeable/dp/B00A3FVH3G/ref=sr_1_1?ie=UTF8&qid=1358360453&sr=8-1&keywords=dimensional+optics+2012+panasonic
Don't know if they're any good (I own the Pannys and Sammys) so YMMV.
Salk STRT / SongCtr-RT / SongSurr ; Rythmik F12 (x2) (latest ver setup guide) ; HT -- Denon 4520; DSonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; CCast; FireTV; Furman Elite15PFi; Salamander Synergy; Omnimic/REW; CalMAN ::Headphones:: RPi3Digi+ >AGD DAC19 >Cavalli LC >HFM HE400i :: RPi3Digi+Pro >Schiit Bifrost 4490 >Schiit Valhalla >Senn HD600 & HD6XX :: RPi3Digi+Pro >Schiit Mimby >Schiit Vali 2 >Meze 99 Classics :: RPi3Digi+Pro >Schiit Modi2U >Schiit Magni2U >Oppo PM3
laulau is offline
post #9293 of 14203 Old 01-16-2013, 10:41 AM
bhawes's Avatar
I have used the Dimensional Optics 3D glasses for my 65VT50 and they work great!!!
bhawes is offline
post #9294 of 14203 Old 01-16-2013, 11:57 AM
stevel's Avatar
Those look exactly like the Monoprice glasses, though Monoprice doesn't include the case.
Steve
stevel is offline
post #9295 of 14203 Old 01-16-2013, 12:20 PM
scott911's Avatar
Quoted: 13 Post(s)
Hope that helps,
Did you have windows in your viewing room by any chance? If so, any comments on each screen's ability to reject light reflections from a practical standpoint? thanks.
scott911 is offline
post #9296 of 14203 Old 01-16-2013, 02:38 PM
Bluecow003's Avatar
Quoted: 169 Post(s)
Liked: 116
Set it to 4:4:4. The TV is made to handle it according to their marketing material. I don't know about benefits or problems with using 4:4:4 together with 1080 Pure Direct, but that's how I have it set on mine. I also set my Oppo blu-ray player to 30-bit Deep Color too since the VT50 is supposed to be able to handle 30-bit. I believe current blu-rays don't actually use 30-bit Deep Color (or Deep Color at all), but I figured the blu-ray player should be set to output the highest quality that the TV can handle.
Here is the line in Panasonic's marketing material:
Color Reproduction Faithful to the Original
1,080p Pure Direct
The 1,080p Pure Direct function transmits and outputs high-quality YUV 4:4:4 30-bit video signals directly to the TV. This reproduces colors that are highly faithful to the original.
http://shop.panasonic.com/shop/model/TC-P55VT50
7.2.4 Setup | Display: Panasonic TC-P65VT50 plasma | Blu-ray: Oppo UDP-203 | Processor: Anthem AVM60 | Amps: Outlaw 7700, Emotiva XPA-5 Gen 2 | Speakers: Paradigm Prestige (2) 95F's, 55C, (4) 15B's, (4) CI-Elite E65-R (Atmos) | Subs: (2) Rythmik F25's
Bluecow003 is offline
post #9297 of 14203 Old 01-16-2013, 03:31 PM
7thSeal's Avatar
We use the Samsung glasses and the things I noticed during day viewing is your side view isn't blocked very well and I also notice a bit of reflection (can see whats behind me). Nothing I that haven't been able to fix with some black duct tape though. cool.gif
Most of our 3D viewing is at night though and no problems there.
7thSeal is offline
post #9298 of 14203 Old 01-16-2013, 03:40 PM
mnc
mnc's Avatar
Quoted: 753 Post(s)
Liked: 564
1,080p Pure Direct
Thanks I'll try it out!
mnc is offline
post #9299 of 14203 Old 01-16-2013, 06:13 PM
kwffs0's Avatar
I got the 2012 Panasonic glasses but wanted to protect them and went to costco optical dept and they had these cases as extra's. They told me they were to big for most custmers eye glasses so I got them to give me 4 of them for free.[IMG]
kwffs0 is offline
post #9300 of 14203 Old 01-16-2013, 06:49 PM
mo949's Avatar
Liked: 1174
Both screens are glossy. Both will not handle direct sun. I have windows on both side walls perpindicular to my screen location, but I employ my shutters when I watch during the day. There is a 60 watt lamp behind my couch and the vt50 shield rejects the reflection better than the es8000, but it does cause a noticeable difference in the black on the part of the screen that has the reflection. I will say during the daytime and when watching crapp cable with the es you could crank up the backlight and although the picture became nothing I'd watch a good bluray on, it was a nice effect for say CNN or sports (vertical banding ruined this though).
scott911 likes this.
mo949 is offline
Panasonic , Panasonic Viera Tc P55vt50 , Plasma Hdtv , Displays , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv
