Panasonic TC-P50S1 Vertical Black Bar (Right Side) - AVS Forum | Home Theater Discussions And Reviews
Old 05-06-2012, 08:08 PM - Thread Starter
irod87's Avatar
A couple of days ago my tv turned off by itself and when I tried to turn it back on the power light just flashed. Eventually it came back on and had some color issues on the right side of the panel. That also went away. Now I have about a 2 to 3" vertical black bar on the right side of the screen. The tv is out of warranty. I did some googling and found that it might be a user replaceable part but I do want to get some more confirmation on what that part is and how to install it.
irod87 is offline
Old 05-08-2012, 07:57 PM - Thread Starter
irod87's Avatar
Anyone know which part I need to try to replace?
irod87 is offline
Old 05-09-2012, 06:43 AM
tomwil's Avatar
Liked: 26
This thread gives you an idea of what the problem might be. Basically, it is either the D or A board, one of the C boards, or the plasma panel itself.
The usual first step is to reseat all the ribbon cables between the boards and panel. It could be a loose or defective connection.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
Old 01-10-2013, 04:58 PM - Thread Starter
irod87's Avatar
Resurrecting my really old post but I wanted to put it out there that I bought a new c1 board from eBay put it in and problem solved! Took all of 30 miutes and about 10 dollars. My S1 can now live longer.
irod87 is offline
Old 01-10-2013, 08:55 PM
lauradogin's Avatar
yeah,i like that , me too,Took all of 30 miutes and about 10 dollars. My S1 can now live longer. thank you1.gif
lauradogin is offline
Panasonic Viera 50 Inch Plasma S1 Series Tc P50s1
