Advice please! 60" Panny ST50 or LG 60PA6500 or LG 60PM6700 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 05-08-2012, 03:43 PM - Thread Starter
mysq's Avatar
Hi everyone,
I have been trying to make up my mind about this by looking at these TVs, but can't seem to find them anywhere in my local BB or Frys(they all seem to be too much in love with Samsung, and LED TVs). I did find a smaller version of the panasonic, but very difficult to make any judgement based on the mode it was using. I need to make a decision and buy within the next 1-2 days, so turning to your expertise. Some requirements :
1. Plasma (not LED)
2. Budget...maybe upto $1500( I don't intend to upgrade for a few years at least)
Questions:
1. Which one would you suggest, based on Picture quality, build quality(long lasting), black levels?
2. Is LG as good as panasonic? No experience with them ( i current own a panasonic ST30, and its very good)
3. the LG6500 is $1200, and doesn't have 3D. Otherwise, do you know if PQ is the same as the LG6700? There si a LG9700 model also, which claims 'TruBlack', but its $2000. Is it worth it?
4. Any other brands/models you will suggest?
5. Lastly, any suggestions for wallmount is also very welcome. As I don't know where I will be living, I think I will take a mount that can swiwel horizontally and vertically.
mysq is offline
post #2 of 16 Old 05-08-2012, 03:53 PM
chunon's Avatar
Quoted: 2036 Post(s)
Liked: 1784
Originally Posted by mysq View Post
Hi everyone,
1. Plasma (not LED)
Questions:
Hands down ST50 imo, better than the ST30 you already have
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 16 Old 05-08-2012, 04:50 PM - Thread Starter
mysq's Avatar
Hi Chunon, i agree! I was actually looking for advice between the new 60" models of Panasonic and LG, I am planning to keep the 50" for the bedroom.
mysq is offline
post #4 of 16 Old 05-08-2012, 04:55 PM
chunon's Avatar
Liked: 1784
Oops misread your post, I prefer Pannys over LG's just my preferance. Wish could help you out tho. Samsung E6500 ?
65C6 OLED
post #5 of 16 Old 05-08-2012, 05:04 PM - Thread Starter
mysq's Avatar
Samsung E6500 is $1900...not impossible to do, but will pinch very hard.
One think I like about the LG is the extremely thin bezel(0.5")...the panasonic looks very big, unless I go to VT series
mysq is offline
post #6 of 16 Old 05-08-2012, 06:00 PM
Dierkdr's Avatar
Liked: 54
I have been trying to make up my mind about this by looking at these TVs, but can't seem to find them anywhere in my local BB or Frys...
1. Plasma (not LED)
Questions:
If you can get a 60" ST50 for $1500 or less, that should easily be the best choice of the 3 you list.
We recently moved from a 60" ST30 - which was actually a Very Nice set, excepting the GROWING PINK TINT ours had - to a 60" ST50: I don't know if I would characterize the ST50 as being as "far above" the ST30 as appears to be the general opinion, but it (ST50) IS an Excellent HDTV, and does appear to have a couple of PQ advantages over the "30." (Although its MAIN advantage for us, of course, is NO PINK TINT.... at least thus far!)
Before we ended up with the ST50, I thought the LG PA6500 was a nice looking Bargain Panel - although the PA6550 (From CostCo) seemed even more attractive, given a Lower Price Point AND a 2-year Warranty.
Have seen the LGs in several stores, and they appear nicely designed, with Bright, good-looking colors. They also have more End User Picture Controls than the Panasonics.
However, they are very reflective, and, even with all of Panasonics troubles over the past several years, still have more confidence in Pan's long-term reliability than any of the other current Plasma options. (Of course, we won't KNOW whether that holds true until a few years down the road!)
Apparently, there is also a LG PA5500 that is a "store exclusive" for one of the bigger chains, and it also carries a very low price tag.
The LG9700 seems likely to exceed your $1500 price target, but it might be worth looking at IF you are placing it into a Very Bright Room, AND will do a lot of Daytime viewing: apparently it has a nice Matte Finish on the panel.
Another Option that might be worth looking at is the Panasonic UT50: It has received an Excellent Review from CNet, and the samples we've seen locally look to have a Bright screen & good colors. At this point in the year, would personally select the UT50 over the LG PA6500 - and probably the PM6700 as well - as a pretty remarkable "bargain panel," although I doubt you would go FAR Wrong with any of these sets!
