Vizio VP422 problem - vertical thin color lines - PIC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-05-2012, 10:54 PM - Thread Starter
uncleL's Avatar
I don't know of I'm posting in the right forum section. Lines started after a year and a half use. Got left on overnight a few times then these thin lines appeared.
I wanted to ask what board I should order and replace to fix my display.
uncleL is offline
post #2 of 9 Old 05-05-2012, 10:59 PM
Fanaticalism's Avatar
None. Vizio does not provide parts after the first year of warranty. It is a throw away.
Fanaticalism is offline
post #3 of 9 Old 05-05-2012, 11:11 PM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Find a good replacement main board from eBay for your model and it should fix the problem.
BB1111 is offline
post #4 of 9 Old 05-06-2012, 10:15 PM - Thread Starter
uncleL's Avatar
Main board Or logic board?
It turns on and boots ups fine, firmware loads, I can access the menus. Just have a large set of thin vertical lines taking up about a third of the screen.
uncleL is offline
post #5 of 9 Old 05-07-2012, 08:54 AM - Thread Starter
uncleL's Avatar
Ttt
uncleL is offline
post #6 of 9 Old 05-07-2012, 01:27 PM - Thread Starter
uncleL's Avatar
Ttt
uncleL is offline
post #7 of 9 Old 05-07-2012, 03:38 PM - Thread Starter
uncleL's Avatar
Ttt
uncleL is offline
post #8 of 9 Old 05-08-2012, 03:32 PM - Thread Starter
uncleL's Avatar
Ttt
uncleL is offline
post #9 of 9 Old 10-09-2012, 10:43 PM
RYan Hil's Avatar
BUMP same problem any luck ?
RYan Hil is offline
