Is saving $300 on a barely used P65GT30 worth it ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-10-2012, 07:15 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
So I really wanted to get a 65ST30 or even an 60S30. My budget was around $1,500 and I guess I waited to long to pull the trigger on the ST or S.
Now I've managed to find a 65GT30 ALMOST within my budget...nevertheless it was "slightly used" still full factory warranty...and I can return if bad from the local store.
HOWEVER since then I've found a new one for about $300 more...without going into "pricing details" is there any reason I should spend the extra cash or is the barely used model a safe bet especially since I can return.
Just looking for some insight guys....
Thanks in advance!
toofast68 is offline
post #2 of 7 Old 05-10-2012, 08:11 AM
chunon's Avatar
Quoted: 2024 Post(s)
Liked: 1779
Thanks in advance!
What are the hours, cosmetic defects, any sign of burn in etc. Depends on how import that $300 is to you I guess.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 7 Old 05-10-2012, 09:00 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Yeah, great questions...I am trying to find that out. I am also struggling as now I've found a NEW ST30 around the same price and since I plan to calibrate, not sure the gamble is worth it on saving the money. YES, the wife will LOVE the sexier panel of course on the GT....but I doubt there is any other benefit.
post #4 of 7 Old 05-10-2012, 09:05 AM
chunon's Avatar
Liked: 1779
ST30 is a good set also thats what I own.
65C6 OLED
post #5 of 7 Old 05-10-2012, 12:09 PM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Just found out the GT MIGHT not carry a Manufacturers Warranty...so IF I need any of the fixes, boards, etc..I am out of luck.
On to the search for a ST now.
post #6 of 7 Old 05-10-2012, 12:40 PM
tbass2k's Avatar
toofast, check your PM
tbass2k is offline
post #7 of 7 Old 05-12-2012, 09:25 AM
ken325i's Avatar
don't get the ST30, get the ST/GT50. Better pic and contrast.....
ken
ken325i is offline
