what tv to keep Maxent or Sony - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: which tv to keep
Maxent mx 42hpm20 plasma 0 0%
sony Kdf 42we655 lcd projection 0 0%
Voters: 0. You may not vote on this poll
post #1 of 4 Old 05-03-2012, 10:00 AM - Thread Starter
Reliantkcar's Avatar
OK so I have 2 TV's one has to go
My main use is going to be mainly video games and some hd video but mainly xbox fps games in 1080i
I just got a maxent 42hpm20 42" plasma for 100$ off Craigslist the panel buttons were stuck so I pulled em out(any button you pressed also hit the power button) and got a universal remote all controls work good now.tv works great except in dark scenes there are a few red dots dancing in the dark. My research shows turning the vscan voltage down will fix this.
Pro's
Better picture
Thinner
VGA input
Cons
Lower resolution 1024x768
Unknown reliability
Fragile glass
No spare parts
Other tv I got free its a Sony kdf42we655. It only worked for. 30 seconds then shut off.I had a spare bulb from one I stripped before and that fixed it.the tv has no blue dots yet and I got another free one with a new bulb that I stripped out for parts. So I have a extra bulb and a optic block with 2 good LCD panels for when this one messes up
Pros
Have spare parts bulb,lcds,power module
Light
Good resolution 1366x768
Cons
Washy LCD pictures(bad blacks)
Unreliable (I can swap the LCD in 30 mins but it takes 6 hours to adjust that damn THING)
takes up more space
Reliantkcar is offline
post #2 of 4 Old 05-03-2012, 03:00 PM - Thread Starter
Any comments on the maxent
post #3 of 4 Old 05-03-2012, 08:46 PM
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
Pro's
Better picture
Thinner
VGA input
Cons
Unknown reliability
Fragile glass
No spare parts
Pros
Light
Cons
takes up more space
Keep whichever one looks better to you?? Personally I probably couldn't deal with either of them and would throw out both of em and spend 500 or more on a new set...
CaTaSTrOphiK is offline
post #4 of 4 Old 05-04-2012, 03:36 PM - Thread Starter
Well I only will be using it once a week for xbox as a spare tv. My main tv is a Toshiba 34hf83 34" crt HDTV that is on all day when I'm home and for hd movies and good xbox or ps3 games I have a pioneer pdp5080 and a Sony xbr 34 910 also
