Official Panasonic VT50 owners thread - Page 471 - AVS Forum | Home Theater Discussions And Reviews
 77Likes
post #14101 of 14109 Old 01-04-2016, 07:41 AM
I WANT MORE's Avatar
Quoted: 271 Post(s)
Liked: 170
No plasma I have ever owned buzzed.
Philips something or other.
5080
6070
Pro 150
Pro 151
VT 25
VT 50
F8500
Perhaps I misremembered.
I WANT MORE is offline
post #14102 of 14109 Old 01-04-2016, 08:05 PM
6SpeedTA95's Avatar
Quoted: 125 Post(s)
Liked: 38
5080
6070
Pro 150
Pro 151
VT 25
VT 50
F8500
Your 5080 didn't buzz on full white scenes? Mine did...
6SpeedTA95 is offline
post #14103 of 14109 Old 01-06-2016, 06:47 AM
Quoted: 271 Post(s)
Liked: 170
Whisper quiet.
post #14104 of 14109 Old 01-10-2016, 04:23 PM
leemathre's Avatar
Sorry if this has be addressed, but I could not find an answer when doing a search of this thread. I have a region free DVD player that works fine with my Sammy UHD TV. On my VT50, however, when I try to play a region 2 DVD, I get audio but no video. I assume it is because the discs are PAL. Has anyone been able to play DVDs that are not region 1 on the VT50? If so, are there settings on the TV that I need to change? Thanks for any help.
Lee Mathre
Las Vegas, NV
leemathre is offline
post #14105 of 14109 Old 01-10-2016, 06:04 PM
mo949's Avatar
Liked: 1026
Pal won't work. You'll need to convert to ntsc. Some region frees players have that ability. For blurry its 24p so non issue.
mo949 is offline
post #14106 of 14109 Old 01-10-2016, 10:40 PM
mrhaboobi's Avatar
Issue with bluetooth
Hi,
Have had the 55" version of the Rv for a while, never used the Bluetooth function nor the little mouse wand thingy. Tried to use it recently and it's as if the to doesn't have a working Bluetooth module, the initial set up process doesn't go through the process as per the manual to set up and pair with the wand, nor does the Bluetooth menus allow you to pair with the wand or with anything Bluetooth, it's as if the item I need to select is disabled, I Se the word access in the Bluetooth menu, but on trying to confirm it just does nothing.. Anything I can do to test or check if the Bluetooth module is stuff from day one? Thanks
mrhaboobi is offline
post #14107 of 14109 Old 01-10-2016, 11:36 PM
rogo's Avatar
Quoted: 1198 Post(s)
Liked: 1330
Originally Posted by rogo View Post
I think the above-linked folks are no longer in the business, alas.
Anyway, I'm cautiously optimistic it's one of the other parts... Once I finally see the code, I'll report back
So, update for the curious... I've now gotten 4 full watching days without any shutdowns. Things seem as good as ever. #knockonwood
Everyone's help was greatly appreciated.
With HDMI cables, if you can see the picture without visible dropouts or sparklies, the cable is working at 100%. No other cable will display a better version of that picture. You're simply wrong if you think there is a better digital cable than one that is already working. Also, while anecdote is the "singular of data" your personal anecdote isn't data. When you conflate your anecdote with data and then decide someone else's anecdote isn't data, you earn a place on my ignore list.
rogo is online now
post #14108 of 14109 Old 01-11-2016, 04:02 AM
whipit's Avatar
Quoted: 96 Post(s)
Liked: 82
Originally Posted by mrhaboobi View Post
Hi,
I found a trouble tree in the ST60 manual. Maybe this will help sort things out.
ST60 BT.pdf
whipit is offline
post #14109 of 14109 Old 01-11-2016, 09:07 AM
leemathre's Avatar
Thanks. Unfortunately this player does not have that option.
Lee Mathre
Las Vegas, NV
Panasonic , Panasonic Viera Tc P55vt50 , Plasma Hdtv , Displays , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv
