The Official Panasonic U50/54 Owners' Thread - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1051 of 1088 Old 11-16-2013, 11:49 AM
bscool's Avatar
Quoted: 16 Post(s)
Factory service menu settings and results
R 80
G 80
B 80
R FF
G EB
B 7D
Contrast: 81
Brightness: 51
Color: 47
bscool is online now
post #1052 of 1088 Old 11-17-2013, 10:12 AM
Tk111's Avatar
I use anikun's calibrated settings on my 50 and 60 u54 my contrast is at 90 bright at 60 and color at 49, looks great everything pops
Tk111 is offline
post #1053 of 1088 Old 11-28-2013, 10:19 PM
badfnz's Avatar
My U50 went tits up tonight. Got the 8 blinks of death from the red LED. It was only 15 months old and was bought to replace a 2008 Panasonic plasma (don't remember the model) that stopped working as well. I'm officially done with Panasonic but in the mean time, I need to figure out what's wrong with this one.
badfnz is offline
post #1054 of 1088 Old 03-31-2014, 12:45 AM
StinDaWg's Avatar
Quoted: 450 Post(s)
Liked: 214
Supposedly Walmart is selling the 60U50 for $628 in store. Has anyone actually seen these? I have no idea why they would all of a sudden be selling a year old model.
http://www.walmart.com/ip/Panasonic-Viera-U50-Series-60-Class-Plasma-1080p-600Hz-HDTV-TC-P60U50/21569912
A few posts about it here...
http://forum.blu-ray.com/showthread.php?t=237915
I've considered buying a 60" LG plasma for $600, but if they are actually selling these Pannys I'll have to go check it out. Black levels are around .005fL on these right?
Edit: CNET says .0031fL
http://www.cnet.com/products/panasonic-tc-p60u50/2/
StinDaWg is offline
post #1055 of 1088 Old 04-04-2014, 09:51 PM
StinDaWg's Avatar
Quoted: 450 Post(s)
Liked: 214
Bump to see if anyone has seen one in the wild.
StinDaWg is offline
post #1056 of 1088 Old 05-01-2014, 07:06 PM
dlee275's Avatar
I found one at a Walmart near Raleigh. It was wrapped in plastic in the back; I was told it was getting ready to be shipped back out to a Walmart warehouse somewhere. I don't know if that means Walmart.com will be selling these stragglers or not. The price was 798, but I guess that is a pretty good deal for a 60" plasma, much less a Panasonic, even if it is their lowest level. I was really close to grabbing one of the 60in Samsung before I found this.
dlee275 is offline
post #1057 of 1088 Old 06-04-2014, 02:35 PM
don480's Avatar
Quoted: 53 Post(s)
Hi guys, I am having an issue with my U54 with the HDMI. I have a Sony blu-ray player hooked up to it directly and more recently I would occasionally get flickering and snow and artifacts and then would come back to normal. Happens off and on. Well I picked up a used Marantz av8801 and now the flickering/snow is now worse and happens more often and not to the point where its says no signal. So I would disconnect from the back of the TV and then reconnect and would sometimes solve the problem for a short while. Even disconnected from back of receiver and then would resolve issue for a short time. So I decided to change ports on the back of my receiver and then stopped for awhile until I swiveled my TV and then it started acting up again. So I disconnected my the hdmi from back of my TV and reconnected and problem solved for now. Its played fine as long as I don't move the TV for the past hour. Not sure if its the TV or the Marantz. I recently took in my Marantz to an authorized service center for something entirely different and they did a firmware update and it resolved that issue but the techs never mentioned they had any issues with the hdmi handshake. I called the service center and they believe its my TV and recommended to do a firmware update. I don't see any option on the menu for a firmware update on the TV and no literature online. Anyone have had similar issue as mine? How did you resolve it? Firmware update? Any thoughts?
don480 is offline
post #1058 of 1088 Old 06-04-2014, 05:08 PM
microbob's Avatar
Quoted: 32 Post(s)
Liked: 24
There's no newer firmware for the U54 available from Panasonic. I doubt they will update it either since they no longer make plasmas.