Happy Hunting!
Dierkdr is offline
post #7 of 16 Old 05-08-2012, 06:34 PM
cjsiv's Avatar
Liked: 33
I have the 6700 hanging on my wall as I type this. I also own an older Panasonic 720p plasma. I have been going back and forth and although I am pro Panasonic, the prices this year are not that great. I ended up with the LG because the bang for the buck is phenomenal. I love the picture, no IR issues like previous years. I'm pretty impressed with it actually. LG gives one year on parts/labor and 2 years on the panel.
This is my first LG and I must say that I was a little hesitant at first. I just got done shopping for TVs again yesterday just to make sure that I made the right choice. I looked at 3 different stores, every LED and plasma that they carried. I decided to stick with the LG.
That being said, I am currently waiting on the 9700 to show up. My dealer must've gotten a bad batch of panels as I got 2 in a row with a few pixels out. They made me a very generous deal on the 9700 since I went through 2 of them. All of the display models had perfect panels. Like I said, must have been a bad batch. It happens.
I wanted the most performance and features for my money this year and to me LG was it. If money were no object I would have gotten a Panny GT or VT. But I am very happy with the LG.
cjsiv is offline
post #8 of 16 Old 05-09-2012, 08:20 AM - Thread Starter
mysq's Avatar
Hi, thanks for your responses.
I did get to see the LM6700 in a different Frys yesterday, and it certainly looks good (thin bezel). I fiddled with the controls to change the mode to 'Cinema' (or was it THX). I have to admit I cannot really understand how people are able to make a very good determination of TV in the stores...there is so much noise, and light coming from TVs all around. Also saw the 50" version of the panasonic ST50. The sales guy said Panny is best, followed by samsung and LG (apparently samsung makes the panel for LG, and they keep the better ones for themselves?!).
@cjsiv - Did you get 3D glasses with LG? If yes, do you know if they will work with other 3D TVs? I got 2 pairs free with my 50" ST30 last year, and Amzn has a deal for 2 pairs with LG currently.
@cjsiv - do you think picture quality between P60ST50 and LG 6700 are comparable? Especially the black levels? May I ask why you are waiting for 9700?
@Dierkdr : thanks for your recommendations. I think there is a LG6550 in Costco, will check it out. I just noticed that on amzn the P60ST50 is $1843, while the P60UT50 is $1799. Plus the UT50 ships in 2-3 weeks (i'm moving overseas in 2 weeks).
@dierkdr: I also liked the idea of matte screen of LG 9700, and if PQ is comparable, would go with that instead of Panny ST50. Any thoughts on PQ between these two (you said you saw the 9700 at your dealer?)
thanks!
mysq is offline
post #9 of 16 Old 05-09-2012, 08:55 AM
cjsiv's Avatar
Liked: 33
I did get 3d glasses but they probably will not work with others. This year uses Bluetooth. The lady at one of the stores I was in said last years Panasonic glasses don't work with this years either.
This years LGs have all new panels from what I am told. Supposedly better black levels. The 9700 has the black filter so that is one advantage of it. I believe there is more to a good set than black levels so differences between the models in that regard is not a huge concern to me.
My dealer may have gotten a bad batch of 6700s with a small (1 or 2 pixel) defect. Most people wouldn't have noticed. I am picky. I've looked at a couple 6700s on display and all of the panels were fine. It was just my dumb luck. To make up for my trouble they are offering me the 9700 for only $50 more instead of $500. I would be stupid to pass that up. For the price I am getting the 9700 for, there isn't another model from 2012 that come close. I can't get a 60 inch UT for what I'm getting the LG flagship for (actually the UT would be a couple hundred more).
I like the design. The picture is great. Black levels seem good although I have no way of measuring or plans to calibrate. 3d works fairly well. Menus are nice. THX certified. Wifi. I like the trumotion when set manually to 1 or 2. Media sharing recognizes and streams dvr shows from my directv box. Media from computer uses Plex media server which is amazing. Streamed 720p bluray rip of MI4 with no issues. I'm impressed with it. There may be others out there with better specs, black levels, etc but they cost much more.
Like I said, I'm happy bang for the buck wise. I'm hesitant, though but was told LG is upping their game this year. Guess we shall see.
I went ahead and got the extended service from my dealer just in case. They offered 2yrs parts and labor with pick up and loaner set thru them without dealing with LG for $70. I'd I have issues beyond that, I'll scrap it and go back to Panasonic. Their features and price point this year was just too good for me not to try it.
cjsiv is offline
post #10 of 16 Old 05-09-2012, 01:46 PM
Dierkdr's Avatar
Liked: 54
For less than $50, would certainly opt for the ST50 over the UT50.
Sorry, have NOT seen a 9700 in person - only the lower models, and thus could only GUESS about PQ on the high-end LG....
The matte screen on the 9700 should be useful in a Bright room. But without knowing how its other PQ factors measure up, it is hard to say whether it beats the ST50.
Our ST50 does a nice job of maintaining its PQ in a "well-lit-but-no-sunshine" setting (it sits in a finished area of our basement: lots of lamps & overheads, but only indirect sun light - and that only during the morning hours!)
Have you checked out potential problems with Local Electrical Current - and possibly TV Reception - assuming you are planning to take your new TV overseas with you?
Frankly, would be worried sick about trying to ship a large panel HDTV overseas!
Again, if that IS your plan, hope you buy Excellent Insurance coverage!
Dierkdr is offline
post #11 of 16 Old 05-10-2012, 07:36 AM - Thread Starter
mysq's Avatar
I'm also leaning towards the ST50 now, just because I don't have time to do much more research. Regarding voltage and current, the plan is to plug the TV (and a whole bunch of other electronics) into a 240->110 transformer.
The bigger question is NTSC vs. PAL, and here LG seems to win, since it apparently supports both formats. But from talking to people there, it seems also that the STB provided by the HD cable/satellite providers works with any kind of TV. Though of course, there are always exceptions!
Absolutely, there will be enough insurance on shipping!
mysq is offline
post #12 of 16 Old 06-13-2012, 08:39 AM
KYScout's Avatar
Does the plex media server work with the new pm6700? This sounds like a really good idea!
KYScout is offline
post #13 of 16 Old 06-13-2012, 10:02 PM
jdevenberg's Avatar
On this, I don't think that there should be exceptions. If you are using a set top box, it will decode the NTSC, PAL, or whatever encryption and send it out to the TV over HDMI in a standard format regardless of service provider. There aren't that many manufacturers of set top boxes (most are Motorola), so any set top box should work with any TV regardless of whether the TV supports the original encryption format or not.
jdevenberg is offline
post #14 of 16 Old 06-13-2012, 11:22 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Before you decide, take a look at the 55VT50 on Amazon. I know you want a 60" but it's worth considering a 55" to get this tv and at this price. I just exchanged the 60GT50 for the 55VT and I'm not sorry. Also, the older tv was 51" and the 55" is a good bit bigger. I think the thinner bezel is the reason.
sheshechic is offline
post #15 of 16 Old 06-27-2012, 01:51 PM
HTtom's Avatar
mysq: What set did you end up with? I'm looking at the ST50 and the 60PM6700 as well. My thread is here if you have advice to offer. Thanks.
HTtom is offline
post #16 of 16 Old 07-05-2012, 04:42 PM
sCythEroXx's Avatar
I bought 60PM6700. Great size and pricing. The only main down side I felt was reflections in the TV set. I feel if you can afford 65ST50 you can buy that, I saved that $1000 to put in something else. I just swivel my lg to avoid reflections and ordered $60 of counter lighting so that I can turn off kitchen over heads as it was interfering with my viewing. 60ST50 was still $400-500 difference. I feel the TV needs some good calibration. Between Onkyo S9400 and this TV there are too many settings that need to be perfected, I am just experimenting.
I shifted from LCD to Plasma, and I am glad in a way. Reason: I had watched the movie Rio two times on 46" and 32" lcds before and I always thought the color of male parrot and female were same (forgot their names) and this weekend when I saw it on my plasma I noticed all the subtle difference in their color, they were not same, blue for male and cyanish for female.
sCythEroXx is offline
Lg 60 Inch Pa6500 Plasma Hdtv , Lg 60pm6700 Plasma Hdtv
