Official Panasonic VT50 owners thread - Page 349 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #10441 of 14194 Old 02-24-2013, 02:57 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Originally Posted by agriebel View Post
The HDMI cable on my VT50 sticks out a bit before it turns and hides behind the set. I was looking at one of the 90 degree adapters that are available from bluejeans or monocable. Has anybody used those?
I'm sure they work, and I've considered them myself, but I decided not to make any extra connections in my signal path. Not worth risking the signal degradation. I'd consider more pliable HDMI cables before the 90 degree adapters.
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #10442 of 14194 Old 02-24-2013, 03:26 PM
lees23's Avatar
Quoted: 20 Post(s)
Hey guys/gals, quick question about network controls on my VT50.
I downloaded the "Roomie" app that is advertised on this site but am having some issues getting the TV to turn on via my phone. I have set "Wake on Lan" to on but the TV still wont go from Off to on unless you use the remote, not the app.
Any ideas? Anyone using this app?
lees23 is offline
post #10443 of 14194 Old 02-24-2013, 03:34 PM
lees23's Avatar
Quoted: 20 Post(s)
I also changed "Power on link" from No to Yes in the the Viera Link menu
lees23 is offline
post #10444 of 14194 Old 02-24-2013, 04:05 PM
robnix's Avatar
Quoted: 678 Post(s)
Liked: 509
I use them. They work just fine. Like anything else in your path, they'll either pass the signal or not.
Looky here!
robnix is offline
post #10445 of 14194 Old 02-24-2013, 04:10 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Do you use the ones from Monoprice?
scirica is offline
post #10446 of 14194 Old 02-24-2013, 04:20 PM
Bond 007's Avatar
Quoted: 2518 Post(s)
Liked: 1993
I use one from Amazon. No problems here.
Licence to Kill
Bond 007 is offline
post #10447 of 14194 Old 02-24-2013, 04:25 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Did you use just one in each port or did you use two connected which would route the connector along the back of the panel versus pointed straight to the wall? I'm intrigued.
scirica is offline
post #10448 of 14194 Old 02-24-2013, 04:27 PM
robnix's Avatar
Quoted: 678 Post(s)
Liked: 509
Amazon. Shouldn't matter though.
Looky here!
robnix is offline
post #10449 of 14194 Old 02-24-2013, 04:28 PM
robnix's Avatar
Quoted: 678 Post(s)
Liked: 509
I use one in each port, but two should be fine. There's a picture floating around here somewhere of someone that put like 8 of them in a chain as a test and had zero issues.
Looky here!
robnix is offline
post #10450 of 14194 Old 02-24-2013, 04:38 PM
Bond 007's Avatar
Liked: 1993
I use 1 of these. That is all I need. Everything is routed through my receiver.
http://www.amazon.com/gp/product/B006GHYBGK/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1
Licence to Kill
Bond 007 is offline
post #10451 of 14194 Old 02-24-2013, 04:42 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Thanks...I think Robnix got what I was going for...trying to do an extra 90 degree bend to route the cables parallel to the back of the panel. I'll have to look for that thread that shows the "chain" to prove they work without signal degradation.
scirica is offline
post #10452 of 14194 Old 02-24-2013, 04:54 PM
Bond 007's Avatar
Liked: 1993
My cable runs straight down and then parallel sideways. You cant possibly make it more flush.
Just realized though that if you are using multiple HDMI ports you could not run the cable downward. They would hit each other. If you take a good look at the adaptor though it is better than a right angle. It is a swivel adaptor 0-180.
Licence to Kill
Bond 007 is offline
post #10453 of 14194 Old 02-24-2013, 06:59 PM
dakall's Avatar
I use these cable with a 90 degree connector, Works great and fits great. The trick was to find the kind that had the direction of the connector facing the correct way.
http://www.amazon.com/gp/product/B004D5GXQI/
dakall is offline
post #10454 of 14194 Old 02-24-2013, 07:48 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Right, which are the 270 degree one for the VT50. Ordered some today.
scirica is offline
post #10455 of 14194 Old 02-24-2013, 08:12 PM
Einskaldir's Avatar
I wasn't sure whether or not to go with the adapter or more pliable cable myself. I ended up purchasing 4 of the Mediabridge "flex" cables off Amazon simply because I had gift card credit there (free, yay!), needed 10 foot cords, and read another thread where someone with a VT50 was happy with them not extending beyond the edge of the TV.
http://www.amazon.com/gp/product/B005T3KH6A/
The cables have a slight bit of tension on them due to how I have things wired and they certainly do not come out beyond the edge of the TV like one of the much thicker HDMI cables did (that my parents let me borrow until my cables arrived). I definitely like these cables, although I'm a little worried that my cord-eating cat may chomp them in half before I mount my TV onto the wall. =)
Einskaldir is offline
post #10456 of 14194 Old 02-24-2013, 08:30 PM
dvzzz's Avatar
Quoted: 108 Post(s)
Liked: 31
What is the starting setting for Sharpness on VT50? Is it 50 or 0? When I slide to "0" I see negative impact on Sharpness of the picture. Image gets too soft, 50 seems good but I keep reading it should be at "0" or 1-3 no more than that. What is the answer here? Thanks.