Robert
microbob is offline
post #1059 of 1088 Old 06-04-2014, 05:17 PM
cv1981's Avatar
I had a similar issue with my older panny plasma connected to a yamaha receiver, turned out it was a bad hdmi cable. Can't say for certain if that's the problem you're experiencing, but I guess it's worth a shot to try out different hdmi cables.
cv1981 is offline
post #1060 of 1088 Old 06-04-2014, 07:30 PM
microbob's Avatar
Quoted: 32 Post(s)
Liked: 24
That's what it sounds like to me. Either a bad cable or you could have a the plug that is not pushed all the way in.
Robert
microbob is offline
post #1061 of 1088 Old 06-05-2014, 07:47 AM
bbexperience's Avatar
Liked: 53
It's not an HDMI handshake issue. As others have said, it's either the cable or the HDMI port on the TV. You can pretty safely say it's not the receiver since it was doing it before that with the blu-ray. Try a new cable in the HDMI port you've been using and if that doesn't work try the other HDMI port on the tv. That should pinpoint the issue for you.
It's also possible that both ports share a board that's going out. In that case switching ports may not help you.
Read. Think. Post. In that order, preferably
"If the Playstation and Xbox are like the Bloods and the Crips, then the Wii is whatever gang Sha Na Na was in" - Christian Finnegan
bbexperience is offline
post #1062 of 1088 Old 06-05-2014, 09:34 AM
don480's Avatar
Quoted: 53 Post(s)
Thank you for the reply. So I decided to connect laptop via hdmi to my tv directly and had no issues. So the I proceeded to hook my blu ray directly to my TV again and no issues this time. So I changed the monitor output on the receiver and then so far no issues. So it looks like it's my receiver. frown.gif
don480 is offline
post #1063 of 1088 Old 06-12-2014, 05:27 PM
Liked: 0
I've been reading these posts for some time and tried some different settings and I have a question. I'm not a tecky by any stretch of the imagination but I have an old Mitsubishi dlp that's still going strong and the Panasonic seems to be less sharp and the colors not as true. I used Neo's settings on both inputs. I have a roku on one input that seems to be excellent quality. The other input that has my directv is not quite as good. Its actually considerably less sharp and the skin tones too rich. Does anyone else have any suggestions for how I can sharpen up the directv picture, or has anyone experienced a lower quality picture from their directv feed than say a blu ray or roku? The old dlp is much sharper with better skin tones and its on directv as well. The dlp has the newer genie and the panasonic is connected to an hd dvr. Thanks.
ftlaudmom is offline
post #1064 of 1088 Old 06-13-2014, 04:59 AM
nveleven22's Avatar
I'm going to get backlash for this, but I don't care.
Don't use anyone else's settings. Calibrate by eye.
The colors were the first thing that bothered me about this set. I know how you feel.
Put a laptop or (something which has a color gamut that you are comfortable with) up next to your plasma. Connect your plasma to the laptop through HDMI, and extend displays so you have two screens side by side. Use the Panny's DVI input so that you have 1:1 pixel mapping and set the appropriate settings in the menu so there is no stretching and turn off burn in reduction (which makes the picture fuzzy)
Open up two instances of MS Paint (or whatever the Apple cost-inducing alternative is), leave one on each screen and fill the screen with various colors, each time adjusting the RGB values of your Panny to match your laptop as close as possible.
When you get those accurate, as a final test, put up a picture on both with lots of skin tones and make any final adjustments.
Fuzzy picture is a different matter, what input are you using/what device are you outputting from,do you have any scaling enabled, etc.
nveleven22 is offline
post #1065 of 1088 Old 06-13-2014, 10:18 AM
Liked: 0
Thanks for the suggestion. I'll give it a try. I'm using hdmi input 1 for my satellite and the receiver is the hr24 500. I haven't messed with any of the satellite box settings from how it was installed. I also don't have any scaling enabled. Although I must say that last night the basketball game looked nice and sharp so i think the broadcast quality is probably what is making the difference. I guess I just didn't notice such big changes before when viewing the dlp. Most content looked pretty good while watching the same channel. However today the world cup match looks awful. So it's kind of frustrating.
post #1066 of 1088 Old 07-07-2014, 07:49 PM
BNestico's Avatar
Quoted: 148 Post(s)
Liked: 210
Just a question if anyone is still watching this thread. I've had my tv for over a year now and love it. I'd like to try some of the different settings but I'm a little nervous about changing the service menu settings. I've heard you can really screw up your tv if you don't know what you're doing. Should I just steer clear of the service menu if I'm not overly comfortable with it?
BNestico is offline
post #1067 of 1088 Old 07-21-2014, 10:13 PM
tvaddicted's Avatar
You can brick it if your not real familiar. I have a 2011 st30 and read all the posts about going into the service menu. I decided to adjust the regular settings by eye, that is to my own liking, and skip the service menu. I'm happy with what I've got. If you love your tv, don't mess with it, lol.
Do you have a 60U50? I am looking at one now, is there anything you don't like about it in particular?
tvaddicted
tvaddicted is offline
post #1068 of 1088 Old 07-22-2014, 05:35 PM
BNestico's Avatar
Quoted: 148 Post(s)
Liked: 210
There's really nothing I don't like about, outside of the relatively limited picture menu. I have the 60U54, which just denotes a Sam's Club model rather than a Best Buy or Wal Mart model. I really believe that that this TV provides a PQ:$ ratio that is extremely difficult to match. During the day the TV looks great, but at night I find it nothing short of stunning, and have heard the same from others who have come over and watched it with me. I'd buy another one in a heart beat. Be careful with IR for a little while though, I had a very faint H from the History Channel for a while cause I fell asleep in from of American Pickers one nigh for a few hours without the pixel orbiter on.
Panasonic P60U54
Marantz SR-7009
Polk Audio RTi8's, CSi5, RTi6's, OWM3's
SVSound PC12 Plus, PC Ultra (12")
Sony BDP-S7200
BNestico is offline
post #1069 of 1088 Old 09-22-2014, 06:41 PM
Goatz18's Avatar
Line Bleed and Video Game Burn In
I have a Panasonic TC-P50U50 and the picture quality, black level, and color are fantastic. I do experience some pretty bad line bleed though, and serious burn in from playing games with HUD displays. I have FIOS and text, graphics, and scenes with window blinds cause line bleed all the time. I have 360 and PS3 and first person shooters with HUD displays are serious burn in offenders, I have to stop playing for a week and run my Disney WOW bluray as much as I can. It all goes away eventually, but is a real hassle.
Is this typical or could some settings be tweaked to at least limit these things from happening? I had thought Plasma's were relatively free of these issues as was my understanding before purchasing the TV, I now have found some information otherwise, like on this site and others that I wish I found before, specifically on Panasonics. Despite the amazing picture, I would almost prefer an LCD with more options and video inputs like VGA. Anybody have any advice, tips, or anything? Other than buy an LCD for gaming?
Goatz18 is offline
post #1070 of 1088 Old 09-23-2014, 07:57 PM
cv1981's Avatar
I get similar problems with my U50. The only things that I have found that help are to lower contrast to around 40-45, turn pixel orbiter on. I find contrast at those low levels way too dim though, so I just live with the image retention, atleast with pixel orbiter on I don't get exact replicas of huds, just blurry scorch marks.
cv1981 is offline
post #1071 of 1088 Old 09-30-2014, 06:56 AM
ArnieG's Avatar
I was a little tired of my display setting so I changed to custom mode and recalibrated. Wow, what a difference! The picture now has a real pop now. After 2 years on cinema mode it seems like a new tv!! The picture may not be as accurate but I'm much more pleased. Is there any harm putting contrast up near 100?
Sent from my SM-T530NU using Tapatalk
ArnieG is offline
post #1072 of 1088 Old 11-08-2014, 12:08 PM
shobuddy's Avatar
I've had this TV for a couple years now and my only gripe is the media player. When I play mp4 files via USB, the video is always garbled. Anyone have this issue or know a fix for it?
shobuddy is offline
post #1073 of 1088 Old 11-10-2014, 08:02 AM
Taheer19's Avatar
Quoted: 69 Post(s)
Liked: 24
So, When the U50 first came out I was working at a Best Buy and someone returned the 50" model. I ended up buying it for like $380 bucks. Freakin' steal. I had it for about a year, then when we moved I needed (wanted) a larger TV...but Panasonic had stopped making plasma's by then. So, I settled with a Samsung PN60F5300 and sold the U50 to a good friend of mine for $400. Decent set, but didn't compare in terms of PQ to the U50.
Long story short, I wasn't happy and have been looking endlessly for a 60" Panasonic for the past year.
Well, I was looking around and learned that the Walmart in a couple of towns over still had a TC-P60U50. I called to confirm and sure enough they told me they had one.
