The Official Panasonic U50/54 Owners' Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 11-28-2012, 06:42 AM
eeee87's Avatar
Originally Posted by redlinegts85 View Post
P50U50....
How do I access 3:2 pulldown and 24p direct in? They are greyed out in the advanced settings.
watch a bluray at 1080/24hz
or if you use a home theater pc/media player set it to output movies at 24p
other than that you should have that option with 1080i sources
eeee87 is offline
Old 11-28-2012, 07:00 AM
OSUBuckIam02's Avatar
TrevorS
No this tv is not a mistake because you clearly have more than one tv. Use this tv for viewing full HD content and watch your news on the other set? I struggled with the same concern then remebered I have 6 tvs in my house that I can watch other stuff on. I know thats probably not what you want to hear but I hope you wouldnt wear your favorite suit or shoes everywhere if you had others. Use the tv for what is was meant for and enjoy. If you have a BB service plan let er rip and watch whatever you want then call them if you get burn in
OSUBuckIam02 is offline
Old 11-28-2012, 10:30 AM
lfeickert's Avatar
Originally Posted by strikehold View Post
I've had the unit from Costco for a few days now. Consistently, when I start up my BDP it will switch to that input, but won't connect to the signal. It says there is no signal. If I unplug the HDMI cable and replug it in, then it will transmit the signal normally. This happens every time. I've tried 3 different cables, 2 from Monoprice and one generic one. Any thoughts would be appreciated.
By any chance is your BDP made by Vizio?
I had similar issues with a Vizio player attached to an inexpensive Westinghouse LCD/LED TV. I spent a lot of time swapping HDMI cables (including Vizio "directional" cables) and on the phone with both Vizio and Westinghouse, all to no avail.
I finally stumbled upon a work around--leave a DVD in the player at all times. By doing so, the BDP player automatically plays the DVD when it is turned on and syncs up with the TV. After you roll through all the copyright and FBI warnings, just stop the player and return to its home menu for other functions.
Hope this works for you...
lfeickert is offline
Old 11-28-2012, 01:06 PM
redlinegts85's Avatar
It's not giving me the option at all.
redlinegts85 is offline
Old 11-28-2012, 02:48 PM
gene9p's Avatar
Quoted: 31 Post(s)
Liked: 31
setting is in your blu ray player....
gene9p is offline
Old 11-28-2012, 05:38 PM
squeakybirnbaum's Avatar
Quoted: 26 Post(s)
Liked: 26
Originally Posted by Greymulkin View Post
I'll check it out when I get home. I had run a DVD calibration disc on my xbox 360. It had me setting contrast really high, around 80-90, but brightness down at 17. I think I had a setting messed up on the Xbox so I'll re-do it with the right setting (it was the black-level setting, I think I mistakenly left it on "expanded" when fooling around).
Did messing with the settings help your line bleeding at all?
squeakybirnbaum is offline
Old 11-28-2012, 05:43 PM
I already set it to 24hz in my blu ray player. What I'm saying is the option on my tv settings has 3:2 pulldown and 24p direct in grayed out.
Old 11-28-2012, 07:49 PM
yourwhiteshadow's Avatar
try changing from the preset settings to custom. i remember my 24p playback was greyed out until i set it to custom and changed the refresh rate on the HTPC to 24Hz.
yourwhiteshadow is offline
Old 11-28-2012, 09:48 PM
Greymulkin's Avatar
They did not. I put Brightness and Contrast down to around 50, with Tint, Color, and Sharpness all neutral. Turned off all processing, &c.
However, it's my understanding that all plasmas have line bleed to some extent. What I experience on mine is not particularly severe and in most scenarios, not even detectable.
I will say that, though the plasma has excellent motion-handling, the higher-end Sonys put it to shame. The plasma has something like a ghosting effect while the super nice LCDs are extremely crisp.
So it's kind of a wash, do I pay $2,200 more for a really nice LCD or just $700 for the plasma?
Greymulkin is offline
Old 11-28-2012, 10:08 PM
hixton401's Avatar
That sounds idiotic, you could spend much less than that and get a ST50 or roughly the same and get a VT50; either one would beat the Sony. In what way does it make sense to compare a base model to a flagship?
hixton401 is offline
Old 11-28-2012, 11:15 PM
strikehold's Avatar
Thanks for the reply. My BDP is a Sony with the latest firmware. I switched to the other HDMI input on the TV and haven't gotten the error since. So it seems like the one HDMI port is wonky. I'm not sure what to do about it. I'd rather not have to take it back as I really like the picture and the store is an hour away. Maybe I can buy the extended warranty after the fact now and deal with it if I ever need the second input.
strikehold is offline
Old 11-29-2012, 10:47 AM
lfeickert's Avatar
You're welcome... and here's hoping you never need a second HDMI port. smile.gif
Old 11-29-2012, 04:04 PM
tim86's Avatar
So I just got my U50 and set it up. Picture is quality is excellent and I'm not have any banding or line bleeding issues some others have described. I may have an issue with one of the speakers though. frown.gif I'm getting some sort of static vibration during the beginning of Prometheus. I have all the audio set to default, but if I turn the bass up it does make it much more pronounced. Has anyone else watched the beginning of Prometheus and had this issue? This opening scene does have some deep bassey undertones. But I wouldn't think with he bass default to 0 I should be hearing this. I hate to think what it will sound when I put in the Dark Knight Rises when I get it. Did my TV come with a blown speaker? frown.gif
tim86 is offline
Old 11-29-2012, 04:08 PM
Greymulkin's Avatar
I think you misunderstand. I'm saying that the only way to overcome the limitations of the lower-end Panasonic is to replace it with a high-end LCD. There is no comparison. It is an option.
Getting an ST50 or VT50 would not really beat the Sony as the limitations are inherent to plasma displays - not particular models / brands.
I spent several hours at my local Fry's comparing the U50 to the it's more expensive brethren to see if I'd miss the slightly larger screen or the fancier looking, solid glass face of the VT50.
While I didn't have access to any special measurement equipment, I did have a blu-ray player and calibration disc. After tweaking them as much as I could, there was no appreciable difference (to my eyes) in quality. Of course the more high-end models have other features, including interpolation and AR film, but I don't have a need for them.
Old 11-29-2012, 04:10 PM
Greymulkin's Avatar
The standard Panasonic warranty is for 1 year, I believe. They should be able to assist you.
Old 11-29-2012, 06:59 PM
Quoted: 26 Post(s)
Liked: 26
I'll take yours, I'll never use the TV speakers. Good to hear about no line bleeding issues on yours though. Hopefully mine is like yours (if it ever ships.)
Old 11-29-2012, 09:42 PM
Quoted: 26 Post(s)
Liked: 26
Could anybody by chance tell me the dimensions of the box of the 60u50 real quick? I'm about to run to walmart and pick this up but I'm not sure if it will fit in my SUV. (Rodeo)
Old 11-29-2012, 11:18 PM
Boltd's Avatar
Big.
64"x11.5"x38".
Boltd is offline
Old 11-29-2012, 11:41 PM
Quoted: 26 Post(s)
Liked: 26
Originally Posted by Boltd View Post
Big.
64"x11.5"x38".
Thanks, I'll be waiting to borrow a truck then.
Old 11-30-2012, 11:49 AM
clutchm3's Avatar
Ok I am very confused. There are over HUNDREDS of posts on how to CORRECTLY break-in/calibrate a plasma. Please someone, tell me the steps I should be taking?
People say break-in the plasma with http://www.eaprogramming.com/ and let the slides from for 100 hours. OK after that how do I go about calibrating it? Use the AVS DVD? I am so confused all I want is the best quality from the TV and a THOROUGH guide for it. Someone please share their experiences with me.
clutchm3 is offline
Old 11-30-2012, 11:57 AM
Redrum509's Avatar
Can someone provide me with instructions on how to check the hours used on this tv? I knew how on my old panny but since have forgot. Thanks
Redrum509 is offline
Old 11-30-2012, 01:16 PM
chunon's Avatar
Quoted: 2036 Post(s)
Liked: 1782
Press and hold the {VOL -} button ON THE PLASMA TV.
•Then press the {INFO} button on the remote control 3 times.
•"Start Adjustment Menu" message will be displayed followed
by the Service Menu after few seconds.
