Panasonic ST50 vertical viewing angle - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-03-2012, 08:21 AM - Thread Starter
idemedosumom's Avatar
Hello guys,
I recently bought a new plasma tv, the panasonic 42st50, this is my first plasma tv and I must say that I am impressed. It looks so much better than my old lcd, I do have one question though:
Viewing angles are supposed to be an advantage of plasma technology (or so I've read numerous times), and I must agree to some point, the horizontal viewing angles are perfect yet I'm slightly concerned with the vertical viewing angles. The tv is located roughly one meter from the floor, and the pq is very good while I'm seated, yet when I stand up the the image gets darker.
Is this a natural occurrence for all plasma tvs or maybe for the panasonic st50 lineup or maybe its just a defect on the panel I own?
idemedosumom is offline
post #2 of 10 Old 05-03-2012, 08:29 AM
eagle_2's Avatar
Quoted: 405 Post(s)
Liked: 293
It's the filter used on these newer tv's to help filter room light and make the tv viewable easier in a brighter room - it's applied directly on the outside of the glass. The downside is as you've noticed, the vertical viewing angle is crap for these plasmas now. It doesn't affect the horizontal viewing angle though, only vertical, so you notice it when you stand up. The only way to get around that is to buy a lower-quality model without the filter, but I think you're much better off with the filter, even though as you noticed it does affect vertical viewing.
eagle_2 is offline
post #3 of 10 Old 05-03-2012, 08:47 AM - Thread Starter
That makes perfect sense, thank you very much for your reply.
post #4 of 10 Old 05-03-2012, 09:04 AM
tomagardner's Avatar
What would you say the vertical viewing angle is?
tomagardner is offline
post #5 of 10 Old 05-03-2012, 09:28 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 519 Post(s)
Liked: 775
Originally Posted by idemedosumom View Post
Hello guys,
It's not a defect on the panel. The ST50/GT50/VT50 series all have what is called a "Louvre Filter" which is designed to reject light from overhead lighting, while allowing the panel light to pass through at normal horizontal viewing angles. Last year's models had a similar filter. It has a sort of "mini-blind" effect similar to partially closed blinds and it does an excellent job of rejecting light from above.
Since nobody ever looks downward on their Plasma TV from above, the fact that it gets darker when doing this is not an issue.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #6 of 10 Old 05-03-2012, 11:14 AM
DrRx's Avatar
What about the other way around - for instance if the set is wall mounted and it is positioned slightly above seated eye level so that you are looking UP at it?? Does the louvre filter similarly darken the picture in this case?? In my situation I will need to wall mount my GT50 such that the lower edge of the screen is at seated eye level or slightly higher (about 40" above the floor or greater).
DrRx is offline
post #7 of 10 Old 05-04-2012, 09:05 AM - Thread Starter
I'm afraid it looks just about the same to me: looking at the tv while sitting on the floor and looking at it while standing, it gets darker. I suggest you check the tv out in person before making any purchases.
post #8 of 10 Old 05-04-2012, 10:11 AM
jmamhd's Avatar
I noticed that somewhat when I wall mounted my P60ST50 but my mount allowed me to tilt the tv slightly downward and the horizontal viewing improved.
jmamhd is offline
post #9 of 10 Old 05-04-2012, 12:39 PM
Dierkdr's Avatar
Liked: 54
What about the other way around - for instance if the set is wall mounted and it is positioned slightly above seated eye level so that you are looking UP at it?? ......
Will depend upon seating distance away from the set: if you are "far enough" away, you won't notice the darkening caused by the filter from your seat being somewhat Too Low. (Farther distance = less of an angle)
But a mount with the ability to tilt the panel slightly downward would certainly help avoid the problem.
Do a daily "floor exercise" routine - usually to Mike & Mike on ESPN - and am often only a couple of feet away from, and therefore looking rather sharply upward at, our ST50: the darkening at that angle is dramatic!
But at our normal 9ft viewing distance (60" panel) you would have to be Very Tall before the filter would be a problem!
Dierkdr is offline
post #10 of 10 Old 05-04-2012, 01:37 PM
Hmm, that won't be good.
