The Official Panasonic VT50 Settings Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #361 of 2198 Old 08-07-2012, 05:15 PM
jasjw's Avatar
Quoted: 42 Post(s)
Originally Posted by wmwilker View Post
It also opens the ISF Day and Night modes
Yes I keep reading about day and night modes but aren't they just a better name for pro modes 1 & 2 or do they service another purpose?
LG 65C6 OLED
Onkyo HT-R390
Dune Solo 4K
SKY Q
Xbox One
jasjw is offline
post #362 of 2198 Old 08-07-2012, 07:45 PM
Quoted: 46 Post(s)
Liked: 61
Sorry, I didn't notice you were in the UK. The US models have the Custom mode which is the only one with the full Pro menu unless you unlock it with ControlCal or CalMAN.
I assume the Pro 1 & 2 are the same as ISF Day & Night
Mike
wmwilker is offline
post #363 of 2198 Old 08-07-2012, 10:40 PM
MrBeer's Avatar
Got my ISF Day finished. The new firmware makes the calibration much easier. I also see a significant improvement in my picture.
The settings can be found in the XML file in the Zip file.
The report is also attached.
ISF Day 8-6-12.zip 193k .zip file
Thanks for the work look nice my set is looking better are u going to redo the night setting to
MrBeer is offline
post #364 of 2198 Old 08-07-2012, 10:58 PM
sillysally's Avatar
Quoted: 828 Post(s)
Liked: 848
I don't think so. Wouldn't the gamma trail up from 90 if it did hold 2.4?
No, it trails down to around 2.25 I am using normal and mid. Actually with those settings 2.4 tails down to about 2.5 and 2.2 drops to about about 2.0.
These readings are from the old firmware on the VT50.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #365 of 2198 Old 08-08-2012, 05:38 AM
Quoted: 1394 Post(s)
Liked: 588
Anyone else find that they're so focused on calibration and picture quality on their new VT50 that they're not into the movie/show as much as they would like?
tbaudoin likes this.
JimP is online now
post #366 of 2198 Old 08-08-2012, 05:53 AM
jasjw's Avatar
Quoted: 42 Post(s)
I wish some of the UK lads would be so nice as to post some calibrated settings. I'd love to try some. I have tried some US ones posted here but obviously they are way out plus you guys get options we don't.
LG 65C6 OLED
Onkyo HT-R390
Dune Solo 4K
SKY Q
Xbox One
jasjw is offline
post #367 of 2198 Old 08-08-2012, 06:07 AM
Quoted: 46 Post(s)
Liked: 61
ss
I worked with the Night settings last night and when set at 2.2 there was too much adjustment. When set at 2.4 I did very little. The picture is gorgeous.
Mike
wmwilker is offline
post #368 of 2198 Old 08-08-2012, 07:00 AM
Quoted: 46 Post(s)
Liked: 61
My ISF Night settings are in the XML file here:
http://www.controlcal.com/forum/showpost.php?p=6497&postcount=18
Light output is at 34 ftL which should be good for a dark room.
Mike
wmwilker is offline
post #369 of 2198 Old 08-08-2012, 09:56 AM
General Kenobi's Avatar
Quoted: 357 Post(s)
Liked: 640
Looks like I need a membership to those forums to open it.
Kenobi's 31 Days of Horror:
2012
2011
2010
2009
General Kenobi is offline
post #370 of 2198 Old 08-08-2012, 10:02 AM
Quoted: 46 Post(s)
Liked: 61
It's free but I'll post the file here when I get home this evening.
Mike
wmwilker is offline
post #371 of 2198 Old 08-08-2012, 12:50 PM
Quoted: 357 Post(s)
Liked: 640
I've got them here but not 100% confident I know how they line up and correspond with the selections in the menu as I'm not familiar with the order controlcal organizes the numbers in.
Here are the numbers, if anyone cares to tell me the order I'd be happy to put it in an easier to read format.
80 52 0 0 50 0 0 -2 0 7 3 0 -1 Warm 2 2.4 Normal Medium Off Off Off -6 -5 -10 27 35 -11 22 50 -10 -16 2 5 5 1 8 -1 -14 4 0 0 3 7 0 3 4 0 1 4 0 2 2 0 -2 1 0 -1 0 0 -5 -1 0 1 -2 0 -4 -3 0 -4 -11 10 8 7 3 5 1 2 -1 0
2012
2011
2010
2009
post #372 of 2198 Old 08-08-2012, 01:00 PM
Quoted: 46 Post(s)
Liked: 61
the XML should open in Explorer on a Windows machine. The formatting should work.
Give me a few and I'll try it from here and post the pdf
Mike
wmwilker is offline
post #373 of 2198 Old 08-08-2012, 01:04 PM
Quoted: 46 Post(s)
Liked: 61
ISF Night Settings - They can be used in the Custom mode
ISF Night.pdf 69k .pdf file
Mike
wmwilker is offline
post #374 of 2198 Old 08-08-2012, 01:04 PM
Quoted: 357 Post(s)
Liked: 640
hold please, I have an app for that;)
wmwilker likes this.
2012
2011
2010
2009
post #375 of 2198 Old 08-08-2012, 01:30 PM
Quoted: 357 Post(s)
Liked: 640
Ok wmwilker, here are your night settings, pls let me know if I've made any errors in the translation.
Picture mode Custom
Motion smoother: Off
1080p pure direct: On
Black level: Light
3:2 pulldown: On
24p Direct in: 96hz
Contrast: 80
Brightness: 52
ACG 0
Black Ext. 0
Color 50
Tint: 0
Sharpness 0
WB High R -2
WB High G 0
WB High B 7
WB Low R 3
WB Low G 0
WB Low B -1
Color Temp: Warm2
Gamma 2.4
Color Space: Normal
Panel Brightness: Mid
C.A.T.S. OFF
Video NR: Off
Contour Temp: Off
Hue * Sat * Lum
Red: -6, -5, -10
Green: 27, 35, -11
Blue: 22, 50, -10
Yellow: -16, 2, 5
Cyan: 5, 1, 8
Magenta: -1, -14, 4
White Balance 10pt.
10IRE
0
0
3
20IRE
7
0
3
30IRE
4
0
1
40IRE
4
0
2
50IRE
2
0
-2
60IRE
1
0
-1
70IRE
0
0
-5
80IRE
-1
0
1
90IRE
-2
0
-4
100IRE
-3
0
-4
Gamma 10pt
10IRE
-11
20IRE
10
30IRE
8
40IRE
7
50IRE
3
60IRE
5
70IRE
1
80IRE
2
90IRE
-1
100IRE
0
2012
2011
2010
2009
post #376 of 2198 Old 08-08-2012, 02:03 PM
Quoted: 46 Post(s)
Liked: 61
Mike
wmwilker is offline
post #377 of 2198 Old 08-08-2012, 02:28 PM
mwag's Avatar
In the XML file those data values should be labeled. I've noticed that they doesn't exactly match up to the order of the menu settings, but it's better than nothing.
EDIT: OOPS... I should try refreshing the thread before replying. Looks like you have it under control!
mwag is offline
post #378 of 2198 Old 08-08-2012, 02:57 PM
turbe's Avatar
Liked: 95
once and if you do an actual calibration, I'm confident you will prefer ControlCAL's layout to the display's...
one change I may do is combine the 10pts (w/b&gamma)..
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #379 of 2198 Old 08-08-2012, 03:25 PM
blwegrzyn's Avatar
wmwilker, would those settings work for 55" ?
blwegrzyn is offline
post #380 of 2198 Old 08-08-2012, 03:31 PM
Quoted: 46 Post(s)
Liked: 61
I have no idea. Anytime you copy someone's settings it is a hit or miss. If you like your current settings write them down and then try mine. Be aware these are night settings so they are made for a dark or dimly lit room.
My Day settings are in this thread too.
Mike
wmwilker is offline
post #381 of 2198 Old 08-08-2012, 08:07 PM
MrBeer's Avatar
wmwilker all i can say is thanks you for the 1000 time your setting are so nice. the 150 firmware fix the tv.
If you every change your setting can u repost them.
Thanks going to watch some movies now
MrBeer is offline
post #382 of 2198 Old 08-08-2012, 10:41 PM
restricted3711's Avatar
I agree, wmwilker, your settings are spot on especially with the colors. I just adjusted the contrast and brightness for my room using the DVE Blu Ray, and the new settings after the update are AMAZING. These settings will definitely do until I can buy the equipment and calibrate it myself. Thanks a million.
restricted3711 is offline
post #383 of 2198 Old 08-08-2012, 11:15 PM
Ss10zidane's Avatar
man wilker your night settings look good so far, getting better pop and more detail and color on skin tones is better
Ss10zidane is offline
post #384 of 2198 Old 08-09-2012, 12:32 AM
sillysally's Avatar
Quoted: 828 Post(s)
Liked: 848
I was also playing with my new i1pro2 last night, however as Tempest pointed out using calman with a i1pro 2 there seems to be a problem reading 10 and 20% IRE's.
I think you use different software and a i1pro 2, are you having problems with readings for 10 and 20% IRE's with your software ?
ss
post #385 of 2198 Old 08-09-2012, 01:37 AM
Quoted: 357 Post(s)
Liked: 640
Agreed, I plugged them in as well and on my 3D settings and think they look fantastic! Watching Planet Earth now with the great sir David Attenborough and while this transfer is noting all that special compared to some other nature programs it is looking fantastic now! Not a bad disc to use to break in either, I run this on repeat for the night on nights I've played the 4hr xobx session.
The day settings looks great too but since mose of my critical watching is at night I'm sticking with the night settings for my 3 sources and will use THX Lightroom for day viewing until I get my calibration.
2012
2011
2010
2009
post #386 of 2198 Old 08-09-2012, 04:23 AM
Liked: 588
ss
SS
I've heard (no personal experience) that the i1pro (the pro2's predicessor) had trouble with low light levels and someone around here would only use it down to 30 IRE due to that problem. That's why many use an better meter to profile a color meter that will read at lower light levels. If you kept your colormeter, you probably could do the same.
My i1pro2 is on order so I'm also trying to figure this out.
JimP is online now
post #387 of 2198 Old 08-09-2012, 04:59 AM
buzzard767's Avatar
Quoted: 1619 Post(s)
Liked: 2393
Originally Posted by JimP View Post
SS
The i1Pro2 has two advantages over the i1Pro1, time between dark readings and temperature stability. They both are accurate down to 30% peak white which will measure +/- 2.5 Foot Lamberts. They are unreliable at lower luminance points. The best affordable Colorimeter is the X-Rite Display 3 which is accurate to .001 FtL. The D3 can be easily profiled from either the i1Pro1 or i1Pro2 and used throughout any calibration for faster reads, better accuracy at low luminance, and no dark readings.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #388 of 2198 Old 08-09-2012, 06:52 AM
Famouss's Avatar
Quoted: 22 Post(s)
Liked: 48
Hmm I will try these settings out later this evening and see how things go. I am still using your older settings, which looked pretty good I might add.smile.gif
Panasonic TC-P65VT60
Sony BDP-S5100
Elite PRO-101FD
Famouss is offline
post #389 of 2198 Old 08-09-2012, 07:44 AM
Quoted: 46 Post(s)
Liked: 61
ss
I use Chromapure. I have an i1 Pro and a i1 D3 Pro. I've been using the spectro on these last 2 cals. 10 & 20 are both erratic but if I keep at it I can get a close reading.
I will probably go back and try with the D3 Pro when I get time just to see if it actually makes a difference.
BTW I recently had Tom Huffman re-calibrate my i1 Pro so I feel very confident in it's accuracy.
Mike
wmwilker is offline
post #390 of 2198 Old 08-09-2012, 08:00 AM
hunspikey's Avatar
Hey there,
I also have the European version of 55VT50 and I do struggle with the settings. Did you manage to calibrate the display to be better than the built in THX mode?
I tend to believe that the Eur model does not even have some of the menus the guys are talking about here eek.gif
hunspikey is offline
Panasonic Viera Tc P55vt50 , Plasma Hdtv , Displays , Panasonic Viera Tc P65st50 Plasma Tv