•ADJUST {Picture Adjustment}
•WB-ADJUST {White Balance Adjustment}
•OPTION {Option Setting}
•V-SUS {V-SUS Adjustment}
•AGING
•SRV-TOOL {Service Tool}
{1} & {2} buttons move through options
•Press the {2} button once to select "SRV-TOOL".
•Then press the {OK} button to access it.
•Using the cursor keys, highlight the right side
of the last item "PTCT :00.00.00.00.00" :
•Then press and hold the {MUTE} button for 3 seconds.
•Time and Count will be displayed in red color:
__TIME = Hours : Minutes of operation.
COUNT = Times the Plasma was powered on.
Hold down the power button on the tv to exit.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
Old 11-30-2012, 06:44 PM
Redrum509's Avatar
•AGING
Thanks man! I have 91 hours on my panny.
Old 11-30-2012, 06:55 PM
Greymulkin's Avatar
•AGING
A big THANK YOU! I've been trying to figure out how to get into the service menu, wasn't able to find it for the Panasonic TC-P60U50 anywhere.
Old 12-01-2012, 06:34 AM
chunon's Avatar
Liked: 1782
No problem
65C6 OLED
Old 12-01-2012, 08:38 AM
derek533's Avatar
Guys, need to know how much your set buzzes. Mine is audible from about 8' away during bright scenes. It's not loud and with the volume up, it drowns it out. However, when playing a game, during the loading scenes when all is quiet, there is definitely a discernible buzz that is clearly detectable. I bought it from Amazon a couple of weeks ago and it was delivered this last Tuesday. I should know the answer to this, but will it improve as the panel ages at all? Should I exchange it? I have an older 42PX75U but since it's a 42" set, I don't think it's fair to necessarily compare the buzzing between the two sets as I'm sure the 60" requires more wattage to drive. I guess the question is, how much buzzing should I really expect during quiet, bright scenes?
BTW, my settings are set for break-in i.e. low contrast and brightness.
Thoughts?
derek533 is offline
Old 12-01-2012, 04:56 PM
ArnieG's Avatar
ArnieG is offline
Old 12-01-2012, 06:05 PM
Johnrg87's Avatar
The only time I've noticed buzzing was when the white slide would come up in my break-in slides. It's very quiet, and I haven't been able to pick it up during regular tv viewing or video game playing.
I've been on the look out for line bleeding, but I haven't seen any yet.
Johnrg87 is offline
Old 12-01-2012, 07:00 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
BTW, my settings are set for break-in i.e. low contrast and brightness. Thoughts?
You should not be able to hear any buzzing at all from 8 feet away in a silent room with the volume off during bright white slides. Something is wrong with it, and it's extremely unlikely that it will become quieter on it's own. There are some buzzing threads that will give you more insight, but what your describing is not normal and i'd have the set exchanged.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 12-01-2012, 07:16 PM
Ernie in NH's Avatar
Thoughts?
I would try to determine if the source of the buzz is internal or external.
Did you use the ferrite rings on your HDMI cables? If you disconnect all inputs does it still buzz?
Are your HDMI cables running parallel and close to the power cables?
Are your wall sockets properly phased (wired) and grounded?
Are there Wall warts and other AC to DC converting equipment on the same circuit or nearby?
You might want to consider what electrical appliances are on the same circuit as your U50. This is a well documented problem with high end audio equipment...refrigerators being the most common offender. Also dimmer light switches are notorious as well as florescent lights for being sources of hum/buzz. Most audiophiles are quiet familiar with the problems that just the electrical lines them selves can add (what is upstream from you) .
Are there Wall warts and other AC to DC converting equipment on the same circuit or nearby ?,IE Heating pads, electric blankets, aquarium heaters and doorbell transformers.
I have a U50 as well. I ran a dedicated electrical circuit just for the refrigerator so as not to add the clicks it creates every time the motor cycles on and off. . Dead silence on the TV. A Blue ray DVD is stunning.
here are some trouble shooting steps that might help.
http://www.ntopix.com/files/Killing_Buzz.php
If you do determine the buzz is from the U50 ...check to see what your contrast setting is..lower it if it is high..this may reduce it enough that you do not notice it.
Ernie in NH is offline
Panasonic , Panasonic Th 50pz77u 50 Inch 1080p Plasma Hdtv , Displays