This was at 1AM Sunday Morning. I call a friend of mine and we hop in his truck and rush out there.
Once there we ask the guy who I spoke with on the phone to go grab the TV. He is gone for like 10 minutes, so I'm kind of shaking in my boots that it is all to good to be true.
The FINALLY, the guy walks out with the TV on a cart. I'm liking still freaking out at this point.
The box is covered in dust..I mean covered. This thing has been sitting in a warehouse for 2 years or close to it. They didn't know what they had and apparently know one else did either.
On the website it says "$628. In store pick up only." Well, when he rings it up, the register says $798.
I still think that $798 is good price for such a great tv...but I didn't want to pay it :
So, I pull up the website on my phone and the guy says, "We don't price match the website."
So, I respond with, "But it says 'in store pick up only.' so I can't order it online and you are the only location within 500 miles that has one."
That kind of stumped the guy so he gets a manager they come out and talk to me then finally agree to sell it to me for $628.
I grab it, and HDMI switch and I'm on my way!
The entire way home, I can't help but think...this is too good to be true. What are the odds?
In the back of my head I keep thinking that since this sucker has been sitting in a Walmart warehouse for a couple of years it has probably been banged around and might be jacked up once I open it up.
We get it in the house and unbox it.....and it is seems to be in great condition. I take down the Samsung and put this up in its place. Turn it on and it starts up no problem!
So, now almost a full year after Panasonic stopped making plasma TV's...I somehow found one that was still in a box at a retail store for $628!
And the best part? I coworker of mine bought the Samsung for $650 bucks! So, I basically didn't have to pay a thing for the Panasonic!
Taheer19 is offline
post #1074 of 1088 Old 11-10-2014, 08:18 AM
Gracepreacher's Avatar
Quoted: 138 Post(s)
Score! What a great story! Great ending! And a great TV!!!
Taheer19 likes this.
Gracepreacher is offline
post #1075 of 1088 Old 12-05-2014, 10:19 PM
thesharkman's Avatar
Quoted: 28 Post(s)
wish me luck, I think I have found an unopened 55UT50. it's 675; so, not as great a deal as you got, but still not bad nonetheless....and beggers can't be choosy during these dark times. lol.
thesharkman
thesharkman is offline
post #1076 of 1088 Old 12-31-2014, 10:07 AM
shobuddy's Avatar
Anyone have luck setting up this Viera Link on this TV with Chromecast where Chromecast will power on/off the TV.
shobuddy is offline
post #1077 of 1088 Old 01-26-2015, 02:32 PM
stickygreen's Avatar
Hey I just bought one of these TC-50PU54's It's used, but in near new condition. (Canadian value used is currently about $400)
I want to know if there is any way to get this TV connected to my network, via LAN, or WiFi?
I'd really love to be able to do this..
stickygreen is offline
post #1078 of 1088 Old 02-09-2015, 10:36 AM
Kevin Sylvain's Avatar
Liked: 0
So i am that guy that didn't write down the default settings in the service menu. I realize there seems to be some variance on default settings, but can anyone help me get close to factory for my 60U50?
Kevin Sylvain is offline
post #1079 of 1088 Old 02-10-2015, 04:31 AM
whipit's Avatar
Quoted: 96 Post(s)
Liked: 83
The way I understand it on Pannys the SD and HD settings are basically the same in the service menu. One won't affect the other. So, feed the tv a confirmed SD signal(press INFO button, look for 480) and then look for the settings in the SM. Write them down and then copy back while using an HD source.
whipit is online now
post #1080 of 1088 Old 03-05-2015, 02:11 PM
wheatworth's Avatar
Liked: 0
HDMI audio input issue
I have the panasonic tc-50pu54 and think I have an hdmi issue with one of my inputs. We just moved and at the old house I thought I had a bad HDMI cable because I would get video but no audio. I never changed it because it was run through the wall and it would have been a pain. Besides the other input worked just fine.
Now at the new house I have the same issue, one input works fine the other gives me video but no audio. I've tried different cables with no luck and different sources (AppleTV and Chrome cast) with the same result.
I'm using an optical cable to a sound bar which works great on the one input but shouldn't it work on both inputs?.
Do you think I have a bad input or is there a tv setting i don't know about?
wheatworth is offline
Panasonic , Panasonic Th 50pz77u 50 Inch 1080p Plasma Hdtv , Displays
taboola here