For sale Sony VPL-HW40ES Projector, 720 hours on Eco Mode http://www.avsforum.com/forum/252-fr...-oem-bulb.html
dvzzz is offline
post #10457 of 14194 Old 02-24-2013, 08:35 PM
Bond 007's Avatar
Liked: 1993
Most people set it between 0 and 10 but that can depend on other settings also. Set it where it looks good to you.
Licence to Kill
Bond 007 is offline
post #10458 of 14194 Old 02-25-2013, 03:03 AM
cast away's Avatar
Does anyone experience mosquito noise on Panasonic 55VT50 with Blu-ray movies? The noise is a litter bit less when I set 1080p pure direct and motion smoother "off" but the motion looks terrible. Your advice to fix the mosquito noise is highly appreciated.
cast away is offline
post #10459 of 14194 Old 02-25-2013, 05:00 AM
robnix's Avatar
Quoted: 678 Post(s)
Liked: 509
I think you may be confusing noise with film grain.
Looky here!
robnix is offline
post #10460 of 14194 Old 02-25-2013, 06:41 AM
casey 2823's Avatar
Originally Posted by mnc View Post
I recommend using d-nice's settings, they are FAR better than the thx modes.
I've only had the tv for a couple of weeks but I'd like to tweak it a little bit. So, as I asked above are the "back office" custom settings the same settings as the thx cinema settings initially except for contrast, brightness, tint, sharpness, etc...on the first page of settings? I'm wondering if the gamma, greyscale, etc... is the same as the thx settings? I'm not ready to go into any pro settings just custom as I'm still being conservative with my settings since the tv is still very new. I just feel I should be able to make some simple improvements to the thx settings but using custom. I don't want to change any of the thx settings. I'd rather use custom to play around and compare against each other. However, it's not really a comparison if the thx "back office" settings aren't the same as custom. Hope this makes sense and sorry I know this posting is wordier than it needs to be and I don't want to waste anyone's time.
casey 2823 is offline
post #10461 of 14194 Old 02-25-2013, 07:08 AM
mo949's Avatar
Liked: 1139
Not the same
mo949 is offline
post #10462 of 14194 Old 02-25-2013, 07:36 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 514 Post(s)
Liked: 772
I use two such adapters on each of my four HDMI cables on my GT50 with zero issues, and i have used them on various other installs and haven't gotten any call-backs.
http://www.avsforum.com/t/1403635/official-panasonic-gt50-series-discussion-thread-no-street-price-talk/2700#post_22205675
Monoprice #3850
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #10463 of 14194 Old 02-25-2013, 08:05 AM
Tony1's Avatar
Quoted: 31 Post(s)
Just received my vt50 55" an hour ago, from Paul's TVs.. Right out of the box set to thx cinema, the picture looks great.. No buzzing heard yet.. All though you can sure feel the rush
of air delivered via the fans doing their jobs.. I also have a gt50, and i feel from my intial viewing, that there is more than a noticable difference in PQ between the two.. After i wall
mount the vt50, then i will be able to make more of a comparison, since they will be literally walll mounted on the same side of the wall and only about 6 feet apart..
IMG_20130205_223451_698.jpg 1479k .jpg file
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #10464 of 14194 Old 02-25-2013, 09:01 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Monoprice #3850
That's what I'm going to try this week. Using 2 of these 270 degree connectors together to route the cable back around the panel. Glad to hear it doesn't mess with the PQ!
I've purchased two from Monoprice and two from Amazon and will be comparing both. I'm not expecting any issues however. (Only using two HDMI ports)
scirica is offline
post #10465 of 14194 Old 02-25-2013, 12:23 PM
dasnub's Avatar
Trying to figure out if I'm crazy. Bought this tv two weeks ago and I SWEAR the picture went edge to edge. Charter came out today to fix the cable and now I'm noticing a 1/8" border all around the screen (on all sources.) Resetting/adjusting aspect ratios does nothing. Does anyone else have this? Is it normal?
dasnub is offline
post #10466 of 14194 Old 02-25-2013, 12:26 PM
mkerdman's Avatar
Does the 65VT50 have (A) MHL Mobile High-Definition Link and (B) WiDi Intel® Wireless Display compatibility built in?
Murray Kerdman
mkerdman is offline
post #10467 of 14194 Old 02-25-2013, 12:30 PM
JSpectre88's Avatar
Liked: 54
JSpectre88 is offline
post #10468 of 14194 Old 02-25-2013, 12:40 PM
dasnub's Avatar
Originally Posted by JSpectre88 View Post
Phew. Last thing I need is a border burned into the edges only to have it go back full screen one day!
dasnub is offline
post #10469 of 14194 Old 02-25-2013, 02:12 PM
Coyote Waits
htwaits's Avatar
Quoted: 935 Post(s)
Liked: 2077
All flat panels that I've examined have a very small dead area between the active part of the screen and the bezel. You can check for yourself with a calibration disk. wink.gif
htwaits is offline
post #10470 of 14194 Old 02-25-2013, 02:41 PM
nabsltd's Avatar
I use two different ones from Monoprice:
http://www.monoprice.com/products/product.asp?p_id=3850
http://www.monoprice.com/products/product.asp?p_id=4859
I use the second version on the bottom port, so the cable goes straight down.
Both work fine, and I like the fact that they came with dust caps on all the connectors, so the unused ports are covered.
nabsltd is offline
Panasonic , Panasonic Viera Tc P55vt50 , Plasma Hdtv , Displays , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv
