The Official Panasonic VT50 Settings Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #901 of 2198 Old 01-15-2013, 11:29 AM
johnnylighton's Avatar
Originally Posted by sillysally View Post
Just make it very clear you do not want BB calibrator to use the service menu, and you should be fine.
Calman is a real Calibration software and there for not Cheap. If you want to get into the calibration hobby then yes I would say yes get Calman 5 (at-least) Control and a I1 Display pro. If you just want to input Calman's settings and open ISF modes then just get the cheapest Calman.
However many of the calibration settings that are posted by DIY's are done using Controlcal, and if that's the case you can use Controlcal to open and input these ISF settings.
I don't use Controlcal to input my settings so Controlcal will not work for my setting. Controlcal is a tool to open ISF modes on a VT50 and input settings, its not a calibration program like Calman.
ss
Good info - thank you. smile.gif I would love to try my hand at calibration but don't have the time right now. So I will probably just go with ControlCal. I will also take a chance on BB's free calibration, telling them no service menu, and report back on how it went.
johnnylighton is offline
post #902 of 2198 Old 01-15-2013, 01:47 PM
JohnDG's Avatar
Quoted: 12 Post(s)
For those who have gone thru the process to create a separate 3D calibration, did you find it makes much of a difference as compared to simply copying over the ISF Day settings?
jdg
JohnDG is offline
post #903 of 2198 Old 01-16-2013, 04:55 AM
stixx's Avatar
jdg
Made a difference for me. The calibration is adjusted for the dark lenses on the 3d glasses. Of you look at the image without glasses, the image looks VERY bright and washed out. With glasses however, it looks great.
stixx is offline
post #904 of 2198 Old 01-16-2013, 07:03 AM
JohnDG's Avatar
Quoted: 12 Post(s)
That is interesting. I compared my ISF Day copied settings with the built-in THX 3D settings and the ISF Day copied is brighter.
You must really have pumped-up the output for your calibrated 3D settings.
jdg
JohnDG is offline
post #905 of 2198 Old 01-16-2013, 08:56 PM
Mac13's Avatar
Originally Posted by robnix View Post
You can put them in custom mode manually. I highly recommend ControlCal though, it's a small investment for an incredible amount of convenience.
So is the ISF mode really the same as custom but the ISF modes are just locked? Can I just input people's (yours) ISF settings into my Custom mode? I didn't think about doing that or know that I could. For some reason I thought there was some difference.
Mac13 is offline
post #906 of 2198 Old 01-16-2013, 09:14 PM
turbe's Avatar
Liked: 97
you can do that...
during calibration, adjustments using the remote and the menus can be frustrating, ControlCAL eliminates that..
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #907 of 2198 Old 01-18-2013, 04:02 PM
heisman's Avatar
Just received this set from Amazon this afternoon. Am trying to adjust the settings based on some of the suggestions in this thread, but I can't access them (specifically color management). Does anyone know why?
heisman is offline
post #908 of 2198 Old 01-18-2013, 04:08 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Did you switch to Custom mode to get to CMS?
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #909 of 2198 Old 01-18-2013, 04:21 PM
heisman's Avatar
Yes, and still grayed out to the off position.
heisman is offline
post #910 of 2198 Old 01-18-2013, 04:26 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Something's not right. Custom mode gives you access to all the color and gamma settings you could ever want. This is a U.S. model, correct?
scirica is offline
post #911 of 2198 Old 01-18-2013, 05:11 PM
KONICA TECH's Avatar
Quoted: 30 Post(s)
Liked: 55
KONICA TECH is offline
post #912 of 2198 Old 01-18-2013, 05:53 PM
heisman's Avatar
Originally Posted by KONICA TECH View Post
Make sure you are in home use and not store Demo mode:)
BAM! Thank you kindly.
heisman is offline
post #913 of 2198 Old 01-19-2013, 10:35 AM
wzh2hz's Avatar
Originally Posted by wmwilker View Post
ISF Night Settings - They can be used in the Custom mode
ISF Night.pdf 69k .pdf file
I recently received my 65VT50. I plan to have it professionally calibrated once I have over 300 hours. In the meantime, I am using wmwilker's settings in custom mode. I have almost all of the settings entered and saved. There are 2 that are greyed out and I cannot change. They are: 1080p pure direct - off and 24p Direct in - 60. I must have another setting incorrect that does not allow me to change these. Any help or direction would be appreciated. Thank you.
wzh2hz is offline
post #914 of 2198 Old 01-19-2013, 10:44 AM
turbe's Avatar
Liked: 97
those those, input 1080p signal
ControlCAL™
turbe is offline
post #915 of 2198 Old 01-19-2013, 11:10 AM
mo949's Avatar
Liked: 1184
You only see them when a 1080p signal goes into the tv. Use your bluray player and you'll see them.
mo949 is offline
post #916 of 2198 Old 01-19-2013, 11:10 AM
wzh2hz's Avatar
I think I've got it. Thank you for the help.
wzh2hz is offline
post #917 of 2198 Old 01-19-2013, 04:03 PM
billmich's Avatar
Quoted: 270 Post(s)
Liked: 60
What's the point of offering a 48hz setting for 24p if it is going to flicker that badly?
Do people here prefer the 96 or the 60 setting?
billmich is offline
post #918 of 2198 Old 01-19-2013, 04:39 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
I'm getting the best picture with 60hz. 48 is a joke. 96 isn't bad but you can still see a tiny bit of flicker.
scirica is offline
post #919 of 2198 Old 01-19-2013, 04:43 PM
billmich's Avatar
Quoted: 270 Post(s)
Liked: 60
I agree, 48 is a joke
But since 96 is an even multiple of 24, isn't that better than 60, which isn't....
billmich is offline
post #920 of 2198 Old 01-19-2013, 04:45 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
You would think intuitively that 96 would be better than 60, but both multiples of 24 are inferior to the 60hz. Jeff Meier did my set last Friday (8 days ago) and his final analysis was to use 60.
scirica is offline
post #921 of 2198 Old 01-19-2013, 04:47 PM
ruegway's Avatar
I am trying to Autocal my 65" VT50, and have a question. How do you access the patterns in the Panasonic so you can then Autocal.
I get as far as getting into ISF mode, and then try to find the source of the patterns, and they do not show up anywhere. According to Spectracal's website, the patterns should be there somewhere, or am I confused again? I was told I would not need any type of pattern generator or DVD to Autocal using Calman5 with a Control license, that there would be one that Calman could open up.
I am using WiFi to connect and having no issues with that.
Thanks for any help you might have on how to access the patterns.
ruegway is offline
post #922 of 2198 Old 01-19-2013, 04:48 PM
billmich's Avatar
Quoted: 270 Post(s)
Liked: 60
Thanks for the info!!!
But my original question remains: why the OFFERING of 48 as a setting if its gonna look like THAT?!?!
billmich is offline
post #923 of 2198 Old 01-19-2013, 04:49 PM
turbe's Avatar
Liked: 97
Many Calibrators recommend 60 still.
I know some owners like 60, others 96.. it's best for you to try both 60 and 96 on your reference content and see what you like.
ControlCAL™
turbe is offline
post #924 of 2198 Old 01-19-2013, 04:50 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Good question...perhaps some real Panasonic afficianados can enlighten us!
billmich likes this.
scirica is offline
post #925 of 2198 Old 01-19-2013, 04:57 PM
chunon's Avatar
Quoted: 2494 Post(s)
Liked: 2231
That 48 hz setting has been around for years and has never served any useful purpose in 2d some use it to mitigate crosstalk in 3d
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #926 of 2198 Old 01-20-2013, 07:46 AM
Ss10zidane's Avatar
That's correct 48hz for 3d is recommended if ur getting a lot of crosstalk
Ss10zidane is offline
post #927 of 2198 Old 01-20-2013, 10:30 AM
cssnms's Avatar
Has wmwilker come out with his 3D settings yet? biggrin.gif I applied the settings I found in Home Theater mag and I think they look terrible.
cssnms is offline
post #928 of 2198 Old 01-20-2013, 01:42 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Not sure if these will work for you, but they are the 3D (day) settings that my calibrator entered. ISF Day 3D.xml 3k .xml file
Your results may vary...
mo949 likes this.
scirica is offline
post #929 of 2198 Old 01-20-2013, 02:48 PM
cssnms's Avatar
Hey thanks for that. My TV is in a dark basement, so ideally a night setting would be best. Might give'm a try anywho.
cssnms is offline
post #930 of 2198 Old 01-20-2013, 03:58 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Just bring the contrast down. No need to get too complicated.
scirica is offline
Panasonic Viera Tc P55vt50 , Plasma Hdtv , Displays , Panasonic Viera Tc P65st50 Plasma Tv
